I'm having an issue with my model, there's is a diagnoal decay at joint 52 direction Mz and joint 60 direction Mx and i can't find the issue. I've tried to find information about this error, what could it be ?
ThanksBentleyRev1.STD
The highlighted cantilever part is unstable as due to member releases it cannot resist the bending moments. You need to review the member releases assigned to these members and make sure that cantilever members have a fixed connectivity to the remaining structure.
Answer Verified By: David Archambault
Thanks you for you time ! I did release the wrong moment at one end for the wole platform by mistake oups
