Inconsistent Results Output with Defined Group in Staad.Pro
Hello Bentley community,
I'm encountering an issue with Staad.Pro regarding the inconsistency between a defined group and the results output. I would greatly appreciate any insights or guidance you can provide to help me resolve this problem. Here are the details:
Issue Overview: When selecting a defined group in the results setup, the displayed results include elements that are not part of the defined group.
Steps Taken:
  1. Created a group called "GA" consisting of nodes/members 3 to 5.
  2. In the post-processing mode, selected the load case and chose the range tag.
  3. Selected the group option and specified "GA" as the desired group for results output.
  4. Upon reviewing the results, I found that nodes/members 3, 8, and 9 are included instead of just nodes/members 3 to 5.
Additional Information:
  • I have double-checked the group definition to ensure that only nodes/members 3 to 5 are included, and there are no accidental inclusions or exclusions.
  • I have verified that the correct load case is assigned and considered in the analysis.
  • I have reviewed the post-processing options and filters to ensure that there are no settings affecting the visibility or display of the group results.
  • I am using Staad.Pro CONNECT Edition v22.01, and I have not encountered this issue in previous versions.
I would appreciate any insights, suggestions, or solutions to help resolve this inconsistency between the defined group and the results output in Staad.Pro. If anyone has encountered a similar issue or can offer guidance on how to address it, your input would be highly valuable.
Thank you in advance for your assistance!
Best regards,
  • It sounds like an issue which existed (or still exists) in STAAD.Pro CE. Could you please attach that model to try it at my end?
    Answer Verified By: Antonia Cobo Ibanez
  • Thank you for your response. Here is the code:
    MEMORY 375
    STAAD SPACE
    START JOB INFORMATION
    ENGINEER DATE 02-May-23
    END JOB INFORMATION
    INPUT WIDTH 79
    SET NL 50
    UNIT METER MTON
    JOINT COORDINATES
    1 0 0 0; 2 8.00002 0 0; 3 0 0 29.3001; 4 8.00002 0 29.3001; 5 0 3.00001 0;
    6 8.00002 3.00001 0; 7 0 3.00001 29.3001; 8 8.00002 3.00001 29.3001;
    9 0 3.00001 0.395947; 10 0 2.5 0.395947; 11 0 2.5 0; 12 0 3.00001 0.791893;
    13 0 2.50001 0.791893; 14 0 3.00001 1.18784; 15 0 2.5 1.18784;
    16 0 3.00001 1.58379; 17 0 2.50001 1.58379; 18 0 3.00001 1.97973;
    19 0 2.5 1.97973; 20 0 3.00001 2.37568; 21 0 2.5 2.37568; 22 0 3.00001 2.77163;
    23 0 2.5 2.77163; 24 0 3.00001 3.16757; 25 0 2.5 3.16757; 26 0 3.00001 3.56352;
    27 0 2.5 3.56352; 28 0 3.00001 3.95947; 29 0 2.5 3.95947; 30 0 3.00001 4.35541;
    31 0 2.5 4.35541; 32 0 3.00001 4.75136; 33 0 2.50001 4.75136;
    34 0 3.00001 5.14731; 35 0 2.5 5.14731; 36 0 3.00001 5.54325;
    37 0 2.50001 5.54325; 38 0 3.00001 5.9392; 39 0 2.50001 5.9392;
    40 0 3.00001 6.33515; 41 0 2.50001 6.33515; 42 0 3.00001 6.73109;
    43 0 2.5 6.7311; 44 0 3.00001 7.12704; 45 0 2.5 7.12704; 46 0 3.00001 7.52299;
    47 0 2.5 7.52299; 48 0 3.00001 7.91894; 49 0 2.5 7.91893; 50 0 3.00001 8.31488;
    51 0 2.5 8.31488; 52 0 3.00001 8.71083; 53 0 2.5 8.71083; 54 0 3.00001 9.10677;
    55 0 2.50001 9.10677; 56 0 3.00001 9.50272; 57 0 2.5 9.50272;
    58 0 3.00001 9.89867; 59 0 2.5 9.89867; 60 0 3.00001 10.2946; 61 0 2.5 10.2946;
    62 0 3.00001 10.6906; 63 0 2.5 10.6906; 64 0 3.00001 11.0865; 65 0 2.5 11.0865;
    66 0 3.00001 11.4825; 67 0 2.50001 11.4825; 68 0 3.00001 11.8784;
    69 0 2.5 11.8784; 70 0 3.00001 12.2743; 71 0 2.5 12.2743; 72 0 3.00001 12.6703;
    73 0 2.5 12.6703; 74 0 3.00001 13.0662; 75 0 2.5 13.0662; 76 0 3.00001 13.4622;
    77 0 2.5 13.4622; 78 0 3.00001 13.8581; 79 0 2.5 13.8581; 80 0 3.00001 14.2541;
    81 0 2.5 14.2541; 82 0 3.00001 14.65; 83 0 2.5 14.65; 84 0 3.00001 15.046;
    85 0 2.5 15.046; 86 0 3.00001 15.4419; 87 0 2.5 15.4419; 88 0 3.00001 15.8379;
    89 0 2.5 15.8379; 90 0 3.00001 16.2338; 91 0 2.5 16.2338; 92 0 3.00001 16.6298;
    93 0 2.5 16.6298; 94 0 3.00001 17.0257; 95 0 2.5 17.0257; 96 0 3.00001 17.4217;
    97 0 2.5 17.4217; 98 0 3.00001 17.8176; 99 0 2.5 17.8176;
    100 0 3.00001 18.2135; 101 0 2.5 18.2135; 102 0 3.00001 18.6095;
    103 0 2.5 18.6095; 104 0 3.00001 19.0054; 105 0 2.5 19.0054;
    106 0 3.00001 19.4014; 107 0 2.5 19.4014; 108 0 3.00001 19.7973;
    109 0 2.5 19.7973; 110 0 3.00001 20.1933; 111 0 2.5 20.1933;
    112 0 3.00001 20.5892; 113 0 2.5 20.5892; 114 0 3.00001 20.9852;
    115 0 2.5 20.9852; 116 0 3.00001 21.3811; 117 0 2.5 21.3811;
    118 0 3.00001 21.7771; 119 0 2.5 21.7771; 120 0 3.00001 22.173;
    121 0 2.5 22.173; 122 0 3.00001 22.569; 123 0 2.5 22.569;
    124 0 3.00001 22.9649; 125 0 2.5 22.9649; 126 0 3.00001 23.3609;
    127 0 2.5 23.3609; 128 0 3.00001 23.7568; 129 0 2.5 23.7568;
    130 0 3.00001 24.1528; 131 0 2.5 24.1528; 132 0 3.00001 24.5487;
    133 0 2.5 24.5487; 134 0 3.00001 24.9446; 135 0 2.5 24.9446;
    136 0 3.00001 25.3406; 137 0 2.5 25.3406; 138 0 3.00001 25.7365;
    139 0 2.5 25.7365; 140 0 3.00001 26.1325; 141 0 2.5 26.1325;
    142 0 3.00001 26.5284; 143 0 2.5 26.5284; 144 0 3.00001 26.9244;
    145 0 2.5 26.9244; 146 0 3.00001 27.3203; 147 0 2.5 27.3203;
    148 0 3.00001 27.7163; 149 0 2.5 27.7163; 150 0 3.00001 28.1122;
    151 0 2.5 28.1122; 152 0 3.00001 28.5082; 153 0 2.5 28.5082;
    154 0 3.00001 28.9041; 155 0 2.5 28.9041; 156 0 2.5 29.3001; 157 0 2 0.395947;
    158 0 2 0; 159 0 2 0.791893; 160 0 2 1.18784; 161 0 2 1.58379; 162 0 2 1.97973;
    163 0 2 2.37568; 164 0 2 2.77163; 165 0 2 3.16757; 166 0 2 3.56352;
    167 0 2 3.95947; 168 0 2 4.35541; 169 0 2 4.75136; 170 0 2 5.14731;
    171 0 2 5.54325; 172 0 2 5.9392; 173 0 2 6.33515; 174 0 2 6.7311;
    175 0 2 7.12704; 176 0 2 7.52299; 177 0 2 7.91894; 178 0 2 8.31488;
    179 0 2 8.71083; 180 0 2 9.10678; 181 0 2 9.50272; 182 0 2 9.89867;
    183 0 2 10.2946; 184 0 2 10.6906; 185 0 2 11.0865; 186 0 2 11.4825;
    187 0 2 11.8784; 188 0 2 12.2743; 189 0 2 12.6703; 190 0 2 13.0662;
    191 0 2 13.4622; 192 0 2 13.8581; 193 0 2 14.2541; 194 0 2 14.65;
    195 0 2 15.046; 196 0 2 15.4419; 197 0 2 15.8379; 198 0 2 16.2338;
    199 0 2 16.6298; 200 0 2 17.0257; 201 0 2 17.4217; 202 0 2 17.8176;
    203 0 2 18.2135; 204 0 2 18.6095; 205 0 2 19.0054; 206 0 2 19.4014;
    207 0 2 19.7973; 208 0 2 20.1933; 209 0 2 20.5892; 210 0 2 20.9852;
    211 0 2 21.3811; 212 0 2 21.7771; 213 0 2 22.173; 214 0 2 22.569;
    215 0 2 22.9649; 216 0 2 23.3609; 217 0 2 23.7568; 218 0 2 24.1528;
    219 0 2 24.5487; 220 0 2 24.9446; 221 0 2 25.3406; 222 0 2 25.7365;
    223 0 2 26.1325; 224 0 2 26.5284; 225 0 2 26.9244; 226 0 2 27.3203;
    227 0 2 27.7163; 228 0 2 28.1122; 229 0 2 28.5082; 230 0 2 28.9041;
    231 0 2 29.3001; 232 0 1.5 0.395947; 233 0 1.5 0; 234 0 1.5 0.791893;
    235 0 1.5 1.18784; 236 0 1.5 1.58379; 237 0 1.5 1.97973; 238 0 1.5 2.37568;
    239 0 1.5 2.77163; 240 0 1.5 3.16757; 241 0 1.5 3.56352; 242 0 1.5 3.95947;
    243 0 1.5 4.35541; 244 0 1.5 4.75136; 245 0 1.5 5.14731; 246 0 1.5 5.54325;
    247 0 1.5 5.9392; 248 0 1.5 6.33515; 249 0 1.5 6.7311; 250 0 1.5 7.12704;
    251 0 1.5 7.52299; 252 0 1.5 7.91894; 253 0 1.5 8.31488; 254 0 1.5 8.71083;
    255 0 1.5 9.10678; 256 0 1.5 9.50272; 257 0 1.5 9.89867; 258 0 1.5 10.2946;
    259 0 1.5 10.6906; 260 0 1.5 11.0865; 261 0 1.5 11.4825; 262 0 1.5 11.8784;
    263 0 1.5 12.2744; 264 0 1.5 12.6703; 265 0 1.5 13.0662; 266 0 1.5 13.4622;
    267 0 1.5 13.8581; 268 0 1.5 14.2541; 269 0 1.5 14.65; 270 0 1.5 15.046;
    271 0 1.5 15.4419; 272 0 1.5 15.8379; 273 0 1.5 16.2338; 274 0 1.5 16.6298;
    275 0 1.5 17.0257; 276 0 1.5 17.4217; 277 0 1.5 17.8176; 278 0 1.5 18.2136;
    279 0 1.5 18.6095; 280 0 1.5 19.0054; 281 0 1.5 19.4014; 282 0 1.5 19.7973;
    283 0 1.5 20.1933; 284 0 1.5 20.5892; 285 0 1.5 20.9852; 286 0 1.5 21.3811;
    287 0 1.5 21.7771; 288 0 1.5 22.173; 289 0 1.5 22.569; 290 0 1.5 22.9649;
    291 0 1.5 23.3609; 292 0 1.5 23.7568; 293 0 1.5 24.1528; 294 0 1.5 24.5487;
    295 0 1.5 24.9446; 296 0 1.5 25.3406; 297 0 1.5 25.7365; 298 0 1.5 26.1325;
    299 0 1.5 26.5284; 300 0 1.5 26.9244; 301 0 1.5 27.3203; 302 0 1.5 27.7163;
    303 0 1.5 28.1122; 304 0 1.5 28.5082; 305 0 1.5 28.9041; 306 0 1.5 29.3001;
    307 0 1 0.395947; 308 0 1 0; 309 0 1 0.791893; 310 0 1 1.18784;
    311 0 1 1.58379; 312 0 1 1.97973; 313 0 1 2.37568; 314 0 1 2.77163;
    315 0 1 3.16757; 316 0 1 3.56352; 317 0 1 3.95947; 318 0 1 4.35541;
    319 0 1 4.75136; 320 0 1 5.14731; 321 0 1 5.54325; 322 0 1 5.9392;
    323 0 1 6.33515; 324 0 1 6.7311; 325 0 1 7.12704; 326 0 1 7.52299;
    327 0 1 7.91894; 328 0 1 8.31488; 329 0 1 8.71083; 330 0 1 9.10678;
    331 0 1 9.50272; 332 0 1 9.89867; 333 0 1 10.2946; 334 0 1 10.6906;
    335 0 1 11.0865; 336 0 1 11.4825; 337 0 1 11.8784; 338 0 1 12.2744;
    339 0 1 12.6703; 340 0 1 13.0662; 341 0 1 13.4622; 342 0 1 13.8581;
    343 0 1 14.2541; 344 0 1 14.65; 345 0 1 15.046; 346 0 1 15.4419;
    347 0 1 15.8379; 348 0 1 16.2338; 349 0 1 16.6298; 350 0 1 17.0257;
    351 0 1 17.4217; 352 0 1 17.8176; 353 0 1 18.2136; 354 0 1 18.6095;
    355 0 1 19.0054; 356 0 1 19.4014; 357 0 1 19.7973; 358 0 1 20.1933;
    359 0 1 20.5892; 360 0 1 20.9852; 361 0 1 21.3811; 362 0 1 21.7771;
    363 0 1 22.173; 364 0 1 22.569; 365 0 1 22.9649; 366 0 1 23.3609;
    367 0 1 23.7568; 368 0 1 24.1528; 369 0 1 24.5487; 370 0 1 24.9446;
    371 0 1 25.3406; 372 0 1 25.7365; 373 0 1 26.1325; 374 0 1 26.5284;
    375 0 1 26.9244; 376 0 1 27.3203; 377 0 1 27.7163; 378 0 1 28.1122;
    379 0 1 28.5082; 380 0 1 28.9041; 381 0 1 29.3001; 382 0 0.500001 0.395947;
    383 0 0.500001 0; 384 0 0.500001 0.791893; 385 0 0.500001 1.18784;
    386 0 0.500001 1.58379; 387 0 0.500001 1.97973; 388 0 0.500001 2.37568;
    389 0 0.500001 2.77163; 390 0 0.500001 3.16757; 391 0 0.500001 3.56352;
    392 0 0.500001 3.95947; 393 0 0.500001 4.35541; 394 0 0.500001 4.75136;
    395 0 0.500001 5.14731; 396 0 0.500001 5.54325; 397 0 0.500001 5.9392;
    398 0 0.500001 6.33515; 399 0 0.500001 6.7311; 400 0 0.500001 7.12704;
    401 0 0.500001 7.52299; 402 0 0.500001 7.91894; 403 0 0.500001 8.31488;
    404 0 0.500001 8.71083; 405 0 0.500001 9.10678; 406 0 0.500001 9.50273;
    407 0 0.500001 9.89867; 408 0 0.500001 10.2946; 409 0 0.500001 10.6906;
