I entered the RAM concept through RAM structural system (RAM ss).
I modeled a mat foundation in the RAM concept and saved it.
I re-opened the RAM concept model through RAM ss and the slab I draw yesterday disappear.
It seems like the mesh data is still on the model.
Why is the foundation layout disappeared? and what should I do to prevent this from happening?
If the option below is checked when launching RAM Concept from RAM Manager, RAM Structural System will re-import the mat foundation geometry and properties. If the mat foundation in RAM Modeler has been deleted or modified, then those changes will be transferred into RAM Concept. If the mat foundation was deleted, then the slab area that was previously saved in RAM Concept would be cleared and there would be nothing to mesh after the re-import process.
If you have made changes to the mat foundation in RAM Concept after importing and do not want to overwrite those changes when opening the file at a later date, you can uncheck the box for importing Slab Areas in the dialog below when opening the file.
Answer Verified By: Sooik Cho
Also note, objects can also just be hidden from any view using the Visible objects control (the "eyeball" tool).
Thank you for the answer!
