Section 12 of IS800-2007 LSD Design Parameter
I am trying to use Design Parameter of Section 12 of IS800-2007 LSD in STAAD.
Please suggest which Design Parameter of Section 12 should be taken care in STAAD File.
Any Example will be helpful.
  • Please refer below section from help file.
    Home > Design > D. Design Codes > D8. Indian Codes > D8.A. Indian Codes - Steel Design per IS 800 - 2007 > D8.A.7 Seismic Detailing per Section 12
    Regarding the parameters you need to use Seismic, IMM, SSY and SSZ. Details can be found in help file.
    Home > Design > D. Design Codes > D8. Indian Codes > D8.A. Indian Codes - Steel Design per IS 800 - 2007 > D8.A.4 Design Parameters
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