    410 0 0.500001 11.0865; 411 0 0.500001 11.4825; 412 0 0.500001 11.8784;
    413 0 0.500001 12.2744; 414 0 0.500001 12.6703; 415 0 0.500001 13.0662;
    416 0 0.500001 13.4622; 417 0 0.500001 13.8581; 418 0 0.500001 14.2541;
    419 0 0.500001 14.65; 420 0 0.500001 15.046; 421 0 0.500001 15.4419;
    422 0 0.500001 15.8379; 423 0 0.500001 16.2338; 424 0 0.500001 16.6298;
    425 0 0.500001 17.0257; 426 0 0.500001 17.4217; 427 0 0.500001 17.8176;
    428 0 0.500001 18.2136; 429 0 0.500001 18.6095; 430 0 0.500001 19.0054;
    431 0 0.500001 19.4014; 432 0 0.500001 19.7973; 433 0 0.500001 20.1933;
    434 0 0.500001 20.5892; 435 0 0.500001 20.9852; 436 0 0.500001 21.3811;
    437 0 0.500001 21.7771; 438 0 0.500001 22.173; 439 0 0.500001 22.569;
    440 0 0.500001 22.9649; 441 0 0.500001 23.3609; 442 0 0.500001 23.7568;
    443 0 0.500001 24.1528; 444 0 0.500001 24.5487; 445 0 0.500001 24.9446;
    446 0 0.500001 25.3406; 447 0 0.500001 25.7365; 448 0 0.500001 26.1325;
    449 0 0.500001 26.5284; 450 0 0.500001 26.9244; 451 0 0.500001 27.3203;
    452 0 0.500001 27.7163; 453 0 0.500001 28.1122; 454 0 0.500001 28.5082;
    455 0 0.500001 28.9041; 456 0 0.500001 29.3001; 457 0 0 0.395947;
    458 0 0 0.791893; 459 0 0 1.18784; 460 0 0 1.58379; 461 0 0 1.97973;
    462 0 0 2.37568; 463 0 0 2.77163; 464 0 0 3.16757; 465 0 0 3.56352;
    466 0 0 3.95947; 467 0 0 4.35541; 468 0 0 4.75136; 469 0 0 5.14731;
    470 0 0 5.54325; 471 0 0 5.9392; 472 0 0 6.33515; 473 0 0 6.7311;
    474 0 0 7.12704; 475 0 0 7.52299; 476 0 0 7.91894; 477 0 0 8.31488;
    478 0 0 8.71083; 479 0 0 9.10678; 480 0 0 9.50272; 481 0 0 9.89867;
    482 0 0 10.2946; 483 0 0 10.6906; 484 0 0 11.0865; 485 0 0 11.4825;
    486 0 0 11.8784; 487 0 0 12.2744; 488 0 0 12.6703; 489 0 0 13.0662;
    490 0 0 13.4622; 491 0 0 13.8581; 492 0 0 14.2541; 493 0 0 14.65;
    494 0 0 15.046; 495 0 0 15.4419; 496 0 0 15.8379; 497 0 0 16.2338;
    498 0 0 16.6298; 499 0 0 17.0257; 500 0 0 17.4217; 501 0 0 17.8176;
    502 0 0 18.2136; 503 0 0 18.6095; 504 0 0 19.0054; 505 0 0 19.4014;
    506 0 0 19.7973; 507 0 0 20.1933; 508 0 0 20.5892; 509 0 0 20.9852;
    510 0 0 21.3811; 511 0 0 21.7771; 512 0 0 22.173; 513 0 0 22.569;
    514 0 0 22.9649; 515 0 0 23.3609; 516 0 0 23.7568; 517 0 0 24.1528;
    518 0 0 24.5487; 519 0 0 24.9446; 520 0 0 25.3406; 521 0 0 25.7365;
    522 0 0 26.1325; 523 0 0 26.5284; 524 0 0 26.9244; 525 0 0 27.3203;
    526 0 0 27.7163; 527 0 0 28.1122; 528 0 0 28.5082; 529 0 0 28.9041;
    530 8.00002 3.00001 28.9041; 531 8.00002 2.5 28.9041; 532 8.00002 2.5 29.3001;
    533 8.00002 3.00001 28.5082; 534 8.00002 2.50001 28.5082;
    535 8.00002 3.00001 28.1122; 536 8.00002 2.5 28.1122;
    537 8.00002 3.00001 27.7163; 538 8.00002 2.50001 27.7163;
    539 8.00002 3.00001 27.3203; 540 8.00002 2.5 27.3203;
    541 8.00002 3.00001 26.9244; 542 8.00002 2.5 26.9244;
    543 8.00002 3.00001 26.5284; 544 8.00002 2.5 26.5284;
    545 8.00002 3.00001 26.1325; 546 8.00002 2.5 26.1325;
    547 8.00002 3.00001 25.7365; 548 8.00002 2.5 25.7365;
    549 8.00002 3.00001 25.3406; 550 8.00001 2.5 25.3406;
    551 8.00002 3.00001 24.9446; 552 8.00002 2.5 24.9446;
    553 8.00002 3.00001 24.5487; 554 8.00002 2.50001 24.5487;
    555 8.00002 3.00001 24.1528; 556 8.00002 2.5 24.1528;
    557 8.00002 3.00001 23.7568; 558 8.00002 2.50001 23.7568;
    559 8.00002 3.00001 23.3609; 560 8.00002 2.50001 23.3609;
    561 8.00002 3.00001 22.9649; 562 8.00002 2.50001 22.9649;
    563 8.00002 3.00001 22.569; 564 8.00002 2.5 22.569; 565 8.00002 3.00001 22.173;
    566 8.00002 2.5 22.173; 567 8.00002 3.00001 21.7771; 568 8.00001 2.5 21.7771;
    569 8.00002 3.00001 21.3811; 570 8.00002 2.5 21.3811;
    571 8.00002 3.00001 20.9852; 572 8.00002 2.5 20.9852;
    573 8.00002 3.00001 20.5892; 574 8.00002 2.5 20.5892;
    575 8.00002 3.00001 20.1933; 576 8.00002 2.50001 20.1933;
    577 8.00002 3.00001 19.7973; 578 8.00002 2.5 19.7973;
    579 8.00002 3.00001 19.4014; 580 8.00002 2.5 19.4014;
    581 8.00002 3.00001 19.0054; 582 8.00002 2.5 19.0054;
    583 8.00002 3.00001 18.6095; 584 8.00002 2.5 18.6095;
    585 8.00002 3.00001 18.2136; 586 8.00002 2.5 18.2136;
    587 8.00002 3.00001 17.8176; 588 8.00002 2.50001 17.8176;
    589 8.00002 3.00001 17.4217; 590 8.00002 2.5 17.4217;
    591 8.00002 3.00001 17.0257; 592 8.00002 2.5 17.0257;
    593 8.00002 3.00001 16.6298; 594 8.00002 2.5 16.6298;
    595 8.00002 3.00001 16.2338; 596 8.00002 2.5 16.2338;
    597 8.00002 3.00001 15.8379; 598 8.00002 2.5 15.8379;
    599 8.00002 3.00001 15.4419; 600 8.00002 2.5 15.4419;
    601 8.00002 3.00001 15.046; 602 8.00002 2.5 15.046; 603 8.00002 3.00001 14.65;
    604 8.00002 2.5 14.65; 605 8.00002 3.00001 14.2541; 606 8.00002 2.5 14.2541;
    607 8.00002 3.00001 13.8581; 608 8.00002 2.5 13.8581;
    609 8.00002 3.00001 13.4622; 610 8.00002 2.5 13.4622;
    611 8.00002 3.00001 13.0662; 612 8.00002 2.5 13.0662;
    613 8.00002 3.00001 12.6703; 614 8.00002 2.5 12.6703;
    615 8.00002 3.00001 12.2743; 616 8.00002 2.5 12.2743;
    617 8.00002 3.00001 11.8784; 618 8.00002 2.5 11.8784;
    619 8.00002 3.00001 11.4825; 620 8.00002 2.5 11.4825;
    621 8.00002 3.00001 11.0865; 622 8.00002 2.5 11.0865;
    623 8.00002 3.00001 10.6906; 624 8.00002 2.5 10.6906;
    625 8.00002 3.00001 10.2946; 626 8.00002 2.5 10.2946;
    627 8.00002 3.00001 9.89867; 628 8.00002 2.5 9.89867;
    629 8.00002 3.00001 9.50272; 630 8.00002 2.5 9.50272;
    631 8.00002 3.00001 9.10678; 632 8.00002 2.5 9.10678;
    633 8.00002 3.00001 8.71083; 634 8.00002 2.5 8.71083;
    635 8.00002 3.00001 8.31488; 636 8.00002 2.5 8.31488;
    637 8.00002 3.00001 7.91893; 638 8.00002 2.5 7.91893;
    639 8.00002 3.00001 7.52299; 640 8.00002 2.5 7.52299;
    641 8.00002 3.00001 7.12704; 642 8.00002 2.5 7.12704;
    643 8.00002 3.00001 6.73109; 644 8.00002 2.5 6.73109;
    645 8.00002 3.00001 6.33515; 646 8.00002 2.5 6.33515;
    647 8.00002 3.00001 5.9392; 648 8.00002 2.5 5.9392;
    649 8.00002 3.00001 5.54325; 650 8.00002 2.5 5.54325;
    651 8.00002 3.00001 5.14731; 652 8.00002 2.5 5.14731;
    653 8.00002 3.00001 4.75136; 654 8.00002 2.5 4.75136;
    655 8.00002 3.00001 4.35541; 656 8.00002 2.5 4.35541;
    657 8.00002 3.00001 3.95947; 658 8.00002 2.5 3.95947;
    659 8.00002 3.00001 3.56352; 660 8.00002 2.5 3.56352;
    661 8.00002 3.00001 3.16757; 662 8.00002 2.5 3.16757;
    663 8.00002 3.00001 2.77163; 664 8.00002 2.5 2.77163;
    665 8.00002 3.00001 2.37568; 666 8.00002 2.5 2.37568;
    667 8.00002 3.00001 1.97973; 668 8.00002 2.5 1.97973;
    669 8.00002 3.00001 1.58379; 670 8.00002 2.5 1.58379;
    671 8.00002 3.00001 1.18784; 672 8.00002 2.5 1.18784;
    673 8.00002 3.00001 0.791893; 674 8.00002 2.5 0.791893;
    675 8.00002 3.00001 0.395947; 676 8.00002 2.5 0.395947; 677 8.00002 2.5 0;
    678 8.00002 2 28.9041; 679 8.00002 2 29.3001; 680 8.00002 2 28.5082;
    681 8.00002 2 28.1122; 682 8.00002 2 27.7163; 683 8.00002 2 27.3203;
    684 8.00002 2 26.9244; 685 8.00002 2 26.5284; 686 8.00002 2 26.1325;
    687 8.00002 2 25.7365; 688 8.00002 2 25.3406; 689 8.00002 2 24.9446;
    690 8.00002 2 24.5487; 691 8.00002 2 24.1528; 692 8.00002 2 23.7568;
    693 8.00002 2 23.3609; 694 8.00002 2 22.9649; 695 8.00002 2 22.569;
    696 8.00002 2 22.173; 697 8.00001 2 21.7771; 698 8.00002 2 21.3811;
    699 8.00002 2 20.9852; 700 8.00002 2 20.5892; 701 8.00002 2 20.1933;
    702 8.00002 2 19.7973; 703 8.00002 2 19.4014; 704 8.00002 2 19.0054;
    705 8.00002 2 18.6095; 706 8.00002 2 18.2136; 707 8.00002 2 17.8176;
    708 8.00002 2 17.4217; 709 8.00002 2 17.0257; 710 8.00002 2 16.6298;
    711 8.00002 2 16.2338; 712 8.00002 2 15.8379; 713 8.00002 2 15.4419;
    714 8.00002 2 15.046; 715 8.00002 2 14.65; 716 8.00002 2 14.2541;
    717 8.00002 2 13.8581; 718 8.00002 2 13.4622; 719 8.00002 2 13.0662;
    720 8.00002 2 12.6703; 721 8.00002 2 12.2743; 722 8.00002 2 11.8784;
    723 8.00002 2 11.4825; 724 8.00002 2 11.0865; 725 8.00002 2 10.6906;
    726 8.00002 2 10.2946; 727 8.00002 2 9.89867; 728 8.00002 2 9.50272;
    729 8.00002 2 9.10678; 730 8.00002 2 8.71083; 731 8.00002 2 8.31488;
    732 8.00002 2 7.91893; 733 8.00002 2 7.52299; 734 8.00002 2 7.12704;
    735 8.00002 2 6.73109; 736 8.00002 2 6.33515; 737 8.00002 2 5.9392;
    738 8.00002 2 5.54325; 739 8.00002 2 5.14731; 740 8.00002 2 4.75136;
    741 8.00002 2 4.35541; 742 8.00002 2 3.95947; 743 8.00002 2 3.56352;
    744 8.00002 2 3.16757; 745 8.00002 2 2.77163; 746 8.00002 2 2.37568;
    747 8.00002 2 1.97973; 748 8.00002 2 1.58379; 749 8.00002 2 1.18784;
    750 8.00002 2 0.791893; 751 8.00002 2 0.395947; 752 8.00002 2 0;
    753 8.00002 1.5 28.9041; 754 8.00002 1.5 29.3001; 755 8.00002 1.5 28.5082;
    756 8.00002 1.5 28.1122; 757 8.00002 1.5 27.7163; 758 8.00002 1.5 27.3203;
    759 8.00002 1.5 26.9244; 760 8.00002 1.5 26.5284; 761 8.00002 1.5 26.1325;
    762 8.00002 1.5 25.7365; 763 8.00002 1.5 25.3406; 764 8.00002 1.5 24.9446;
    765 8.00002 1.5 24.5487; 766 8.00002 1.5 24.1527; 767 8.00002 1.5 23.7568;
    768 8.00002 1.5 23.3609; 769 8.00002 1.5 22.9649; 770 8.00002 1.5 22.569;
    771 8.00002 1.5 22.173; 772 8.00002 1.5 21.7771; 773 8.00002 1.5 21.3811;
    774 8.00002 1.5 20.9852; 775 8.00002 1.5 20.5892; 776 8.00002 1.5 20.1933;
    777 8.00002 1.5 19.7973; 778 8.00002 1.5 19.4014; 779 8.00002 1.5 19.0054;
    780 8.00002 1.5 18.6095; 781 8.00002 1.5 18.2136; 782 8.00002 1.5 17.8176;
    783 8.00002 1.5 17.4217; 784 8.00002 1.5 17.0257; 785 8.00002 1.5 16.6298;
    786 8.00002 1.5 16.2338; 787 8.00002 1.5 15.8379; 788 8.00002 1.5 15.4419;
    789 8.00002 1.5 15.046; 790 8.00002 1.5 14.65; 791 8.00002 1.5 14.2541;
    792 8.00002 1.5 13.8581; 793 8.00002 1.5 13.4622; 794 8.00002 1.5 13.0662;
    795 8.00002 1.5 12.6703; 796 8.00002 1.5 12.2743; 797 8.00002 1.5 11.8784;
    798 8.00002 1.5 11.4825; 799 8.00002 1.5 11.0865; 800 8.00002 1.5 10.6906;
    801 8.00002 1.5 10.2946; 802 8.00002 1.5 9.89867; 803 8.00002 1.5 9.50272;
    804 8.00002 1.5 9.10678; 805 8.00002 1.5 8.71083; 806 8.00002 1.5 8.31488;
    807 8.00002 1.5 7.91893; 808 8.00002 1.5 7.52299; 809 8.00002 1.5 7.12704;
    810 8.00002 1.5 6.73109; 811 8.00002 1.5 6.33515; 812 8.00002 1.5 5.9392;
    813 8.00002 1.5 5.54325; 814 8.00002 1.5 5.14731; 815 8.00002 1.5 4.75136;
    816 8.00002 1.5 4.35541; 817 8.00002 1.5 3.95947; 818 8.00002 1.5 3.56352;
    819 8.00002 1.5 3.16757; 820 8.00002 1.5 2.77163; 821 8.00002 1.5 2.37568;
    822 8.00002 1.5 1.97973; 823 8.00002 1.5 1.58379; 824 8.00002 1.5 1.18784;
    825 8.00002 1.5 0.791893; 826 8.00002 1.5 0.395947; 827 8.00002 1.5 0;
    828 8.00002 1 28.9041; 829 8.00002 1 29.3001; 830 8.00002 1 28.5082;
    831 8.00002 1 28.1122; 832 8.00002 1 27.7163; 833 8.00002 1 27.3203;
    834 8.00002 1 26.9244; 835 8.00002 1 26.5284; 836 8.00002 1 26.1325;
    837 8.00002 1 25.7365; 838 8.00002 1 25.3406; 839 8.00002 1 24.9446;
    840 8.00002 1 24.5487; 841 8.00002 1 24.1527; 842 8.00002 1 23.7568;
    843 8.00002 1 23.3609; 844 8.00002 1 22.9649; 845 8.00002 1 22.569;
    846 8.00002 1 22.173; 847 8.00002 1 21.7771; 848 8.00002 1 21.3811;
    849 8.00002 1 20.9852; 850 8.00002 1 20.5892; 851 8.00002 1 20.1933;
    852 8.00002 1 19.7973; 853 8.00002 1 19.4014; 854 8.00002 1 19.0054;
    855 8.00002 1 18.6095; 856 8.00002 1 18.2136; 857 8.00002 1 17.8176;
    858 8.00002 1 17.4217; 859 8.00002 1 17.0257; 860 8.00002 1 16.6298;
    861 8.00002 1 16.2338; 862 8.00002 1 15.8379; 863 8.00002 1 15.4419;
    864 8.00002 1 15.046; 865 8.00002 1 14.65; 866 8.00002 1 14.2541;
    867 8.00002 1 13.8581; 868 8.00002 1 13.4622; 869 8.00002 1 13.0662;
    870 8.00002 1 12.6703; 871 8.00002 1 12.2743; 872 8.00002 1 11.8784;
    873 8.00002 1 11.4825; 874 8.00002 1 11.0865; 875 8.00002 1 10.6906;
    876 8.00002 1 10.2946; 877 8.00002 1 9.89867; 878 8.00002 1 9.50272;
    879 8.00002 1 9.10678; 880 8.00002 1 8.71083; 881 8.00002 1 8.31488;
    882 8.00002 1 7.91893; 883 8.00002 1 7.52299; 884 8.00002 1 7.12704;
    885 8.00002 1 6.73109; 886 8.00002 1 6.33515; 887 8.00002 1 5.9392;
    888 8.00002 1 5.54325; 889 8.00002 1 5.14731; 890 8.00002 1 4.75136;
    891 8.00002 1 4.35541; 892 8.00002 1 3.95947; 893 8.00002 1 3.56352;
    894 8.00002 1 3.16757; 895 8.00002 1 2.77163; 896 8.00002 1 2.37568;
    897 8.00002 1 1.97973; 898 8.00002 1 1.58379; 899 8.00002 1 1.18784;
    900 8.00002 1 0.791893; 901 8.00002 1 0.395947; 902 8.00002 1 0;
    903 8.00002 0.500001 28.9041; 904 8.00002 0.500001 29.3001;
    905 8.00002 0.500001 28.5082; 906 8.00002 0.500001 28.1122;
    907 8.00002 0.500001 27.7163; 908 8.00002 0.500001 27.3203;
    909 8.00002 0.500001 26.9244; 910 8.00002 0.500001 26.5284;
    911 8.00002 0.500001 26.1325; 912 8.00002 0.500001 25.7365;
    913 8.00002 0.500001 25.3406; 914 8.00002 0.500001 24.9446;
    915 8.00002 0.500001 24.5487; 916 8.00002 0.500001 24.1528;
    917 8.00002 0.500001 23.7568; 918 8.00002 0.500001 23.3609;
    919 8.00002 0.500001 22.9649; 920 8.00002 0.500001 22.569;
    921 8.00002 0.500001 22.173; 922 8.00002 0.500001 21.7771;
    923 8.00002 0.500001 21.3811; 924 8.00002 0.500001 20.9852;
    925 8.00002 0.500001 20.5892; 926 8.00002 0.500001 20.1933;
    927 8.00002 0.500001 19.7973; 928 8.00002 0.500001 19.4014;
    929 8.00002 0.500001 19.0054; 930 8.00002 0.500001 18.6095;
    931 8.00002 0.500001 18.2136; 932 8.00002 0.500001 17.8176;
    933 8.00002 0.500001 17.4217; 934 8.00002 0.500001 17.0257;
    935 8.00002 0.500001 16.6298; 936 8.00002 0.500001 16.2338;
    937 8.00002 0.500001 15.8379; 938 8.00002 0.500001 15.4419;
    939 8.00002 0.500001 15.046; 940 8.00002 0.500001 14.65;
    941 8.00002 0.500001 14.2541; 942 8.00002 0.500001 13.8581;
    943 8.00002 0.500001 13.4622; 944 8.00002 0.500001 13.0662;
    945 8.00002 0.500001 12.6703; 946 8.00002 0.500001 12.2744;
    947 8.00002 0.500001 11.8784; 948 8.00002 0.500001 11.4825;
    949 8.00002 0.500001 11.0865; 950 8.00002 0.500001 10.6906;
    951 8.00002 0.500001 10.2946; 952 8.00002 0.500001 9.89867;
    953 8.00002 0.500001 9.50272; 954 8.00002 0.500001 9.10678;
    955 8.00002 0.500001 8.71083; 956 8.00002 0.500001 8.31488;
    957 8.00002 0.500001 7.91893; 958 8.00002 0.500001 7.52299;
    959 8.00002 0.500001 7.12704; 960 8.00002 0.500001 6.73109;
    961 8.00002 0.500001 6.33515; 962 8.00002 0.500001 5.9392;
    963 8.00002 0.500001 5.54326; 964 8.00002 0.500001 5.14731;
    965 8.00002 0.500001 4.75136; 966 8.00002 0.500001 4.35541;
    967 8.00002 0.500001 3.95947; 968 8.00002 0.500001 3.56352;
    969 8.00002 0.500001 3.16757; 970 8.00002 0.500001 2.77163;
    971 8.00002 0.500001 2.37568; 972 8.00002 0.500001 1.97973;
    973 8.00002 0.500001 1.58379; 974 8.00002 0.500001 1.18784;
    975 8.00002 0.500001 0.791893; 976 8.00002 0.500001 0.395947;
    977 8.00002 0.500001 0; 978 8.00002 0 28.9041; 979 8.00002 0 28.5082;
    980 8.00002 0 28.1122; 981 8.00002 0 27.7163; 982 8.00002 0 27.3203;
    983 8.00002 0 26.9244; 984 8.00002 0 26.5284; 985 8.00002 0 26.1325;
    986 8.00002 0 25.7365; 987 8.00002 0 25.3406; 988 8.00002 0 24.9446;
    989 8.00002 0 24.5487; 990 8.00002 0 24.1527; 991 8.00002 0 23.7568;
    992 8.00002 0 23.3609; 993 8.00002 0 22.9649; 994 8.00002 0 22.569;
    995 8.00002 0 22.173; 996 8.00002 0 21.7771; 997 8.00002 0 21.3811;
    998 8.00002 0 20.9852; 999 8.00002 0 20.5892; 1000 8.00002 0 20.1933;
    1001 8.00002 0 19.7973; 1002 8.00002 0 19.4014; 1003 8.00002 0 19.0054;
    1004 8.00002 0 18.6095; 1005 8.00002 0 18.2135; 1006 8.00002 0 17.8176;
    1007 8.00002 0 17.4217; 1008 8.00002 0 17.0257; 1009 8.00002 0 16.6298;
    1010 8.00002 0 16.2338; 1011 8.00002 0 15.8379; 1012 8.00002 0 15.4419;
    1013 8.00002 0 15.046; 1014 8.00002 0 14.65; 1015 8.00002 0 14.2541;
    1016 8.00002 0 13.8581; 1017 8.00002 0 13.4622; 1018 8.00002 0 13.0662;
    1019 8.00002 0 12.6703; 1020 8.00002 0 12.2743; 1021 8.00002 0 11.8784;
    1022 8.00002 0 11.4825; 1023 8.00002 0 11.0865; 1024 8.00002 0 10.6906;
    1025 8.00002 0 10.2946; 1026 8.00002 0 9.89867; 1027 8.00002 0 9.50272;
    1028 8.00002 0 9.10677; 1029 8.00002 0 8.71083; 1030 8.00002 0 8.31488;
    1031 8.00002 0 7.91893; 1032 8.00002 0 7.52299; 1033 8.00002 0 7.12704;
    1034 8.00002 0 6.73109; 1035 8.00002 0 6.33515; 1036 8.00002 0 5.9392;
    1037 8.00002 0 5.54325; 1038 8.00002 0 5.14731; 1039 8.00002 0 4.75136;
    1040 8.00002 0 4.35541; 1041 8.00002 0 3.95947; 1042 8.00002 0 3.56352;
    1043 8.00002 0 3.16757; 1044 8.00002 0 2.77163; 1045 8.00002 0 2.37568;
    1046 8.00002 0 1.97973; 1047 8.00002 0 1.58379; 1048 8.00002 0 1.18784;
    1049 8.00002 0 0.791893; 1050 8.00002 0 0.395947; 1051 7.60002 0 0;
    1052 7.60002 0 0.395947; 1053 7.20001 0 0; 1054 7.20001 0 0.395947;
    1055 6.80001 0 0; 1056 6.80001 0 0.395947; 1057 6.40001 0 0;
    1058 6.40001 0 0.395947; 1059 6.00001 0 0; 1060 6.00001 0 0.395947;
    1061 5.60001 0 0; 1062 5.60001 0 0.395947; 1063 5.20001 0 0;
    1064 5.20001 0 0.395947; 1065 4.80001 0 0; 1066 4.80001 0 0.395947;
    1067 4.40001 0 0; 1068 4.40001 0 0.395947; 1069 4.00001 0 0;
    1070 4.00001 0 0.395947; 1071 3.60001 0 0; 1072 3.60001 0 0.395947;
    1073 3.20001 0 0; 1074 3.20001 0 0.395947; 1075 2.80001 0 0;
    1076 2.80001 0 0.395947; 1077 2.4 0 0; 1078 2.4 0 0.395947; 1079 2 0 0;
    1080 2 0 0.395947; 1081 1.6 0 0; 1082 1.6 0 0.395947; 1083 1.2 0 0;
    1084 1.2 0 0.395947; 1085 0.800001 0 0; 1086 0.800001 0 0.395947;
    1087 0.400001 0 0; 1088 0.400001 0 0.395947; 1089 7.60001 0 0.791893;
    1090 7.20002 0 0.791893; 1091 6.80001 0 0.791893; 1092 6.40001 0 0.791893;
    1093 6.00001 0 0.791893; 1094 5.60001 0 0.791893; 1095 5.20001 0 0.791893;
    1096 4.80001 0 0.791893; 1097 4.40001 0 0.791893; 1098 4.00001 0 0.791893;
    1099 3.60001 0 0.791893; 1100 3.20001 0 0.791893; 1101 2.80001 0 0.791893;
    1102 2.4 0 0.791893; 1103 2 0 0.791893; 1104 1.6 0 0.791893;
    1105 1.2 0 0.791893; 1106 0.800001 0 0.791893; 1107 0.400001 0 0.791893;
    1108 7.60001 0 1.18784; 1109 7.20001 0 1.18784; 1110 6.80001 0 1.18784;
    1111 6.40001 0 1.18784; 1112 6.00001 0 1.18784; 1113 5.60001 0 1.18784;
    1114 5.20001 0 1.18784; 1115 4.80001 0 1.18784; 1116 4.40001 0 1.18784;
    1117 4.00001 0 1.18784; 1118 3.60001 0 1.18784; 1119 3.20001 0 1.18784;
    1120 2.80001 0 1.18784; 1121 2.4 0 1.18784; 1122 2 0 1.18784;
    1123 1.6 0 1.18784; 1124 1.2 0 1.18784; 1125 0.800001 0 1.18784;
    1126 0.400001 0 1.18784; 1127 7.60001 0 1.58379; 1128 7.20001 0 1.58379;
    1129 6.80001 0 1.58379; 1130 6.40001 0 1.58379; 1131 6.00001 0 1.58379;
    1132 5.60001 0 1.58379; 1133 5.20001 0 1.58379; 1134 4.80001 0 1.58379;
    1135 4.40001 0 1.58379; 1136 4.00001 0 1.58379; 1137 3.60001 0 1.58379;
    1138 3.20001 0 1.58379; 1139 2.80001 0 1.58379; 1140 2.4 0 1.58379;
    1141 2 0 1.58379; 1142 1.6 0 1.58379; 1143 1.2 0 1.58379;
    1144 0.800001 0 1.58379; 1145 0.400001 0 1.58379; 1146 7.60001 0 1.97973;
    1147 7.20001 0 1.97973; 1148 6.80001 0 1.97973; 1149 6.40001 0 1.97973;
    1150 6.00001 0 1.97973; 1151 5.60001 0 1.97973; 1152 5.20001 0 1.97973;
    1153 4.80001 0 1.97973; 1154 4.40001 0 1.97973; 1155 4.00001 0 1.97973;
    1156 3.60001 0 1.97973; 1157 3.20001 0 1.97973; 1158 2.80001 0 1.97973;
    1159 2.4 0 1.97973; 1160 2 0 1.97973; 1161 1.6 0 1.97973; 1162 1.2 0 1.97973;
    1163 0.800001 0 1.97973; 1164 0.400001 0 1.97973; 1165 7.60001 0 2.37568;
    1166 7.20001 0 2.37568; 1167 6.80001 0 2.37568; 1168 6.40001 0 2.37568;
    1169 6.00001 0 2.37568; 1170 5.60001 0 2.37568; 1171 5.20001 0 2.37568;
    1172 4.80001 0 2.37568; 1173 4.40001 0 2.37568; 1174 4.00001 0 2.37568;
    1175 3.60001 0 2.37568; 1176 3.20001 0 2.37568; 1177 2.80001 0 2.37568;
    1178 2.4 0 2.37568; 1179 2 0 2.37568; 1180 1.6 0 2.37568; 1181 1.2 0 2.37568;
    1182 0.800001 0 2.37568; 1183 0.400001 0 2.37568; 1184 7.60002 0 2.77163;
    1185 7.20002 0 2.77163; 1186 6.80001 0 2.77163; 1187 6.40001 0 2.77163;
    1188 6.00001 0 2.77163; 1189 5.60001 0 2.77163; 1190 5.20001 0 2.77163;
    1191 4.80001 0 2.77163; 1192 4.40001 0 2.77163; 1193 4.00001 0 2.77163;
    1194 3.60001 0 2.77163; 1195 3.20001 0 2.77163; 1196 2.80001 0 2.77163;
    1197 2.4 0 2.77163; 1198 2 0 2.77163; 1199 1.6 0 2.77163; 1200 1.2 0 2.77163;
    1201 0.800001 0 2.77163; 1202 0.400001 0 2.77163; 1203 7.60001 0 3.16757;
    1204 7.20001 0 3.16757; 1205 6.80001 0 3.16757; 1206 6.40001 0 3.16757;
    1207 6.00001 0 3.16757; 1208 5.60001 0 3.16757; 1209 5.20001 0 3.16757;
    1210 4.80001 0 3.16757; 1211 4.40001 0 3.16757; 1212 4.00001 0 3.16757;
    1213 3.60001 0 3.16757; 1214 3.20001 0 3.16757; 1215 2.80001 0 3.16757;
    1216 2.4 0 3.16757; 1217 2 0 3.16757; 1218 1.6 0 3.16757; 1219 1.2 0 3.16757;
    1220 0.800001 0 3.16757; 1221 0.400001 0 3.16757; 1222 7.60002 0 3.56352;
    1223 7.20001 0 3.56352; 1224 6.80001 0 3.56352; 1225 6.40001 0 3.56352;
    1226 6.00001 0 3.56352; 1227 5.60001 0 3.56352; 1228 5.20001 0 3.56352;
    1229 4.80001 0 3.56352; 1230 4.40001 0 3.56352; 1231 4.00001 0 3.56352;
    1232 3.60001 0 3.56352; 1233 3.20001 0 3.56352; 1234 2.80001 0 3.56352;
    1235 2.4 0 3.56352; 1236 2 0 3.56352; 1237 1.6 0 3.56352; 1238 1.2 0 3.56352;
    1239 0.800001 0 3.56352; 1240 0.400001 0 3.56352; 1241 7.60002 0 3.95947;
    1242 7.20001 0 3.95947; 1243 6.80001 0 3.95947; 1244 6.40001 0 3.95947;
    1245 6.00001 0 3.95947; 1246 5.60001 0 3.95947; 1247 5.20001 0 3.95947;
    1248 4.80001 0 3.95947; 1249 4.40001 0 3.95947; 1250 4.00001 0 3.95947;
    1251 3.60001 0 3.95947; 1252 3.20001 0 3.95947; 1253 2.80001 0 3.95947;
    1254 2.4 0 3.95947; 1255 2 0 3.95947; 1256 1.6 0 3.95947; 1257 1.2 0 3.95947;
    1258 0.800001 0 3.95947; 1259 0.400001 0 3.95947; 1260 7.60002 0 4.35542;
    1261 7.20002 0 4.35542; 1262 6.80001 0 4.35542; 1263 6.40001 0 4.35542;
    1264 6.00001 0 4.35542; 1265 5.60001 0 4.35542; 1266 5.20001 0 4.35542;
    1267 4.80001 0 4.35542; 1268 4.40001 0 4.35542; 1269 4.00001 0 4.35542;
    1270 3.60001 0 4.35542; 1271 3.20001 0 4.35542; 1272 2.80001 0 4.35542;
    1273 2.4 0 4.35542; 1274 2 0 4.35542; 1275 1.6 0 4.35541; 1276 1.2 0 4.35541;
    1277 0.800001 0 4.35541; 1278 0.400001 0 4.35541; 1279 7.60002 0 4.75136;
    1280 7.20001 0 4.75136; 1281 6.80001 0 4.75136; 1282 6.40001 0 4.75136;
    1283 6.00001 0 4.75136; 1284 5.60001 0 4.75136; 1285 5.20001 0 4.75136;
    1286 4.80001 0 4.75136; 1287 4.40001 0 4.75136; 1288 4.00001 0 4.75136;
    1289 3.60001 0 4.75136; 1290 3.20001 0 4.75136; 1291 2.80001 0 4.75136;
    1292 2.40001 0 4.75136; 1293 2 0 4.75136; 1294 1.6 0 4.75136;
    1295 1.2 0 4.75136; 1296 0.800001 0 4.75136; 1297 0.400001 0 4.75136;
    1298 7.60002 0 5.14731; 1299 7.20002 0 5.14731; 1300 6.80001 0 5.14731;
    1301 6.40001 0 5.14731; 1302 6.00001 0 5.14731; 1303 5.60001 0 5.14731;
    1304 5.20001 0 5.14731; 1305 4.80001 0 5.14731; 1306 4.40001 0 5.14731;
    1307 4.00001 0 5.14731; 1308 3.60001 0 5.14731; 1309 3.20001 0 5.14731;
    1310 2.80001 0 5.14731; 1311 2.40001 0 5.14731; 1312 2 0 5.14731;
    1313 1.6 0 5.14731; 1314 1.2 0 5.14731; 1315 0.800001 0 5.14731;
    1316 0.400001 0 5.14731; 1317 7.60002 0 5.54325; 1318 7.20002 0 5.54325;
    1319 6.80001 0 5.54325; 1320 6.40001 0 5.54325; 1321 6.00001 0 5.54325;
    1322 5.60001 0 5.54325; 1323 5.20001 0 5.54325; 1324 4.80001 0 5.54325;
    1325 4.40001 0 5.54325; 1326 4.00001 0 5.54325; 1327 3.60001 0 5.54325;
    1328 3.20001 0 5.54325; 1329 2.80001 0 5.54325; 1330 2.4 0 5.54325;
    1331 2 0 5.54325; 1332 1.6 0 5.54325; 1333 1.2 0 5.54325;
    1334 0.800001 0 5.54325; 1335 0.400001 0 5.54325; 1336 7.60002 0 5.9392;
    1337 7.20002 0 5.9392; 1338 6.80001 0 5.9392; 1339 6.40001 0 5.9392;
    1340 6.00001 0 5.9392; 1341 5.60001 0 5.9392; 1342 5.20001 0 5.9392;
    1343 4.80001 0 5.9392; 1344 4.40001 0 5.9392; 1345 4.00001 0 5.9392;
    1346 3.60001 0 5.9392; 1347 3.20001 0 5.9392; 1348 2.80001 0 5.9392;
    1349 2.4 0 5.9392; 1350 2 0 5.9392; 1351 1.6 0 5.9392; 1352 1.2 0 5.9392;
    1353 0.800001 0 5.9392; 1354 0.400001 0 5.9392; 1355 7.60002 0 6.33515;
    1356 7.20002 0 6.33515; 1357 6.80001 0 6.33515; 1358 6.40001 0 6.33515;
    1359 6.00001 0 6.33515; 1360 5.60001 0 6.33515; 1361 5.20001 0 6.33515;
    1362 4.80001 0 6.33515; 1363 4.40001 0 6.33515; 1364 4.00001 0 6.33515;
    1365 3.60001 0 6.33515; 1366 3.20001 0 6.33515; 1367 2.80001 0 6.33515;
    1368 2.4 0 6.33515; 1369 2 0 6.33515; 1370 1.6 0 6.33515; 1371 1.2 0 6.33515;
    1372 0.800001 0 6.33515; 1373 0.400001 0 6.33515; 1374 7.60001 0 6.7311;
    1375 7.20002 0 6.7311; 1376 6.80001 0 6.7311; 1377 6.40001 0 6.7311;
    1378 6.00001 0 6.7311; 1379 5.60001 0 6.7311; 1380 5.20001 0 6.7311;
    1381 4.80001 0 6.7311; 1382 4.40001 0 6.7311; 1383 4.00001 0 6.7311;
    1384 3.60001 0 6.7311; 1385 3.20001 0 6.7311; 1386 2.80001 0 6.7311;
    1387 2.4 0 6.7311; 1388 2 0 6.7311; 1389 1.6 0 6.7311; 1390 1.2 0 6.7311;
    1391 0.800001 0 6.7311; 1392 0.400001 0 6.7311; 1393 7.60002 0 7.12704;
    1394 7.20001 0 7.12704; 1395 6.80001 0 7.12704; 1396 6.40001 0 7.12704;
    1397 6.00001 0 7.12704; 1398 5.60001 0 7.12704; 1399 5.20001 0 7.12704;
    1400 4.80001 0 7.12704; 1401 4.40001 0 7.12704; 1402 4.00001 0 7.12704;
    1403 3.60001 0 7.12704; 1404 3.20001 0 7.12704; 1405 2.80001 0 7.12704;
    1406 2.4 0 7.12704; 1407 2 0 7.12704; 1408 1.6 0 7.12704; 1409 1.2 0 7.12704;
    1410 0.800001 0 7.12704; 1411 0.400001 0 7.12704; 1412 7.60001 0 7.52299;
    1413 7.20001 0 7.52299; 1414 6.80001 0 7.52299; 1415 6.40001 0 7.52299;
    1416 6.00001 0 7.52299; 1417 5.60001 0 7.52299; 1418 5.20001 0 7.52299;
    1419 4.80001 0 7.52299; 1420 4.40001 0 7.52299; 1421 4.00001 0 7.52299;
    1422 3.60001 0 7.52299; 1423 3.20001 0 7.52299; 1424 2.80001 0 7.52299;
    1425 2.4 0 7.52299; 1426 2 0 7.52299; 1427 1.6 0 7.52299; 1428 1.2 0 7.52299;
    1429 0.800001 0 7.52299; 1430 0.400001 0 7.52299; 1431 7.60001 0 7.91894;
    1432 7.20002 0 7.91894; 1433 6.80001 0 7.91894; 1434 6.40001 0 7.91894;
    1435 6.00001 0 7.91894; 1436 5.60001 0 7.91894; 1437 5.20001 0 7.91894;
    1438 4.80001 0 7.91894; 1439 4.40001 0 7.91894; 1440 4.00001 0 7.91894;
    1441 3.60001 0 7.91894; 1442 3.20001 0 7.91894; 1443 2.80001 0 7.91894;
    1444 2.4 0 7.91894; 1445 2 0 7.91894; 1446 1.6 0 7.91894; 1447 1.2 0 7.91894;
    1448 0.800001 0 7.91894; 1449 0.400001 0 7.91894; 1450 7.60002 0 8.31488;
    1451 7.20002 0 8.31488; 1452 6.80001 0 8.31488; 1453 6.40001 0 8.31488;
    1454 6.00001 0 8.31488; 1455 5.60001 0 8.31488; 1456 5.20001 0 8.31488;
    1457 4.80001 0 8.31488; 1458 4.40001 0 8.31488; 1459 4.00001 0 8.31488;
    1460 3.60001 0 8.31488; 1461 3.20001 0 8.31488; 1462 2.80001 0 8.31488;
    1463 2.4 0 8.31488; 1464 2 0 8.31488; 1465 1.6 0 8.31488; 1466 1.2 0 8.31488;
    1467 0.800001 0 8.31488; 1468 0.400001 0 8.31488; 1469 7.60002 0 8.71083;
    1470 7.20001 0 8.71083; 1471 6.80001 0 8.71083; 1472 6.40001 0 8.71083;
    1473 6.00001 0 8.71083; 1474 5.60001 0 8.71083; 1475 5.20001 0 8.71083;
    1476 4.80001 0 8.71083; 1477 4.40001 0 8.71083; 1478 4.00001 0 8.71083;
    1479 3.60001 0 8.71083; 1480 3.20001 0 8.71083; 1481 2.80001 0 8.71083;
    1482 2.4 0 8.71083; 1483 2 0 8.71083; 1484 1.6 0 8.71083; 1485 1.2 0 8.71083;
    1486 0.800001 0 8.71083; 1487 0.400001 0 8.71083; 1488 7.60002 0 9.10678;
    1489 7.20001 0 9.10678; 1490 6.80001 0 9.10678; 1491 6.40001 0 9.10678;
    1492 6.00001 0 9.10678; 1493 5.60001 0 9.10678; 1494 5.20001 0 9.10678;
    1495 4.80001 0 9.10678; 1496 4.40001 0 9.10678; 1497 4.00001 0 9.10678;
    1498 3.60001 0 9.10677; 1499 3.20001 0 9.10677; 1500 2.80001 0 9.10677;
    1501 2.4 0 9.10677; 1502 2 0 9.10677; 1503 1.6 0 9.10677; 1504 1.2 0 9.10677;
    1505 0.800001 0 9.10677; 1506 0.400001 0 9.10677; 1507 7.60002 0 9.50272;
    1508 7.20001 0 9.50272; 1509 6.80001 0 9.50272; 1510 6.40001 0 9.50272;
    1511 6.00001 0 9.50272; 1512 5.60001 0 9.50272; 1513 5.20001 0 9.50272;
    1514 4.80001 0 9.50272; 1515 4.40001 0 9.50272; 1516 4.00001 0 9.50272;
    1517 3.60001 0 9.50272; 1518 3.20001 0 9.50272; 1519 2.80001 0 9.50272;
    1520 2.4 0 9.50272; 1521 2 0 9.50272; 1522 1.6 0 9.50272; 1523 1.2 0 9.50272;
    1524 0.800001 0 9.50272; 1525 0.400001 0 9.50272; 1526 7.60001 0 9.89867;
    1527 7.20002 0 9.89867; 1528 6.80001 0 9.89867; 1529 6.40001 0 9.89867;
    1530 6.00001 0 9.89867; 1531 5.60001 0 9.89867; 1532 5.20001 0 9.89867;
    1533 4.80001 0 9.89867; 1534 4.40001 0 9.89867; 1535 4.00001 0 9.89867;
    1536 3.60001 0 9.89867; 1537 3.20001 0 9.89867; 1538 2.80001 0 9.89867;
    1539 2.4 0 9.89867; 1540 2 0 9.89867; 1541 1.6 0 9.89867; 1542 1.2 0 9.89867;
    1543 0.800001 0 9.89867; 1544 0.400001 0 9.89867; 1545 7.60001 0 10.2946;
    1546 7.20002 0 10.2946; 1547 6.80001 0 10.2946; 1548 6.40001 0 10.2946;
    1549 6.00001 0 10.2946; 1550 5.60001 0 10.2946; 1551 5.20001 0 10.2946;
    1552 4.80001 0 10.2946; 1553 4.40001 0 10.2946; 1554 4.00001 0 10.2946;
    1555 3.60001 0 10.2946; 1556 3.20001 0 10.2946; 1557 2.80001 0 10.2946;
    1558 2.4 0 10.2946; 1559 2 0 10.2946; 1560 1.6 0 10.2946; 1561 1.2 0 10.2946;
    1562 0.800001 0 10.2946; 1563 0.400001 0 10.2946; 1564 7.60001 0 10.6906;
    1565 7.20002 0 10.6906; 1566 6.80001 0 10.6906; 1567 6.40001 0 10.6906;
    1568 6.00001 0 10.6906; 1569 5.60001 0 10.6906; 1570 5.20001 0 10.6906;
    1571 4.80001 0 10.6906; 1572 4.40001 0 10.6906; 1573 4.00001 0 10.6906;
    1574 3.60001 0 10.6906; 1575 3.20001 0 10.6906; 1576 2.80001 0 10.6906;
    1577 2.4 0 10.6906; 1578 2 0 10.6906; 1579 1.6 0 10.6906; 1580 1.2 0 10.6906;
    1581 0.800001 0 10.6906; 1582 0.400001 0 10.6906; 1583 7.60001 0 11.0865;
    1584 7.20002 0 11.0865; 1585 6.80001 0 11.0865; 1586 6.40001 0 11.0865;
    1587 6.00001 0 11.0865; 1588 5.60001 0 11.0865; 1589 5.20001 0 11.0865;
    1590 4.80001 0 11.0865; 1591 4.40001 0 11.0865; 1592 4.00001 0 11.0865;
    1593 3.60001 0 11.0865; 1594 3.20001 0 11.0865; 1595 2.80001 0 11.0865;
    1596 2.40001 0 11.0865; 1597 2 0 11.0865; 1598 1.6 0 11.0865;
    1599 1.2 0 11.0865; 1600 0.800001 0 11.0865; 1601 0.400001 0 11.0865;
    1602 7.60001 0 11.4825; 1603 7.20001 0 11.4825; 1604 6.80001 0 11.4825;
    1605 6.40001 0 11.4825; 1606 6.00001 0 11.4825; 1607 5.60001 0 11.4825;
    1608 5.20001 0 11.4825; 1609 4.80001 0 11.4825; 1610 4.40001 0 11.4825;
    1611 4.00001 0 11.4825; 1612 3.60001 0 11.4825; 1613 3.20001 0 11.4825;
    1614 2.80001 0 11.4825; 1615 2.4 0 11.4825; 1616 2 0 11.4825;
    1617 1.6 0 11.4825; 1618 1.2 0 11.4825; 1619 0.800001 0 11.4825;
    1620 0.400001 0 11.4825; 1621 7.60002 0 11.8784; 1622 7.20001 0 11.8784;
    1623 6.80001 0 11.8784; 1624 6.40001 0 11.8784; 1625 6.00001 0 11.8784;
    1626 5.60001 0 11.8784; 1627 5.20001 0 11.8784; 1628 4.80001 0 11.8784;
    1629 4.40001 0 11.8784; 1630 4.00001 0 11.8784; 1631 3.60001 0 11.8784;
    1632 3.20001 0 11.8784; 1633 2.80001 0 11.8784; 1634 2.4 0 11.8784;
    1635 2 0 11.8784; 1636 1.6 0 11.8784; 1637 1.2 0 11.8784;
    1638 0.800001 0 11.8784; 1639 0.400001 0 11.8784; 1640 7.60001 0 12.2743;
    1641 7.20001 0 12.2743; 1642 6.80001 0 12.2743; 1643 6.40001 0 12.2743;
    1644 6.00001 0 12.2743; 1645 5.60001 0 12.2743; 1646 5.20001 0 12.2743;
    1647 4.80001 0 12.2743; 1648 4.40001 0 12.2743; 1649 4.00001 0 12.2743;
    1650 3.60001 0 12.2743; 1651 3.20001 0 12.2743; 1652 2.80001 0 12.2743;
    1653 2.4 0 12.2743; 1654 2 0 12.2743; 1655 1.6 0 12.2743; 1656 1.2 0 12.2743;
    1657 0.800001 0 12.2743; 1658 0.400001 0 12.2743; 1659 7.60002 0 12.6703;
    1660 7.20002 0 12.6703; 1661 6.80001 0 12.6703; 1662 6.40001 0 12.6703;
    1663 6.00001 0 12.6703; 1664 5.60001 0 12.6703; 1665 5.20001 0 12.6703;
    1666 4.80001 0 12.6703; 1667 4.40001 0 12.6703; 1668 4.00001 0 12.6703;
    1669 3.60001 0 12.6703; 1670 3.20001 0 12.6703; 1671 2.80001 0 12.6703;
    1672 2.4 0 12.6703; 1673 2 0 12.6703; 1674 1.6 0 12.6703; 1675 1.2 0 12.6703;
    1676 0.800001 0 12.6703; 1677 0.400001 0 12.6703; 1678 7.60001 0 13.0662;
    1679 7.20002 0 13.0662; 1680 6.80001 0 13.0662; 1681 6.40001 0 13.0662;
    1682 6.00001 0 13.0662; 1683 5.60001 0 13.0662; 1684 5.20001 0 13.0662;
    1685 4.80001 0 13.0662; 1686 4.40001 0 13.0662; 1687 4.00001 0 13.0662;
    1688 3.60001 0 13.0662; 1689 3.20001 0 13.0662; 1690 2.80001 0 13.0662;
    1691 2.4 0 13.0662; 1692 2 0 13.0662; 1693 1.6 0 13.0662; 1694 1.2 0 13.0662;
    1695 0.800001 0 13.0662; 1696 0.400001 0 13.0662; 1697 7.60001 0 13.4622;
    1698 7.20002 0 13.4622; 1699 6.80001 0 13.4622; 1700 6.40001 0 13.4622;
    1701 6.00001 0 13.4622; 1702 5.60001 0 13.4622; 1703 5.20001 0 13.4622;
    1704 4.80001 0 13.4622; 1705 4.40001 0 13.4622; 1706 4.00001 0 13.4622;
    1707 3.60001 0 13.4622; 1708 3.20001 0 13.4622; 1709 2.80001 0 13.4622;
    1710 2.4 0 13.4622; 1711 2 0 13.4622; 1712 1.6 0 13.4622; 1713 1.2 0 13.4622;
    1714 0.800001 0 13.4622; 1715 0.400001 0 13.4622; 1716 7.60001 0 13.8581;
    1717 7.20002 0 13.8581; 1718 6.80001 0 13.8581; 1719 6.40001 0 13.8581;
    1720 6.00001 0 13.8581; 1721 5.60001 0 13.8581; 1722 5.20001 0 13.8581;
    1723 4.80001 0 13.8581; 1724 4.40001 0 13.8581; 1725 4.00001 0 13.8581;
    1726 3.60001 0 13.8581; 1727 3.20001 0 13.8581; 1728 2.80001 0 13.8581;
    1729 2.4 0 13.8581; 1730 2 0 13.8581; 1731 1.6 0 13.8581; 1732 1.2 0 13.8581;
    1733 0.800001 0 13.8581; 1734 0.400001 0 13.8581; 1735 7.60001 0 14.2541;
    1736 7.20002 0 14.2541; 1737 6.80001 0 14.2541; 1738 6.40001 0 14.2541;
    1739 6.00001 0 14.2541; 1740 5.60001 0 14.2541; 1741 5.20001 0 14.2541;
    1742 4.80001 0 14.2541; 1743 4.40001 0 14.2541; 1744 4.00001 0 14.2541;
    1745 3.60001 0 14.2541; 1746 3.20001 0 14.2541; 1747 2.80001 0 14.2541;
    1748 2.4 0 14.2541; 1749 2 0 14.2541; 1750 1.6 0 14.2541; 1751 1.2 0 14.2541;
    1752 0.800001 0 14.2541; 1753 0.400001 0 14.2541; 1754 7.60001 0 14.65;
    1755 7.20002 0 14.65; 1756 6.80001 0 14.65; 1757 6.40001 0 14.65;
    1758 6.00001 0 14.65; 1759 5.60001 0 14.65; 1760 5.20001 0 14.65;
    1761 4.80001 0 14.65; 1762 4.40001 0 14.65; 1763 4.00001 0 14.65;
    1764 3.60001 0 14.65; 1765 3.20001 0 14.65; 1766 2.80001 0 14.65;
    1767 2.4 0 14.65; 1768 2 0 14.65; 1769 1.6 0 14.65; 1770 1.2 0 14.65;
    1771 0.800001 0 14.65; 1772 0.400001 0 14.65; 1773 7.60002 0 15.046;
    1774 7.20001 0 15.046; 1775 6.80001 0 15.046; 1776 6.40001 0 15.046;
    1777 6.00001 0 15.046; 1778 5.60001 0 15.046; 1779 5.20001 0 15.046;
    1780 4.80001 0 15.046; 1781 4.40001 0 15.046; 1782 4.00001 0 15.046;
    1783 3.60001 0 15.046; 1784 3.20001 0 15.046; 1785 2.80001 0 15.046;
    1786 2.4 0 15.046; 1787 2 0 15.046; 1788 1.6 0 15.046; 1789 1.2 0 15.046;
    1790 0.800001 0 15.046; 1791 0.400001 0 15.046; 1792 7.60001 0 15.4419;
    1793 7.20002 0 15.4419; 1794 6.80001 0 15.4419; 1795 6.40001 0 15.4419;
    1796 6.00001 0 15.4419; 1797 5.60001 0 15.4419; 1798 5.20001 0 15.4419;
    1799 4.80001 0 15.4419; 1800 4.40001 0 15.4419; 1801 4.00001 0 15.4419;
    1802 3.60001 0 15.4419; 1803 3.20001 0 15.4419; 1804 2.80001 0 15.4419;
    1805 2.4 0 15.4419; 1806 2 0 15.4419; 1807 1.6 0 15.4419; 1808 1.2 0 15.4419;
    1809 0.800001 0 15.4419; 1810 0.400001 0 15.4419; 1811 7.60002 0 15.8379;
    1812 7.20002 0 15.8379; 1813 6.80001 0 15.8379; 1814 6.40001 0 15.8379;
    1815 6.00001 0 15.8379; 1816 5.60001 0 15.8379; 1817 5.20001 0 15.8379;
    1818 4.80001 0 15.8379; 1819 4.40001 0 15.8379; 1820 4.00001 0 15.8379;
    1821 3.60001 0 15.8379; 1822 3.20001 0 15.8379; 1823 2.80001 0 15.8379;
    1824 2.4 0 15.8379; 1825 2 0 15.8379; 1826 1.6 0 15.8379; 1827 1.2 0 15.8379;
    1828 0.800001 0 15.8379; 1829 0.400001 0 15.8379; 1830 7.60001 0 16.2338;
    1831 7.20001 0 16.2338; 1832 6.80001 0 16.2338; 1833 6.40001 0 16.2338;
    1834 6.00001 0 16.2338; 1835 5.60001 0 16.2338; 1836 5.20001 0 16.2338;
    1837 4.80001 0 16.2338; 1838 4.40001 0 16.2338; 1839 4.00001 0 16.2338;
    1840 3.60001 0 16.2338; 1841 3.20001 0 16.2338; 1842 2.80001 0 16.2338;
    1843 2.4 0 16.2338; 1844 2 0 16.2338; 1845 1.6 0 16.2338; 1846 1.2 0 16.2338;
    1847 0.800001 0 16.2338; 1848 0.400001 0 16.2338; 1849 7.60001 0 16.6298;
    1850 7.20002 0 16.6298; 1851 6.80001 0 16.6298; 1852 6.40001 0 16.6298;
    1853 6.00001 0 16.6298; 1854 5.60001 0 16.6298; 1855 5.20001 0 16.6298;
    1856 4.80001 0 16.6298; 1857 4.40001 0 16.6298; 1858 4.00001 0 16.6298;
    1859 3.60001 0 16.6298; 1860 3.20001 0 16.6298; 1861 2.80001 0 16.6298;
    1862 2.4 0 16.6298; 1863 2 0 16.6298; 1864 1.6 0 16.6298; 1865 1.2 0 16.6298;
    1866 0.800001 0 16.6298; 1867 0.400001 0 16.6298; 1868 7.60001 0 17.0257;
    1869 7.20002 0 17.0257; 1870 6.80001 0 17.0257; 1871 6.40001 0 17.0257;
    1872 6.00001 0 17.0257; 1873 5.60001 0 17.0257; 1874 5.20001 0 17.0257;
    1875 4.80001 0 17.0257; 1876 4.40001 0 17.0257; 1877 4.00001 0 17.0257;
    1878 3.60001 0 17.0257; 1879 3.20001 0 17.0257; 1880 2.80001 0 17.0257;
    1881 2.4 0 17.0257; 1882 2 0 17.0257; 1883 1.6 0 17.0257; 1884 1.2 0 17.0257;
    1885 0.800001 0 17.0257; 1886 0.400001 0 17.0257; 1887 7.60001 0 17.4217;
    1888 7.20002 0 17.4217; 1889 6.80001 0 17.4217; 1890 6.40001 0 17.4217;
    1891 6.00001 0 17.4217; 1892 5.60001 0 17.4217; 1893 5.20001 0 17.4217;
    1894 4.80001 0 17.4217; 1895 4.40001 0 17.4217; 1896 4.00001 0 17.4217;
    1897 3.60001 0 17.4217; 1898 3.20001 0 17.4217; 1899 2.80001 0 17.4217;
    1900 2.4 0 17.4217; 1901 2 0 17.4217; 1902 1.6 0 17.4217; 1903 1.2 0 17.4217;
    1904 0.800001 0 17.4217; 1905 0.400001 0 17.4217; 1906 7.60001 0 17.8176;
    1907 7.20002 0 17.8176; 1908 6.80001 0 17.8176; 1909 6.40001 0 17.8176;
    1910 6.00001 0 17.8176; 1911 5.60001 0 17.8176; 1912 5.20001 0 17.8176;
    1913 4.80001 0 17.8176; 1914 4.40001 0 17.8176; 1915 4.00001 0 17.8176;
    1916 3.60001 0 17.8176; 1917 3.20001 0 17.8176; 1918 2.80001 0 17.8176;
    1919 2.4 0 17.8176; 1920 2 0 17.8176; 1921 1.6 0 17.8176; 1922 1.2 0 17.8176;
    1923 0.800001 0 17.8176; 1924 0.400001 0 17.8176; 1925 7.60002 0 18.2135;
    1926 7.20001 0 18.2135; 1927 6.80001 0 18.2135; 1928 6.40001 0 18.2135;
    1929 6.00001 0 18.2135; 1930 5.60001 0 18.2135; 1931 5.20001 0 18.2135;
    1932 4.80001 0 18.2135; 1933 4.40001 0 18.2135; 1934 4.00001 0 18.2135;
    1935 3.60001 0 18.2135; 1936 3.20001 0 18.2135; 1937 2.80001 0 18.2135;
    1938 2.4 0 18.2135; 1939 2 0 18.2135; 1940 1.6 0 18.2135; 1941 1.2 0 18.2135;
    1942 0.800001 0 18.2135; 1943 0.400001 0 18.2135; 1944 7.60001 0 18.6095;
    1945 7.20002 0 18.6095; 1946 6.80001 0 18.6095; 1947 6.40001 0 18.6095;
    1948 6.00001 0 18.6095; 1949 5.60001 0 18.6095; 1950 5.20001 0 18.6095;
    1951 4.80001 0 18.6095; 1952 4.40001 0 18.6095; 1953 4.00001 0 18.6095;
    1954 3.60001 0 18.6095; 1955 3.20001 0 18.6095; 1956 2.80001 0 18.6095;
    1957 2.4 0 18.6095; 1958 2 0 18.6095; 1959 1.6 0 18.6095; 1960 1.2 0 18.6095;
    1961 0.800001 0 18.6095; 1962 0.400001 0 18.6095; 1963 7.60002 0 19.0054;
    1964 7.20001 0 19.0054; 1965 6.80001 0 19.0054; 1966 6.40001 0 19.0054;
    1967 6.00001 0 19.0054; 1968 5.60001 0 19.0054; 1969 5.20001 0 19.0054;
    1970 4.80001 0 19.0054; 1971 4.40001 0 19.0054; 1972 4.00001 0 19.0054;
    1973 3.60001 0 19.0054; 1974 3.20001 0 19.0054; 1975 2.80001 0 19.0054;
    1976 2.4 0 19.0054; 1977 2 0 19.0054; 1978 1.6 0 19.0054; 1979 1.2 0 19.0054;
    1980 0.800001 0 19.0054; 1981 0.400001 0 19.0054; 1982 7.60001 0 19.4014;
    1983 7.20001 0 19.4014; 1984 6.80001 0 19.4014; 1985 6.40001 0 19.4014;
    1986 6.00001 0 19.4014; 1987 5.60001 0 19.4014; 1988 5.20001 0 19.4014;
    1989 4.80001 0 19.4014; 1990 4.40001 0 19.4014; 1991 4.00001 0 19.4014;
    1992 3.60001 0 19.4014; 1993 3.20001 0 19.4014; 1994 2.80001 0 19.4014;
    1995 2.4 0 19.4014; 1996 2 0 19.4014; 1997 1.6 0 19.4014; 1998 1.2 0 19.4014;
    1999 0.800001 0 19.4014; 2000 0.400001 0 19.4014; 2001 7.60001 0 19.7973;
    2002 7.20001 0 19.7973; 2003 6.80001 0 19.7973; 2004 6.40001 0 19.7973;
    2005 6.00001 0 19.7973; 2006 5.60001 0 19.7973; 2007 5.20001 0 19.7973;
    2008 4.80001 0 19.7973; 2009 4.40001 0 19.7973; 2010 4.00001 0 19.7973;
    2011 3.60001 0 19.7973; 2012 3.20001 0 19.7973; 2013 2.80001 0 19.7973;
    2014 2.4 0 19.7973; 2015 2 0 19.7973; 2016 1.6 0 19.7973; 2017 1.2 0 19.7973;
    2018 0.800001 0 19.7973; 2019 0.400001 0 19.7973; 2020 7.60001 0 20.1933;
    2021 7.20002 0 20.1933; 2022 6.80001 0 20.1933; 2023 6.40001 0 20.1933;
    2024 6.00001 0 20.1933; 2025 5.60001 0 20.1933; 2026 5.20001 0 20.1933;
    2027 4.80001 0 20.1933; 2028 4.40001 0 20.1933; 2029 4.00001 0 20.1933;
    2030 3.60001 0 20.1933; 2031 3.20001 0 20.1933; 2032 2.80001 0 20.1933;
    2033 2.4 0 20.1933; 2034 2 0 20.1933; 2035 1.6 0 20.1933; 2036 1.2 0 20.1933;
    2037 0.800001 0 20.1933; 2038 0.400001 0 20.1933; 2039 7.60002 0 20.5892;
    2040 7.20001 0 20.5892; 2041 6.80001 0 20.5892; 2042 6.40001 0 20.5892;
    2043 6.00001 0 20.5892; 2044 5.60001 0 20.5892; 2045 5.20001 0 20.5892;
    2046 4.80001 0 20.5892; 2047 4.40001 0 20.5892; 2048 4.00001 0 20.5892;
    2049 3.60001 0 20.5892; 2050 3.20001 0 20.5892; 2051 2.80001 0 20.5892;
    2052 2.4 0 20.5892; 2053 2 0 20.5892; 2054 1.6 0 20.5892; 2055 1.2 0 20.5892;
    2056 0.800001 0 20.5892; 2057 0.400001 0 20.5892; 2058 7.60002 0 20.9852;
    2059 7.20002 0 20.9852; 2060 6.80001 0 20.9852; 2061 6.40001 0 20.9852;
    2062 6.00001 0 20.9852; 2063 5.60001 0 20.9852; 2064 5.20001 0 20.9852;
    2065 4.80001 0 20.9852; 2066 4.40001 0 20.9852; 2067 4.00001 0 20.9852;
    2068 3.60001 0 20.9852; 2069 3.20001 0 20.9852; 2070 2.80001 0 20.9852;
    2071 2.4 0 20.9852; 2072 2 0 20.9852; 2073 1.6 0 20.9852; 2074 1.2 0 20.9852;
    2075 0.800001 0 20.9852; 2076 0.400001 0 20.9852; 2077 7.60002 0 21.3811;
