RAM Frame loads
  1.  When I applied I auto lateral loads using RAM frame , I am getting some unclear results. There are only three diaphragms I defined, but there are 6 different loads that are being applied when I check the building story shears. I attached some screenshots showing different diaphragms and different loads being applied.
  2.
  1. There are some moment frames that do not seem to be participating in resisting any lateral load. Is there a reason why the model is behaving this way ?
