RAM Connection Base Plate Anchor Bolt Force Distribution
Why is it that in RAM Connection, Base Plate module, fixed biaxial, that tensile loads in anchor bolts aren't distributed based on their location to the load application point?  For example, if I have a column with a 2x2 anchor bolt layout, with one of the anchors offset from the standard pattern, the anchor bolts should not all have the same tensile loads but they do in RAM Connections.