    2078 7.20001 0 21.3811; 2079 6.80001 0 21.3811; 2080 6.40001 0 21.3811;
    2081 6.00001 0 21.3811; 2082 5.60001 0 21.3811; 2083 5.20001 0 21.3811;
    2084 4.80001 0 21.3811; 2085 4.40001 0 21.3811; 2086 4.00001 0 21.3811;
    2087 3.60001 0 21.3811; 2088 3.20001 0 21.3811; 2089 2.80001 0 21.3811;
    2090 2.4 0 21.3811; 2091 2 0 21.3811; 2092 1.6 0 21.3811; 2093 1.2 0 21.3811;
    2094 0.800001 0 21.3811; 2095 0.400001 0 21.3811; 2096 7.60001 0 21.7771;
    2097 7.20002 0 21.7771; 2098 6.80002 0 21.7771; 2099 6.40001 0 21.7771;
    2100 6.00001 0 21.7771; 2101 5.60001 0 21.7771; 2102 5.20001 0 21.7771;
    2103 4.80001 0 21.7771; 2104 4.40001 0 21.7771; 2105 4.00001 0 21.7771;
    2106 3.60001 0 21.7771; 2107 3.20001 0 21.7771; 2108 2.80001 0 21.7771;
    2109 2.4 0 21.7771; 2110 2 0 21.7771; 2111 1.6 0 21.7771; 2112 1.2 0 21.7771;
    2113 0.800001 0 21.7771; 2114 0.400001 0 21.7771; 2115 7.60002 0 22.173;
    2116 7.20002 0 22.173; 2117 6.80001 0 22.173; 2118 6.40001 0 22.173;
    2119 6.00001 0 22.173; 2120 5.60001 0 22.173; 2121 5.20001 0 22.173;
    2122 4.80001 0 22.173; 2123 4.40001 0 22.173; 2124 4.00001 0 22.173;
    2125 3.60001 0 22.173; 2126 3.20001 0 22.173; 2127 2.80001 0 22.173;
    2128 2.4 0 22.173; 2129 2 0 22.173; 2130 1.6 0 22.173; 2131 1.2 0 22.173;
    2132 0.800001 0 22.173; 2133 0.400001 0 22.173; 2134 7.60001 0 22.569;
    2135 7.20001 0 22.569; 2136 6.80001 0 22.569; 2137 6.40001 0 22.569;
    2138 6.00001 0 22.569; 2139 5.60001 0 22.569; 2140 5.20001 0 22.569;
    2141 4.80001 0 22.569; 2142 4.40001 0 22.569; 2143 4.00001 0 22.569;
    2144 3.60001 0 22.569; 2145 3.20001 0 22.569; 2146 2.80001 0 22.569;
    2147 2.4 0 22.569; 2148 2 0 22.569; 2149 1.6 0 22.569; 2150 1.2 0 22.569;
    2151 0.800001 0 22.569; 2152 0.400001 0 22.569; 2153 7.60001 0 22.9649;
    2154 7.20001 0 22.9649; 2155 6.80001 0 22.9649; 2156 6.40001 0 22.9649;
    2157 6.00001 0 22.9649; 2158 5.60001 0 22.9649; 2159 5.20001 0 22.9649;
    2160 4.80001 0 22.9649; 2161 4.40001 0 22.9649; 2162 4.00001 0 22.9649;
    2163 3.60001 0 22.9649; 2164 3.20001 0 22.9649; 2165 2.80001 0 22.9649;
    2166 2.4 0 22.9649; 2167 2 0 22.9649; 2168 1.6 0 22.9649; 2169 1.2 0 22.9649;
    2170 0.800001 0 22.9649; 2171 0.400001 0 22.9649; 2172 7.60001 0 23.3609;
    2173 7.20002 0 23.3609; 2174 6.80001 0 23.3609; 2175 6.40001 0 23.3609;
    2176 6.00001 0 23.3609; 2177 5.60001 0 23.3609; 2178 5.20001 0 23.3609;
    2179 4.80001 0 23.3609; 2180 4.40001 0 23.3609; 2181 4.00001 0 23.3609;
    2182 3.60001 0 23.3609; 2183 3.20001 0 23.3609; 2184 2.80001 0 23.3609;
    2185 2.4 0 23.3609; 2186 2 0 23.3609; 2187 1.6 0 23.3609; 2188 1.2 0 23.3609;
    2189 0.800001 0 23.3609; 2190 0.400001 0 23.3609; 2191 7.60002 0 23.7568;
    2192 7.20002 0 23.7568; 2193 6.80001 0 23.7568; 2194 6.40001 0 23.7568;
    2195 6.00001 0 23.7568; 2196 5.60001 0 23.7568; 2197 5.20001 0 23.7568;
    2198 4.80001 0 23.7568; 2199 4.40001 0 23.7568; 2200 4.00001 0 23.7568;
    2201 3.60001 0 23.7568; 2202 3.20001 0 23.7568; 2203 2.80001 0 23.7568;
    2204 2.4 0 23.7568; 2205 2 0 23.7568; 2206 1.6 0 23.7568; 2207 1.2 0 23.7568;
    2208 0.800001 0 23.7568; 2209 0.400001 0 23.7568; 2210 7.60001 0 24.1527;
    2211 7.20001 0 24.1527; 2212 6.80001 0 24.1527; 2213 6.40001 0 24.1527;
    2214 6.00001 0 24.1527; 2215 5.60001 0 24.1527; 2216 5.20001 0 24.1527;
    2217 4.80001 0 24.1527; 2218 4.40001 0 24.1527; 2219 4.00001 0 24.1527;
    2220 3.60001 0 24.1527; 2221 3.20001 0 24.1527; 2222 2.80001 0 24.1527;
    2223 2.4 0 24.1527; 2224 2 0 24.1527; 2225 1.6 0 24.1527; 2226 1.2 0 24.1527;
    2227 0.800001 0 24.1527; 2228 0.400001 0 24.1527; 2229 7.60001 0 24.5487;
    2230 7.20001 0 24.5487; 2231 6.80001 0 24.5487; 2232 6.40001 0 24.5487;
    2233 6.00001 0 24.5487; 2234 5.60001 0 24.5487; 2235 5.20001 0 24.5487;
    2236 4.80001 0 24.5487; 2237 4.40001 0 24.5487; 2238 4.00001 0 24.5487;
    2239 3.60001 0 24.5487; 2240 3.20001 0 24.5487; 2241 2.80001 0 24.5487;
    2242 2.4 0 24.5487; 2243 2 0 24.5487; 2244 1.6 0 24.5487; 2245 1.2 0 24.5487;
    2246 0.800001 0 24.5487; 2247 0.400001 0 24.5487; 2248 7.60002 0 24.9446;
    2249 7.20001 0 24.9446; 2250 6.80001 0 24.9446; 2251 6.40001 0 24.9446;
    2252 6.00001 0 24.9446; 2253 5.60001 0 24.9446; 2254 5.20001 0 24.9446;
    2255 4.80001 0 24.9446; 2256 4.40001 0 24.9446; 2257 4.00001 0 24.9446;
    2258 3.60001 0 24.9446; 2259 3.20001 0 24.9446; 2260 2.80001 0 24.9446;
    2261 2.4 0 24.9446; 2262 2 0 24.9446; 2263 1.6 0 24.9446; 2264 1.2 0 24.9446;
    2265 0.800001 0 24.9446; 2266 0.400001 0 24.9446; 2267 7.60002 0 25.3406;
    2268 7.20002 0 25.3406; 2269 6.80001 0 25.3406; 2270 6.40001 0 25.3406;
    2271 6.00001 0 25.3406; 2272 5.60001 0 25.3406; 2273 5.20001 0 25.3406;
    2274 4.80001 0 25.3406; 2275 4.40001 0 25.3406; 2276 4.00001 0 25.3406;
    2277 3.60001 0 25.3406; 2278 3.20001 0 25.3406; 2279 2.80001 0 25.3406;
    2280 2.4 0 25.3406; 2281 2 0 25.3406; 2282 1.6 0 25.3406; 2283 1.2 0 25.3406;
    2284 0.800001 0 25.3406; 2285 0.400001 0 25.3406; 2286 7.60001 0 25.7365;
    2287 7.20001 0 25.7365; 2288 6.80001 0 25.7365; 2289 6.40001 0 25.7365;
    2290 6.00001 0 25.7365; 2291 5.60001 0 25.7365; 2292 5.20001 0 25.7365;
    2293 4.80001 0 25.7365; 2294 4.40001 0 25.7365; 2295 4.00001 0 25.7365;
    2296 3.60001 0 25.7365; 2297 3.20001 0 25.7365; 2298 2.80001 0 25.7365;
    2299 2.4 0 25.7365; 2300 2 0 25.7365; 2301 1.6 0 25.7365; 2302 1.2 0 25.7365;
    2303 0.800001 0 25.7365; 2304 0.400001 0 25.7365; 2305 7.60001 0 26.1325;
    2306 7.20001 0 26.1325; 2307 6.80001 0 26.1325; 2308 6.40001 0 26.1325;
    2309 6.00001 0 26.1325; 2310 5.60001 0 26.1325; 2311 5.20001 0 26.1325;
    2312 4.80001 0 26.1325; 2313 4.40001 0 26.1325; 2314 4.00001 0 26.1325;
    2315 3.60001 0 26.1325; 2316 3.20001 0 26.1325; 2317 2.80001 0 26.1325;
    2318 2.4 0 26.1325; 2319 2 0 26.1325; 2320 1.6 0 26.1325; 2321 1.2 0 26.1325;
    2322 0.800001 0 26.1325; 2323 0.400001 0 26.1325; 2324 7.60001 0 26.5284;
    2325 7.20001 0 26.5284; 2326 6.80001 0 26.5284; 2327 6.40001 0 26.5284;
    2328 6.00001 0 26.5284; 2329 5.60001 0 26.5284; 2330 5.20001 0 26.5284;
    2331 4.80001 0 26.5284; 2332 4.40001 0 26.5284; 2333 4.00001 0 26.5284;
    2334 3.60001 0 26.5284; 2335 3.20001 0 26.5284; 2336 2.80001 0 26.5284;
    2337 2.4 0 26.5284; 2338 2 0 26.5284; 2339 1.6 0 26.5284; 2340 1.2 0 26.5284;
    2341 0.800001 0 26.5284; 2342 0.400001 0 26.5284; 2343 7.60001 0 26.9244;
    2344 7.20002 0 26.9244; 2345 6.80001 0 26.9244; 2346 6.40001 0 26.9244;
    2347 6.00001 0 26.9244; 2348 5.60001 0 26.9244; 2349 5.20001 0 26.9244;
    2350 4.80001 0 26.9244; 2351 4.40001 0 26.9244; 2352 4.00001 0 26.9244;
    2353 3.60001 0 26.9244; 2354 3.20001 0 26.9244; 2355 2.80001 0 26.9244;
    2356 2.4 0 26.9244; 2357 2 0 26.9244; 2358 1.6 0 26.9244; 2359 1.2 0 26.9244;
    2360 0.800001 0 26.9244; 2361 0.400001 0 26.9244; 2362 7.60002 0 27.3203;
    2363 7.20002 0 27.3203; 2364 6.80001 0 27.3203; 2365 6.40001 0 27.3203;
    2366 6.00001 0 27.3203; 2367 5.60001 0 27.3203; 2368 5.20001 0 27.3203;
    2369 4.80001 0 27.3203; 2370 4.40001 0 27.3203; 2371 4.00001 0 27.3203;
    2372 3.60001 0 27.3203; 2373 3.20001 0 27.3203; 2374 2.80001 0 27.3203;
    2375 2.4 0 27.3203; 2376 2 0 27.3203; 2377 1.6 0 27.3203; 2378 1.2 0 27.3203;
    2379 0.800001 0 27.3203; 2380 0.400001 0 27.3203; 2381 7.60001 0 27.7163;
    2382 7.20001 0 27.7163; 2383 6.80001 0 27.7163; 2384 6.40001 0 27.7163;
    2385 6.00001 0 27.7163; 2386 5.60001 0 27.7163; 2387 5.20001 0 27.7163;
    2388 4.80001 0 27.7163; 2389 4.40001 0 27.7163; 2390 4.00001 0 27.7163;
    2391 3.60001 0 27.7163; 2392 3.20001 0 27.7163; 2393 2.80001 0 27.7163;
    2394 2.4 0 27.7163; 2395 2 0 27.7163; 2396 1.6 0 27.7163; 2397 1.2 0 27.7163;
    2398 0.800001 0 27.7163; 2399 0.400001 0 27.7163; 2400 7.60001 0 28.1122;
    2401 7.20002 0 28.1122; 2402 6.80001 0 28.1122; 2403 6.40001 0 28.1122;
    2404 6.00001 0 28.1122; 2405 5.60001 0 28.1122; 2406 5.20001 0 28.1122;
    2407 4.80001 0 28.1122; 2408 4.40001 0 28.1122; 2409 4.00001 0 28.1122;
    2410 3.60001 0 28.1122; 2411 3.20001 0 28.1122; 2412 2.80001 0 28.1122;
    2413 2.4 0 28.1122; 2414 2 0 28.1122; 2415 1.6 0 28.1122; 2416 1.2 0 28.1122;
    2417 0.800001 0 28.1122; 2418 0.400001 0 28.1122; 2419 7.60002 0 28.5082;
    2420 7.20002 0 28.5082; 2421 6.80001 0 28.5082; 2422 6.40001 0 28.5082;
    2423 6.00001 0 28.5082; 2424 5.60001 0 28.5082; 2425 5.20001 0 28.5082;
    2426 4.80001 0 28.5082; 2427 4.40001 0 28.5082; 2428 4.00001 0 28.5082;
    2429 3.60001 0 28.5082; 2430 3.20001 0 28.5082; 2431 2.80001 0 28.5082;
    2432 2.4 0 28.5082; 2433 2 0 28.5082; 2434 1.6 0 28.5082; 2435 1.2 0 28.5082;
    2436 0.800001 0 28.5082; 2437 0.400001 0 28.5082; 2438 7.60001 0 28.9041;
    2439 7.20002 0 28.9041; 2440 6.80001 0 28.9041; 2441 6.40001 0 28.9041;
    2442 6.00001 0 28.9041; 2443 5.60001 0 28.9041; 2444 5.20001 0 28.9041;
    2445 4.80001 0 28.9041; 2446 4.40001 0 28.9041; 2447 4.00001 0 28.9041;
    2448 3.60001 0 28.9041; 2449 3.20001 0 28.9041; 2450 2.80001 0 28.9041;
    2451 2.4 0 28.9041; 2452 2 0 28.9041; 2453 1.6 0 28.9041; 2454 1.2 0 28.9041;
    2455 0.800001 0 28.9041; 2456 0.400001 0 28.9041; 2457 7.60001 0 29.3001;
    2458 7.20001 0 29.3001; 2459 6.80001 0 29.3001; 2460 6.40001 0 29.3001;
    2461 6.00001 0 29.3001; 2462 5.60001 0 29.3001; 2463 5.20001 0 29.3001;
    2464 4.80001 0 29.3001; 2465 4.40001 0 29.3001; 2466 4.00001 0 29.3001;
    2467 3.60001 0 29.3001; 2468 3.20001 0 29.3001; 2469 2.80001 0 29.3001;
    2470 2.4 0 29.3001; 2471 2 0 29.3001; 2472 1.6 0 29.3001; 2473 1.2 0 29.3001;
    2474 0.800001 0 29.3001; 2475 0.400001 0 29.3001;
    ELEMENT INCIDENCES SHELL
    1 1457 1458 1477 1476; 4 5 9 10 11; 5 9 12 13 10; 6 12 14 15 13; 7 14 16 17 15;
    8 16 18 19 17; 9 18 20 21 19; 10 20 22 23 21; 11 22 24 25 23; 12 24 26 27 25;
    13 26 28 29 27; 14 28 30 31 29; 15 30 32 33 31; 16 32 34 35 33; 17 34 36 37 35;
    18 36 38 39 37; 19 38 40 41 39; 20 40 42 43 41; 21 42 44 45 43; 22 44 46 47 45;
    23 46 48 49 47; 24 48 50 51 49; 25 50 52 53 51; 26 52 54 55 53; 27 54 56 57 55;
    28 56 58 59 57; 29 58 60 61 59; 30 60 62 63 61; 31 62 64 65 63; 32 64 66 67 65;
    33 66 68 69 67; 34 68 70 71 69; 35 70 72 73 71; 36 72 74 75 73; 37 74 76 77 75;
