ASSIGMENT-6.std
ON RUNNING THIS ERROR COME ,,PLEASE GIVE ME SOLUTION TO RESOLVE THIS , I HAVE TRY ALL THE METHOD GIVEN PREVIOUSLY
In your model you have used surface element. Seems like you are using some older V8i version. Please note support for V8i version is not available and we have deprecated all older V8i version. Please use STAAD.pro connect edition and plate elements instead of surface to get the file analyzed.
How can I convert surface elements to plate elements
