How can I insert this command as shown below into staad "Command File"?
PRINT SECTION (MAX) DISPLACEMENTS (NSECT i) (SAVE a) { NOPRINT | ALL | LIST memb-list }
You can enter the command PRINT SECTION DISPL LIST 1 (where 1 is the member number) directly into the STAAD input file by using the STAAD Editor after the PERFROM ANALYSIS command or add it by using the GUI:
