RAM Concept - Program Error During Load History Deflection Calculation
While running Calc Partial through the Load History Deflection step, I receive the following popup error message which causes the load history calculation to terminate:
"Program Error (no deflection found for point inside slab in SpanSegment::deflectionAnalysis()) Contact support."
I'm using RAM Concept v8.04. Is this a known issue in this version? Or could there be something in the model causing this error?
The level is pretty complex and some areas are changing, so I'm only focusing on designing the PT for portions of the slabs and beams that are properly coordinated for now. I'm not sure if the unfinished areas are experiencing excessive deflection/rebar yielding and this is related to that or if there's another issue with the program. Please contact me if you need me to upload the current version of the model to try to duplicate the error.
Parents Reply Children
