I am analyzing this braced frame structure with the effective length method following this procedure https://communities.bentley.com/products/ram-staad/w/structural_analysis_and_design__wiki/55456/asce-7-aisc-360-and-the-effective-length-method-in-the-ram-structural-system
The drift report seems to indicate that my structure is extremely torsionally irregular. The stability coefficients report also shows that it exceeds the max allowable.
Before I begin adding new braced frames to my structure, is there a way to determine that the issues shown in the reports are accurate and not related to mistakes in modeling the structure?
Thanks Seth. Thanks for your suggestions and help.
This is Jane and I am John's coworker. We are working on the same project.
What is the difference in drift output and nodal displacement output in RAM structural? Is there a Wiki discussion or community discussion on difference between drift and nodal displacement?
Thanks again!
Does the drift include the diaphragm displacement? Does the nodal displacement include the diaphragm displacement?
Check the RamFrameAnalysis.pdf manual for detail on drift output, section 3.6.13 Drift. If the diaphragm is semi-rigid and you are using drift output, then yes the deflection of the diaphragm is included. If you are using nodal displacements and reporting for the nodes of the frames, then it's not.
Thanks Seth.
How to select "Include semirigid diaphragm node results" option for "Nodal displacements"? See below from "help". Thanks
