while I am coding in VBA, I need to obtain the output units in Open Staad for forces, moments and dimensions (for example for beams internal forces).
I use the commands:
GetOutputUnitForSectDimension
GetOutputUnitForForce
GetOutputUnitForMoment
By the way, the result is a number and I do not know which is the related unit (m, mm, inch, ft, kN, kip, ...)
Does anyone know what these numbers mean?
Thank you in advance
The correct syntax of the function is given below
Dim strOutputUnitForDisplacement As StringDim strOutputUnitForRotation As StringDim strOutputUnitForForce As StringDim strOutputUnitForMoment As String
objOpenSTAAD.Output.GetOutputUnitForDisplacement strOutputUnitForDisplacementobjOpenSTAAD.Output.GetOutputUnitForRotation strOutputUnitForRotationobjOpenSTAAD.Output.GetOutputUnitForForce strOutputUnitForForceobjOpenSTAAD.Output.GetOutputUnitForMoment strOutputUnitForMoment
But these functions returns output unit used by the GUI as a string.
If you want the unit of the displacement for function GetNodeDisplacements or the unit of the force for function GetIntermediateMemberForcesAtDistance, then the unit are always in BASE UNIT of the structure.
So, function GetOutputUnitForDisplacement returns the unit used by the GUI and the unit of the displacement for function GetNodeDisplacements are in BASE UNIT of the structure.
