Why does STAAD Aluminum Design report fail to give any output in the "Clause" or "L/C" columns in the Utilization Ratio chart.
Please help!
Designing a simple truss using the Aluminum Code analysis. The initial analysis produced utilization ratios where the "Clause" references AISC's H1-3 Equation and H2-1 Equation. This led to revise my analysis commands so that it was analyzing for the aluminum code, not the steel codes. However, now that I have corrected for this, the "Clause" column and the "L/C" column are blank. I cannot tell what load case is being used and what code it is referencing. Now the client is asking about this. I have attached the reports and the file here.
  1. What am I doing wrong?
  2. How can I show the client that the correct code is being used to check the utilization ratios?
Files attached:
  1. STAAD FILE
  2. "STAAD Calc Report Sloped Awning 6ft Analysis 2D.STD" - old report that checks AISC codes
  3. "Sloped Awning 6ft Analysis 2D (revised) May 10 23.STD" - new report that does not show anything in the "Clause" and "L/C" columns.PDFSloped Awning 6ft Analysis 2D May 10 23.STDPDF
Parents Reply Children
