Hello
I am currently using the floor load to assist with applying wind loads on walls. However, when I am checking the wind load there's an issue where it looks like it's not being applied correctly. Is this a visual glitch or is it being applied incorrectly?
The walls are on different planes (differing X-values) and I'm not sure if that affects anything.
Can you please share the STAAD model for investigation?
