I start STAAD, click on Configure > File Format > Input format. I select all items under "Input format > Single Line Format Commands:", and "Write expanded list", then click "OK". After all these steps, I opened the Command File of an existing STAAD model, the Joint Coordinates and member incidences are still shown as previous format, not the single line format that I want......
I think you are doing the correct steps. Once you set the configuration as stated in your statement, pleases open the STAAD file and then save the file from GUI using save button.
Now open the editor file and it should be written in single line format.
Answer Verified By: Jean Lin
Thank you very much! This works!
Glad to know it helped.
