I might have accidently clicked something in my model, because now every time I save my model, saving is a lot slower. When comparing with older versions of my model, the saving seems to slow down for the files ending in .c0, .c1, .c2, .c3.
Can anyone please provide some clarity? I am afraid I drastically changed something in my model.
I figured it out. These files started appearing after I had run the concrete module.
Yes, those sound like concrete analysis results files. In Ram Frame and in Ram Concrete there are some optional results in the criteria dialog that can saved or excluded (things like diaphragm stresses). If model save times become a problem, you can turn those options off. Then turn them on again only when you need to scrutinize those results.
