I have created generated and custom load combinations in RAM structural steel frame module. When I send the model to RAM Connection the generated load combinations and only the first custom load combination transfers in. I have the "use" box checked on all. How do I get all my custom load combinations into RAM Connection? Is there a way to edit load combinations within RAM Connection? (Not the stand alone version)
Thank you,
Brian
Which version of RAM SS you are using? Can you please upload the file for a quick check?
You can use this link to upload file if it is too big.
File Upload
You mentioned attaching a file above, but there were no files in the post thread or on our Sharefile site. Let's start by getting the file. You can use this link Share File - https://bentley.sharefile.com/r-r5dae662b0e684bc08861a8394a78f447 It would also be good to confirm your version of RAM SS and RAM Connection. The original issue about load combinations is usually because something changed and there was not a green light or up to date status for both Ram Frame Analysis and Ram Frame Steel design mode(s).
