Attach the model please.
Also for the Info the concrete strength is 22.5 Mpa, I converted it to 22500 kN/m2 but in the model I provided to you I change to 22.5 BCS I try to see if it's gonna work
As the error says, RY, RT, FY and FU values are meant for the Steel properties in the material definition. So you need to delete these values in the input file from Concrete definitions.This model does not seem to be finished, as loadings, analysis command and material assignments are still missing in it.
Answer Verified By: Christanya Mewengkang
thank you so much for the help! yes, still missing it, I'm just trying to analyze the draft to see what's missing, before putting the loading and etc. Thank you once again! gonna catch up with you once the design and analysis are finished!
