Hi, i would like to ask how to change node color can be suitable with main background?for example, if i change main background to black/dark, node color not changed (still black). so, i cannot see the nodes.
Thank you,
Regards!
Which software you are referring to?
If this is STAAD.Pro, then there is no way to change the color of node. But if you press CTRL+K, it will show you small circle and that may help you to identify the nodes.
