Ram SS - Knee Brace on sloping slab (Ramp)
I am adding knee braces to my frame which is located at a ramp. For some reason my knee braces are attaching to my level and not my beam. The location of my beam is at a different elevation from my ramp level (I had to adjust column heights to create my ramp).
Do you know why my knee braces are attaching to my level and not my beam? Is there a way to correctly attach my knee braces?
Parents Reply
  • Seth, I also tried starting my knee brace with a calculated wrong location so when I later input my correct column height my knee brace goes back to the correct location. For this approach I had to subtract my vertical height elevation from each beam (at each location) to my vertical knee brace height. This approach was working fine until I had negative numbers which the system will not allow me to input them on the "Steel Brace - Standard Profile."
