Hello sirs!
Im recently started to learn Staad Pro and i want to know if im going to ignore duplicated nodes while in the Physical Modeller or is there a button or somewhere i can just delete those nodes? When i run the validate check i get the warnings but when pressing the warning, the nodes gets marked but i cant delete them then by pressing delete?
Once you do the integrity check it will give you option to validate.
Once you click on validate it will show you any duplicate node and also activate the option Delete to delete it. You can use that Delete option to accomplish the work.
Answer Verified By: Mrtb2arvd
Nevermind, i solved it
great!
Thanks anyways, sir =)
