1. Whenever beam is split because of node insertion, beams with smaller length are failing in shear-Tcmax (Beam 42, 36 in below figure).
How to modify these members to pass the section without failure??
O22064-C-FB-07-DC-0001_B.std
2. Also when there is discontinuity (Beam 17, 18) "sway" condition is becomes governing.
Please find the staad, RCDC files(secure file upload) and help me how to modify my structure of beam dimensions to avoid failure??
Uploaded file names
Dear Sir,
Understood your requirement. No need to do any changes in STAAD file. Please find attached video showing converting two beams into one beam by removing support in RCDC.hope it will resolve your problem.
./cfs-file/__key/communityserver-discussions-components-files/5932/video-_2D00_-to-change-Beam-continuity.zip
Answer Verified By: Ashok Yarrabothula
Thank you, Abhijeet
