RAM Concrete Beam Design - Design Warning for Flexural Reinforcement
I have an 8"x16" concrete beam and in the end span of a multi-span condition, it says the bottom flexural beam reinforcement fails code limit by 1 bar. I have 2-#5 bars currently for all spans and for every other span, this is adequate and meets all code and design criteria. This error does not go away even if I add bottom bars to this span. The Design Warning message also does not even give a code section reference.
Is there a workaround for this, or is this something that should be able to be ignored?
RAMSS version 17.04.3.05
Code used: ACI 318-14
Parents Reply Children
