How to add a reference load with a load factor to a load case using openSTAAD commands
I have the below code which interfaces with a matrix i have created in excell/VBA.
I want to create the loadcase, this code works, and then add the reference load say "R1" to the load case with a load factor as per the image below. The reference loads have already been created successfully. How can I achieve this?
'Define Load Cases
Dim RefLoadNo As Double
Dim RefLoadName As String
Dim RefLoadType As Long
Dim LoadCaseName As String
Dim LoadCaseType As Long
Dim LoadCaseNo As Double
Dim LoadFactor As Double
For j = 2 To UBound(Load_Matrix(), 2) 'i=2 at start as i=0 is the loacombination row and i=1 is loadcombination name row
LoadCaseName = Load_Matrix(1, j)
LoadCaseType = 22 ' Type "NONE"
LoadCaseNo = Load_Matrix(0, j)
ObjOPENSTAAD.Load.CreateNewPrimaryLoadEx2 LoadCaseName, LoadCaseType, LoadCaseNo ' in form LoadCaseName, LoadCaseType, LoadCaseNo
For i = 2 To UBound(Load_Matrix(), 1)
RefLoadNo = CDbl(RemoveFirstChars(CVar(Load_Matrix(i, 0)), 1))                   ' this results in a reference load case number of 1 rather than R1.
LoadFactor = Load_Matrix(i, j)
ObjOPENSTAAD.Load.AddLoadRefEx2 LoadCaseNo, RefLoadNo, LoadFactor ' in form LoadCase, Node, Factor
Next i
Next j
Best Regards,
Tom
Parents Reply
  • Yes, you need to use AddReferenceLoad function.
    I would like to mention one thing here that the datatype of the Primary or Reference Load case number should be Long instead of Double
    Sample VBA Syntax is
    Set objOpenSTAAD = GetObject(, "StaadPro.OpenSTAAD")
    Dim LoadCaseNo As Long
    Dim RefLoadNo(2) As Long
    Dim LoadFactor(2) As Double
    LoadCaseNo = 1
    objOpenSTAAD.Load.SetLoadActive LoadCaseNo
    RefLoadNo(0) = 2
    RefLoadNo(1) = 4
    RefLoadNo(2) = 5
    LoadFactor(0) = 1.2
    LoadFactor(1) = 1
    LoadFactor(2) = 0.9
    objOpenSTAAD.Load.AddReferenceLoad RefLoadNo, LoadFactor
    Answer Verified By: Tom Pallister