    38 76 78 79 77; 39 78 80 81 79; 40 80 82 83 81; 41 82 84 85 83; 42 84 86 87 85;
    43 86 88 89 87; 44 88 90 91 89; 45 90 92 93 91; 46 92 94 95 93; 47 94 96 97 95;
    48 96 98 99 97; 49 98 100 101 99; 50 100 102 103 101; 51 102 104 105 103;
    52 104 106 107 105; 53 106 108 109 107; 54 108 110 111 109; 55 110 112 113 111;
    56 112 114 115 113; 57 114 116 117 115; 58 116 118 119 117; 59 118 120 121 119;
    60 120 122 123 121; 61 122 124 125 123; 62 124 126 127 125; 63 126 128 129 127;
    64 128 130 131 129; 65 130 132 133 131; 66 132 134 135 133; 67 134 136 137 135;
    68 136 138 139 137; 69 138 140 141 139; 70 140 142 143 141; 71 142 144 145 143;
    72 144 146 147 145; 73 146 148 149 147; 74 148 150 151 149; 75 150 152 153 151;
    76 152 154 155 153; 77 154 7 156 155; 78 11 10 157 158; 79 10 13 159 157;
    80 13 15 160 159; 81 15 17 161 160; 82 17 19 162 161; 83 19 21 163 162;
    84 21 23 164 163; 85 23 25 165 164; 86 25 27 166 165; 87 27 29 167 166;
    88 29 31 168 167; 89 31 33 169 168; 90 33 35 170 169; 91 35 37 171 170;
    92 37 39 172 171; 93 39 41 173 172; 94 41 43 174 173; 95 43 45 175 174;
    96 45 47 176 175; 97 47 49 177 176; 98 49 51 178 177; 99 51 53 179 178;
    100 53 55 180 179; 101 55 57 181 180; 102 57 59 182 181; 103 59 61 183 182;
    104 61 63 184 183; 105 63 65 185 184; 106 65 67 186 185; 107 67 69 187 186;
    108 69 71 188 187; 109 71 73 189 188; 110 73 75 190 189; 111 75 77 191 190;
    112 77 79 192 191; 113 79 81 193 192; 114 81 83 194 193; 115 83 85 195 194;
    116 85 87 196 195; 117 87 89 197 196; 118 89 91 198 197; 119 91 93 199 198;
    120 93 95 200 199; 121 95 97 201 200; 122 97 99 202 201; 123 99 101 203 202;
    124 101 103 204 203; 125 103 105 205 204; 126 105 107 206 205;
    127 107 109 207 206; 128 109 111 208 207; 129 111 113 209 208;
    130 113 115 210 209; 131 115 117 211 210; 132 117 119 212 211;
    133 119 121 213 212; 134 121 123 214 213; 135 123 125 215 214;
    136 125 127 216 215; 137 127 129 217 216; 138 129 131 218 217;
    139 131 133 219 218; 140 133 135 220 219; 141 135 137 221 220;
    142 137 139 222 221; 143 139 141 223 222; 144 141 143 224 223;
    145 143 145 225 224; 146 145 147 226 225; 147 147 149 227 226;
    148 149 151 228 227; 149 151 153 229 228; 150 153 155 230 229;
    151 155 156 231 230; 152 158 157 232 233; 153 157 159 234 232;
    154 159 160 235 234; 155 160 161 236 235; 156 161 162 237 236;
    157 162 163 238 237; 158 163 164 239 238; 159 164 165 240 239;
    160 165 166 241 240; 161 166 167 242 241; 162 167 168 243 242;
    163 168 169 244 243; 164 169 170 245 244; 165 170 171 246 245;
    166 171 172 247 246; 167 172 173 248 247; 168 173 174 249 248;
    169 174 175 250 249; 170 175 176 251 250; 171 176 177 252 251;
    172 177 178 253 252; 173 178 179 254 253; 174 179 180 255 254;
    175 180 181 256 255; 176 181 182 257 256; 177 182 183 258 257;
    178 183 184 259 258; 179 184 185 260 259; 180 185 186 261 260;
    181 186 187 262 261; 182 187 188 263 262; 183 188 189 264 263;
    184 189 190 265 264; 185 190 191 266 265; 186 191 192 267 266;
    187 192 193 268 267; 188 193 194 269 268; 189 194 195 270 269;
    190 195 196 271 270; 191 196 197 272 271; 192 197 198 273 272;
    193 198 199 274 273; 194 199 200 275 274; 195 200 201 276 275;
    196 201 202 277 276; 197 202 203 278 277; 198 203 204 279 278;
    199 204 205 280 279; 200 205 206 281 280; 201 206 207 282 281;
    202 207 208 283 282; 203 208 209 284 283; 204 209 210 285 284;
    205 210 211 286 285; 206 211 212 287 286; 207 212 213 288 287;
    208 213 214 289 288; 209 214 215 290 289; 210 215 216 291 290;
    211 216 217 292 291; 212 217 218 293 292; 213 218 219 294 293;
    214 219 220 295 294; 215 220 221 296 295; 216 221 222 297 296;
    217 222 223 298 297; 218 223 224 299 298; 219 224 225 300 299;
    220 225 226 301 300; 221 226 227 302 301; 222 227 228 303 302;
    223 228 229 304 303; 224 229 230 305 304; 225 230 231 306 305;
    226 233 232 307 308; 227 232 234 309 307; 228 234 235 310 309;
    229 235 236 311 310; 230 236 237 312 311; 231 237 238 313 312;
    232 238 239 314 313; 233 239 240 315 314; 234 240 241 316 315;
    235 241 242 317 316; 236 242 243 318 317; 237 243 244 319 318;
    238 244 245 320 319; 239 245 246 321 320; 240 246 247 322 321;
    241 247 248 323 322; 242 248 249 324 323; 243 249 250 325 324;
    244 250 251 326 325; 245 251 252 327 326; 246 252 253 328 327;
    247 253 254 329 328; 248 254 255 330 329; 249 255 256 331 330;
    250 256 257 332 331; 251 257 258 333 332; 252 258 259 334 333;
    253 259 260 335 334; 254 260 261 336 335; 255 261 262 337 336;
    256 262 263 338 337; 257 263 264 339 338; 258 264 265 340 339;
    259 265 266 341 340; 260 266 267 342 341; 261 267 268 343 342;
    262 268 269 344 343; 263 269 270 345 344; 264 270 271 346 345;
    265 271 272 347 346; 266 272 273 348 347; 267 273 274 349 348;
    268 274 275 350 349; 269 275 276 351 350; 270 276 277 352 351;
    271 277 278 353 352; 272 278 279 354 353; 273 279 280 355 354;
    274 280 281 356 355; 275 281 282 357 356; 276 282 283 358 357;
    277 283 284 359 358; 278 284 285 360 359; 279 285 286 361 360;
    280 286 287 362 361; 281 287 288 363 362; 282 288 289 364 363;
    283 289 290 365 364; 284 290 291 366 365; 285 291 292 367 366;
    286 292 293 368 367; 287 293 294 369 368; 288 294 295 370 369;
    289 295 296 371 370; 290 296 297 372 371; 291 297 298 373 372;
    292 298 299 374 373; 293 299 300 375 374; 294 300 301 376 375;
    295 301 302 377 376; 296 302 303 378 377; 297 303 304 379 378;
    298 304 305 380 379; 299 305 306 381 380; 300 308 307 382 383;
    301 307 309 384 382; 302 309 310 385 384; 303 310 311 386 385;
    304 311 312 387 386; 305 312 313 388 387; 306 313 314 389 388;
    307 314 315 390 389; 308 315 316 391 390; 309 316 317 392 391;
    310 317 318 393 392; 311 318 319 394 393; 312 319 320 395 394;
    313 320 321 396 395; 314 321 322 397 396; 315 322 323 398 397;
    316 323 324 399 398; 317 324 325 400 399; 318 325 326 401 400;
    319 326 327 402 401; 320 327 328 403 402; 321 328 329 404 403;
    322 329 330 405 404; 323 330 331 406 405; 324 331 332 407 406;
    325 332 333 408 407; 326 333 334 409 408; 327 334 335 410 409;
    328 335 336 411 410; 329 336 337 412 411; 330 337 338 413 412;
    331 338 339 414 413; 332 339 340 415 414; 333 340 341 416 415;
    334 341 342 417 416; 335 342 343 418 417; 336 343 344 419 418;
    337 344 345 420 419; 338 345 346 421 420; 339 346 347 422 421;
    340 347 348 423 422; 341 348 349 424 423; 342 349 350 425 424;
    343 350 351 426 425; 344 351 352 427 426; 345 352 353 428 427;
    346 353 354 429 428; 347 354 355 430 429; 348 355 356 431 430;
    349 356 357 432 431; 350 357 358 433 432; 351 358 359 434 433;
    352 359 360 435 434; 353 360 361 436 435; 354 361 362 437 436;
    355 362 363 438 437; 356 363 364 439 438; 357 364 365 440 439;
    358 365 366 441 440; 359 366 367 442 441; 360 367 368 443 442;
    361 368 369 444 443; 362 369 370 445 444; 363 370 371 446 445;
    364 371 372 447 446; 365 372 373 448 447; 366 373 374 449 448;
    367 374 375 450 449; 368 375 376 451 450; 369 376 377 452 451;
    370 377 378 453 452; 371 378 379 454 453; 372 379 380 455 454;
    373 380 381 456 455; 374 383 382 457 1; 375 382 384 458 457;
    376 384 385 459 458; 377 385 386 460 459; 378 386 387 461 460;
    379 387 388 462 461; 380 388 389 463 462; 381 389 390 464 463;
    382 390 391 465 464; 383 391 392 466 465; 384 392 393 467 466;
    385 393 394 468 467; 386 394 395 469 468; 387 395 396 470 469;
    388 396 397 471 470; 389 397 398 472 471; 390 398 399 473 472;
    391 399 400 474 473; 392 400 401 475 474; 393 401 402 476 475;
    394 402 403 477 476; 395 403 404 478 477; 396 404 405 479 478;
    397 405 406 480 479; 398 406 407 481 480; 399 407 408 482 481;
    400 408 409 483 482; 401 409 410 484 483; 402 410 411 485 484;
    403 411 412 486 485; 404 412 413 487 486; 405 413 414 488 487;
    406 414 415 489 488; 407 415 416 490 489; 408 416 417 491 490;
    409 417 418 492 491; 410 418 419 493 492; 411 419 420 494 493;
    412 420 421 495 494; 413 421 422 496 495; 414 422 423 497 496;
    415 423 424 498 497; 416 424 425 499 498; 417 425 426 500 499;
    418 426 427 501 500; 419 427 428 502 501; 420 428 429 503 502;
    421 429 430 504 503; 422 430 431 505 504; 423 431 432 506 505;
    424 432 433 507 506; 425 433 434 508 507; 426 434 435 509 508;
    427 435 436 510 509; 428 436 437 511 510; 429 437 438 512 511;
    430 438 439 513 512; 431 439 440 514 513; 432 440 441 515 514;
    433 441 442 516 515; 434 442 443 517 516; 435 443 444 518 517;
    436 444 445 519 518; 437 445 446 520 519; 438 446 447 521 520;
    439 447 448 522 521; 440 448 449 523 522; 441 449 450 524 523;
    442 450 451 525 524; 443 451 452 526 525; 444 452 453 527 526;
    445 453 454 528 527; 446 454 455 529 528; 447 455 456 3 529; 448 8 530 531 532;
    449 530 533 534 531; 450 533 535 536 534; 451 535 537 538 536;
    452 537 539 540 538; 453 539 541 542 540; 454 541 543 544 542;
    455 543 545 546 544; 456 545 547 548 546; 457 547 549 550 548;
    458 549 551 552 550; 459 551 553 554 552; 460 553 555 556 554;
    461 555 557 558 556; 462 557 559 560 558; 463 559 561 562 560;
    464 561 563 564 562; 465 563 565 566 564; 466 565 567 568 566;
    467 567 569 570 568; 468 569 571 572 570; 469 571 573 574 572;
    470 573 575 576 574; 471 575 577 578 576; 472 577 579 580 578;
    473 579 581 582 580; 474 581 583 584 582; 475 583 585 586 584;
    476 585 587 588 586; 477 587 589 590 588; 478 589 591 592 590;
    479 591 593 594 592; 480 593 595 596 594; 481 595 597 598 596;
    482 597 599 600 598; 483 599 601 602 600; 484 601 603 604 602;
    485 603 605 606 604; 486 605 607 608 606; 487 607 609 610 608;
    488 609 611 612 610; 489 611 613 614 612; 490 613 615 616 614;
    491 615 617 618 616; 492 617 619 620 618; 493 619 621 622 620;
    494 621 623 624 622; 495 623 625 626 624; 496 625 627 628 626;
    497 627 629 630 628; 498 629 631 632 630; 499 631 633 634 632;
    500 633 635 636 634; 501 635 637 638 636; 502 637 639 640 638;
    503 639 641 642 640; 504 641 643 644 642; 505 643 645 646 644;
    506 645 647 648 646; 507 647 649 650 648; 508 649 651 652 650;
    509 651 653 654 652; 510 653 655 656 654; 511 655 657 658 656;
    512 657 659 660 658; 513 659 661 662 660; 514 661 663 664 662;
