For some reason, RAM Frame is not reporting the unbalanced brace loads in the Seismic Provisions > OCBF-V beam output. Is this a software bug or did I miss a setting somewhere?
Thanks for the suggestions, but I tried deleting and remodeling the braces with no success. Changing the code also didn't help. We have already done the checks by hand, so this is not a huge priority for me, but it is a nice feature to double check with.
If you want to send the file I can check it in the latest build.
I would be curious to see if you have better luck. Uploaded.
It's working for me. I happen to be testing our prerelease build so it's possible that something changed since the released verison (I'll do a little research).
