I would just like to clarify if the issue stated in this help forum is updated.
Analyzing multiple disjointed structures in one model
Has this issue been addressed in STAAD Connect Edition? If yes, which update version has it. If not, are there plans of fixing it?
Thank you.
Thank you for both of your answers.May I ask, in follow up, why can't STAAD create a separate stiffness matrix for disjointed structure and compute "separately"? Is there a special reason for this?
Please note that stiffness of the disjointed structures will be considered separately but the problem is that there will be a single mass matrix. In other terms the total seismic weight of the multiple structure will be conceded to compute a single horizontal base shear that will be distributed as storey shear.
