As far as I can tell - it isn't possible to name weld groups like you can other joints in RAM Connection. Am I missing something?
Standard Connection
weld
You are correct. The joint label is part of the joint properties, not the connection properties, and currently the weld group joint is not directly defined or editable. You can renumber the joint only.
Answer Verified By: TLiebhold
Thanks - please consider this a feature request to be able to name weld groups (and bolt groups).
Hello TLiebhold, let us plan this for Q2-Q3 for RAM Connection for both Bolt Groups and Weld Groups.You can check and follow this IDEA in our new framework in AHA.
RAM Connection Ideas (aha.io)
