Hi everyone,
i already know how to export member from staad.pro to Autocad 3D
but if it's possible that i can export 3D model with Size or property of member to Autocad.
if there're any programs or anyways to do. Please let me know
thanks
I think the best way to accomplish this task to use iTwin Analytical synchronizer. Using this tool you can create an .ism.dgn file. This file can be imported in AUTOCAD as a 3D object. Please try at your end and let me know if this helps.
The below video may help a bit. You may ignore the additional stuff for the time being .
https://www.youtube.com/watch?v=fKM1VS6bXuw
once you create the ism.dgn file, open an Autocad file and use IMPORT option to import the model.
it works. Size of member is arrived in the name of each member.
thanks sir !
