Ram Connection Error: No Connection has been detected in the model
I modeled and analyzed a Tube membered structure as per IS:800-2007 LSD in STAAD.Pro Advanced CE - V 22.12.00.142 , and tried connection design using integrated Ram Connection as Per American Code.
I am encountering an error that connections are not detected.
I have assigned member attributes as Column, Beam, and Braces as incidental in the Staad Model before starting Ram Connection. Please Help
View Cutter.STD
