Analysis terminates without any error message
I am using Staad Connect Edition V22 Update 12 to create a steel and RCC structure. But now I find that the analysis terminates without any error message.
Please help me understand the reason behind it. The STAAD file is attached below:
MASS SD.STD
  • Hello,
     This is a known issue and we have found a bug which affects few files in column design part with IS456 design code. Your model is one of them and hence program is unable to complete the run and terminating midway. One bug #995169 has been posted for the same and being fixed with priority. Sorry for the inconveniences caused to you and the fix will be available in next immediate build.
    As of now I can suggest you few workarounds.
    1. If you delete the column design command for IS456 code in the model, the same model can be run without any issue.
    2. You can create 2 separate files one for the steel part and one for the concrete part. You can use the reaction from steel structure as loads for the concrete model. Then if you run the 2 models separately they will work fine.
    3. If you want a complete design of the same file please use version 22 update 10 for the time being. In that version run will be completed including all column design without any issue.
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
Reply
  • Hello,
    Thanks & Regards,
    Abhisek Mandal
