SHEAR FORCE DAIGRAM IS CHANGED IF WE CHANGE THE BEAM INCIDENCE
I MODEL A BEAM A BEAM OF 12 M SPAN IN WHICH THE SUPPORTS ARE ASSIGNED AT 8 M C/C AND REST 2.2 M FROM EITHER SIDE IS CANTILEVR , NOW IF I CHANGES THE BEAM INCIDENCE THE SHEAR FORCE DIAGRAM IS CHANGED (REVERSED) WHILE LOADING POINT IS SAME
Parents Reply Children
