Steel Design Capacities Are The Same For Different Steel Strengths
I have created a simply supported steel beam in the Physical Modeller (Connect Edition 22.11.00.156). I am designing the beam to the UK National Annex of Eurocode 3.
I have attached 2 different models, the first is a simply supported steel beam with the material specified as S275. On the second model, I have specified the material as S355.
When I change the material from S275 to S355, the Design Capacities do not change. See the screenshots below:
The program seems to be defaulting to S235, even though I specified in the Physical Modeller to use S275 and S355.
Unless I have done something wrong, there seems to be a bug where the program does not apply the correct material even though I have specified what to use in the physical modeller.
Thank-You for your help,
Ryan
S275.zip
S355.zip
Parents Reply Children
