Good morning,
I am working on a tool using RAM DataAccess and have two questions:
1. What is the most current documentation for DataAccess? The developer's guide packaged with my version 17.02 RAM SS install is for Release 15.06.00. I am having trouble locating more up-to-date documentation.
2. There are a couple errors in the documentation affecting my software. First, the Get() and GetAt() methods take an int UID rather a long. Second, and more critically, it appears that if a Get() method is fed an invalid lUID, a NullReferenceException results. The documentation states that the Get() method should return a NULL pointer in this case. Are these issues known?
Adam Schulz
The Ram DataAccess Developers Guide.pdf manual has not been updated in a while, regretfully. I will make a point of getting this updated sometime after the imminent release. Meanwhile I'll check with our developers about item 2.
Good morning Seth,
Do you have any update on this issue?
Seth,
Has there been any progress on this question?
Thank you,
