RAM is showing a failure for "web plate strength due to out of plane transverse load" but I do not believe it applies. Below is a figure from the Design of Wrap Around Gussets paper referenced at the bottom of the results. It shows there should be no out of plane loads applied to the beam or girder but that does not seem to be what RAM is doing. Attached is the Connection Data and Design Report for reference. Using V13 Upate 9.
PDFPDF
Can you send your file? I threw together a horizontal brace connection per AISC 36016 ASD and I'm not seeing that web plate check at all. I also have version 13.09.
File uploaded. Filename HBBB. Spending further time investigating, the demand on the gusset-to-beam and gusset-to-girder connection changes significantly depending on whether it is directly welded or bolted.
I see, that check is not even performed when the interface of the gusset to the beam/girder is bolted angles. I'll have to do some digging to find out why we implemented things differently.
Any updates on this?
Some feedback from the Ram Conenction team:
When the user selects a directly welded connection for the HCBB Connection, we utilize the same design considerations as for a single plate connection in a Beam to Column configuration. This is due to their similar geometric and loading characteristics, and as a result, the capacities we are evaluating are based on the single plate design. The Web Plate Strength due out of plate transverse load capacity is included within the single plate design, which assumes a plate that remains continuously attached to the web of the supporting member. This approach only applies to directly welded connections. In instances where the connection is bolted, we follow the standard clip angle approach and assess all relevant capacities associated with that connection. Such capacities are available for BCF, BCW, BG, and gusset connections.
