Whenever i try to create slab in STAAD.Pro so as to export it to RAM CONCEPT i get this notification as shown on the attached picture
Iam attaching my sample staad model for your help
5635.Structure1.STD
I have selected the geometry which include all plate elements which form the slab, as well as column members both above and below the slab, when i click on create slab option i get that message
Make sure that only this .std file is opened in your computer and then try the process again.
This is the only std file opened in Staad pro,but that message appears
Structure1_REI2CONCEPT.cpt
Go to Layers -> Mesh Input and double click on the Standard Plan.
Thank you Modestas i can see i was skipping this option of 'input mesh'
I have noted another thing in STAAD file columns are circular but RAM Concept read these columns as rectangular, is there any logic behind this scenario?
