Mat Foundation Design - STAAD Foundation Advanced Error
Hello. Good day!
I was designing a mat foundation at STAAD Foundation Advanced and it cannot give a "PLOT Failure Diagram".
Further, it will give an error message saying "The bar arrangement provided corresponds to a steel area that is less than the minimum required steel area prescribed by the code. Hence, the calculated capacity is lower than the minimum capacity that the code requires." and "Unable to determine a rational value of flexure capacity for steel provided."
Punching Shear passed and the steel area required from the designed were solved and none failed.
What seems to be the problem?
Parents Reply Children
