Hello.
I am working on a RAM model for a wood structure of roof & attic.
After I ran "Analyze model", I found that all the loads on the structure were disappeared.
Could you please check the attached file and give me comments?
Thanks in advance.
RE Model.zip
The category property that is defined for the applied loads has not been set correctly. Refer to the property marked in the image below. The use of "1" is reserved for loads that are calculated internally by the program from modeled deck areas, which are not used in your model. Deck area loads are cleared and recalculated each time the analysis is run.
To resolve the problem, use either 0 or 2 for the category.
0 = load applied to the member calculated based on the projected length of the member
2 = load applied to the over the actual member length
