When I change the ground level as detailed here: LINK How can I find the reactions of the imposed global lateral restraints?
Additionally, let's say that I want to eliminate the "overhang cantilever" affect that these global lateral restraints would have on a shearwall. Therefore, I want to disengage my shearwall from the diaphragm at the new ground level so that any forces from above are transmitted to the foundation. Is this possible? In my case I'm using a semi-rigid diaphragm.
Also inherit in this technique is the assumption that any forces on the new ground level would be resisted by the global lateral restraints. Therefore, I would still need to find these forces and verify that the diaphragm at that level can distribute them somewhere (i.e. exterior basement walls).
You can disconnect the nodes in Ram Frame if the diaphragm is rigid. If it's meshed (semi-rigid and/or 2-way) then you would actually have to make an opening.
Answer Verified By: RFreund