    515 663 665 666 664; 516 665 667 668 666; 517 667 669 670 668;
    518 669 671 672 670; 519 671 673 674 672; 520 673 675 676 674;
    521 675 6 677 676; 522 532 531 678 679; 523 531 534 680 678;
    524 534 536 681 680; 525 536 538 682 681; 526 538 540 683 682;
    527 540 542 684 683; 528 542 544 685 684; 529 544 546 686 685;
    530 546 548 687 686; 531 548 550 688 687; 532 550 552 689 688;
    533 552 554 690 689; 534 554 556 691 690; 535 556 558 692 691;
    536 558 560 693 692; 537 560 562 694 693; 538 562 564 695 694;
    539 564 566 696 695; 540 566 568 697 696; 541 568 570 698 697;
    542 570 572 699 698; 543 572 574 700 699; 544 574 576 701 700;
    545 576 578 702 701; 546 578 580 703 702; 547 580 582 704 703;
    548 582 584 705 704; 549 584 586 706 705; 550 586 588 707 706;
    551 588 590 708 707; 552 590 592 709 708; 553 592 594 710 709;
    554 594 596 711 710; 555 596 598 712 711; 556 598 600 713 712;
    557 600 602 714 713; 558 602 604 715 714; 559 604 606 716 715;
    560 606 608 717 716; 561 608 610 718 717; 562 610 612 719 718;
    563 612 614 720 719; 564 614 616 721 720; 565 616 618 722 721;
    566 618 620 723 722; 567 620 622 724 723; 568 622 624 725 724;
    569 624 626 726 725; 570 626 628 727 726; 571 628 630 728 727;
    572 630 632 729 728; 573 632 634 730 729; 574 634 636 731 730;
    575 636 638 732 731; 576 638 640 733 732; 577 640 642 734 733;
    578 642 644 735 734; 579 644 646 736 735; 580 646 648 737 736;
    581 648 650 738 737; 582 650 652 739 738; 583 652 654 740 739;
    584 654 656 741 740; 585 656 658 742 741; 586 658 660 743 742;
    587 660 662 744 743; 588 662 664 745 744; 589 664 666 746 745;
    590 666 668 747 746; 591 668 670 748 747; 592 670 672 749 748;
    593 672 674 750 749; 594 674 676 751 750; 595 676 677 752 751;
    596 679 678 753 754; 597 678 680 755 753; 598 680 681 756 755;
    599 681 682 757 756; 600 682 683 758 757; 601 683 684 759 758;
    602 684 685 760 759; 603 685 686 761 760; 604 686 687 762 761;
    605 687 688 763 762; 606 688 689 764 763; 607 689 690 765 764;
    608 690 691 766 765; 609 691 692 767 766; 610 692 693 768 767;
    611 693 694 769 768; 612 694 695 770 769; 613 695 696 771 770;
    614 696 697 772 771; 615 697 698 773 772; 616 698 699 774 773;
    617 699 700 775 774; 618 700 701 776 775; 619 701 702 777 776;
    620 702 703 778 777; 621 703 704 779 778; 622 704 705 780 779;
    623 705 706 781 780; 624 706 707 782 781; 625 707 708 783 782;
    626 708 709 784 783; 627 709 710 785 784; 628 710 711 786 785;
    629 711 712 787 786; 630 712 713 788 787; 631 713 714 789 788;
    632 714 715 790 789; 633 715 716 791 790; 634 716 717 792 791;
    635 717 718 793 792; 636 718 719 794 793; 637 719 720 795 794;
    638 720 721 796 795; 639 721 722 797 796; 640 722 723 798 797;
    641 723 724 799 798; 642 724 725 800 799; 643 725 726 801 800;
    644 726 727 802 801; 645 727 728 803 802; 646 728 729 804 803;
    647 729 730 805 804; 648 730 731 806 805; 649 731 732 807 806;
    650 732 733 808 807; 651 733 734 809 808; 652 734 735 810 809;
    653 735 736 811 810; 654 736 737 812 811; 655 737 738 813 812;
    656 738 739 814 813; 657 739 740 815 814; 658 740 741 816 815;
    659 741 742 817 816; 660 742 743 818 817; 661 743 744 819 818;
    662 744 745 820 819; 663 745 746 821 820; 664 746 747 822 821;
    665 747 748 823 822; 666 748 749 824 823; 667 749 750 825 824;
    668 750 751 826 825; 669 751 752 827 826; 670 754 753 828 829;
    671 753 755 830 828; 672 755 756 831 830; 673 756 757 832 831;
    674 757 758 833 832; 675 758 759 834 833; 676 759 760 835 834;
    677 760 761 836 835; 678 761 762 837 836; 679 762 763 838 837;
    680 763 764 839 838; 681 764 765 840 839; 682 765 766 841 840;
    683 766 767 842 841; 684 767 768 843 842; 685 768 769 844 843;
    686 769 770 845 844; 687 770 771 846 845; 688 771 772 847 846;
    689 772 773 848 847; 690 773 774 849 848; 691 774 775 850 849;
    692 775 776 851 850; 693 776 777 852 851; 694 777 778 853 852;
    695 778 779 854 853; 696 779 780 855 854; 697 780 781 856 855;
    698 781 782 857 856; 699 782 783 858 857; 700 783 784 859 858;
    701 784 785 860 859; 702 785 786 861 860; 703 786 787 862 861;
    704 787 788 863 862; 705 788 789 864 863; 706 789 790 865 864;
    707 790 791 866 865; 708 791 792 867 866; 709 792 793 868 867;
    710 793 794 869 868; 711 794 795 870 869; 712 795 796 871 870;
    713 796 797 872 871; 714 797 798 873 872; 715 798 799 874 873;
    716 799 800 875 874; 717 800 801 876 875; 718 801 802 877 876;
    719 802 803 878 877; 720 803 804 879 878; 721 804 805 880 879;
    722 805 806 881 880; 723 806 807 882 881; 724 807 808 883 882;
    725 808 809 884 883; 726 809 810 885 884; 727 810 811 886 885;
    728 811 812 887 886; 729 812 813 888 887; 730 813 814 889 888;
    731 814 815 890 889; 732 815 816 891 890; 733 816 817 892 891;
    734 817 818 893 892; 735 818 819 894 893; 736 819 820 895 894;
    737 820 821 896 895; 738 821 822 897 896; 739 822 823 898 897;
    740 823 824 899 898; 741 824 825 900 899; 742 825 826 901 900;
    743 826 827 902 901; 744 829 828 903 904; 745 828 830 905 903;
    746 830 831 906 905; 747 831 832 907 906; 748 832 833 908 907;
    749 833 834 909 908; 750 834 835 910 909; 751 835 836 911 910;
    752 836 837 912 911; 753 837 838 913 912; 754 838 839 914 913;
    755 839 840 915 914; 756 840 841 916 915; 757 841 842 917 916;
    758 842 843 918 917; 759 843 844 919 918; 760 844 845 920 919;
    761 845 846 921 920; 762 846 847 922 921; 763 847 848 923 922;
    764 848 849 924 923; 765 849 850 925 924; 766 850 851 926 925;
    767 851 852 927 926; 768 852 853 928 927; 769 853 854 929 928;
    770 854 855 930 929; 771 855 856 931 930; 772 856 857 932 931;
    773 857 858 933 932; 774 858 859 934 933; 775 859 860 935 934;
    776 860 861 936 935; 777 861 862 937 936; 778 862 863 938 937;
    779 863 864 939 938; 780 864 865 940 939; 781 865 866 941 940;
    782 866 867 942 941; 783 867 868 943 942; 784 868 869 944 943;
    785 869 870 945 944; 786 870 871 946 945; 787 871 872 947 946;
    788 872 873 948 947; 789 873 874 949 948; 790 874 875 950 949;
    791 875 876 951 950; 792 876 877 952 951; 793 877 878 953 952;
    794 878 879 954 953; 795 879 880 955 954; 796 880 881 956 955;
    797 881 882 957 956; 798 882 883 958 957; 799 883 884 959 958;
    800 884 885 960 959; 801 885 886 961 960; 802 886 887 962 961;
    803 887 888 963 962; 804 888 889 964 963; 805 889 890 965 964;
    806 890 891 966 965; 807 891 892 967 966; 808 892 893 968 967;
    809 893 894 969 968; 810 894 895 970 969; 811 895 896 971 970;
    812 896 897 972 971; 813 897 898 973 972; 814 898 899 974 973;
    815 899 900 975 974; 816 900 901 976 975; 817 901 902 977 976;
    818 904 903 978 4; 819 903 905 979 978; 820 905 906 980 979;
    821 906 907 981 980; 822 907 908 982 981; 823 908 909 983 982;
    824 909 910 984 983; 825 910 911 985 984; 826 911 912 986 985;
    827 912 913 987 986; 828 913 914 988 987; 829 914 915 989 988;
    830 915 916 990 989; 831 916 917 991 990; 832 917 918 992 991;
    833 918 919 993 992; 834 919 920 994 993; 835 920 921 995 994;
    836 921 922 996 995; 837 922 923 997 996; 838 923 924 998 997;
    839 924 925 999 998; 840 925 926 1000 999; 841 926 927 1001 1000;
    842 927 928 1002 1001; 843 928 929 1003 1002; 844 929 930 1004 1003;
    845 930 931 1005 1004; 846 931 932 1006 1005; 847 932 933 1007 1006;
    848 933 934 1008 1007; 849 934 935 1009 1008; 850 935 936 1010 1009;
    851 936 937 1011 1010; 852 937 938 1012 1011; 853 938 939 1013 1012;
    854 939 940 1014 1013; 855 940 941 1015 1014; 856 941 942 1016 1015;
    857 942 943 1017 1016; 858 943 944 1018 1017; 859 944 945 1019 1018;
    860 945 946 1020 1019; 861 946 947 1021 1020; 862 947 948 1022 1021;
    863 948 949 1023 1022; 864 949 950 1024 1023; 865 950 951 1025 1024;
    866 951 952 1026 1025; 867 952 953 1027 1026; 868 953 954 1028 1027;
    869 954 955 1029 1028; 870 955 956 1030 1029; 871 956 957 1031 1030;
    872 957 958 1032 1031; 873 958 959 1033 1032; 874 959 960 1034 1033;
    875 960 961 1035 1034; 876 961 962 1036 1035; 877 962 963 1037 1036;
    878 963 964 1038 1037; 879 964 965 1039 1038; 880 965 966 1040 1039;
    881 966 967 1041 1040; 882 967 968 1042 1041; 883 968 969 1043 1042;
    884 969 970 1044 1043; 885 970 971 1045 1044; 886 971 972 1046 1045;
    887 972 973 1047 1046; 888 973 974 1048 1047; 889 974 975 1049 1048;
    890 975 976 1050 1049; 891 976 977 2 1050; 892 2 1051 1052 1050;
    893 1051 1053 1054 1052; 894 1053 1055 1056 1054; 895 1055 1057 1058 1056;
    896 1057 1059 1060 1058; 897 1059 1061 1062 1060; 898 1061 1063 1064 1062;
    899 1063 1065 1066 1064; 900 1065 1067 1068 1066; 901 1067 1069 1070 1068;
    902 1069 1071 1072 1070; 903 1071 1073 1074 1072; 904 1073 1075 1076 1074;
    905 1075 1077 1078 1076; 906 1077 1079 1080 1078; 907 1079 1081 1082 1080;
    908 1081 1083 1084 1082; 909 1083 1085 1086 1084; 910 1085 1087 1088 1086;
    911 1087 1 457 1088; 912 1050 1052 1089 1049; 913 1052 1054 1090 1089;
    914 1054 1056 1091 1090; 915 1056 1058 1092 1091; 916 1058 1060 1093 1092;
    917 1060 1062 1094 1093; 918 1062 1064 1095 1094; 919 1064 1066 1096 1095;
    920 1066 1068 1097 1096; 921 1068 1070 1098 1097; 922 1070 1072 1099 1098;
    923 1072 1074 1100 1099; 924 1074 1076 1101 1100; 925 1076 1078 1102 1101;
    926 1078 1080 1103 1102; 927 1080 1082 1104 1103; 928 1082 1084 1105 1104;
    929 1084 1086 1106 1105; 930 1086 1088 1107 1106; 931 1088 457 458 1107;
    932 1049 1089 1108 1048; 933 1089 1090 1109 1108; 934 1090 1091 1110 1109;
    935 1091 1092 1111 1110; 936 1092 1093 1112 1111; 937 1093 1094 1113 1112;
    938 1094 1095 1114 1113; 939 1095 1096 1115 1114; 940 1096 1097 1116 1115;
    941 1097 1098 1117 1116; 942 1098 1099 1118 1117; 943 1099 1100 1119 1118;
    944 1100 1101 1120 1119; 945 1101 1102 1121 1120; 946 1102 1103 1122 1121;
    947 1103 1104 1123 1122; 948 1104 1105 1124 1123; 949 1105 1106 1125 1124;
    950 1106 1107 1126 1125; 951 1107 458 459 1126; 952 1048 1108 1127 1047;
    953 1108 1109 1128 1127; 954 1109 1110 1129 1128; 955 1110 1111 1130 1129;
    956 1111 1112 1131 1130; 957 1112 1113 1132 1131; 958 1113 1114 1133 1132;
    959 1114 1115 1134 1133; 960 1115 1116 1135 1134; 961 1116 1117 1136 1135;
    962 1117 1118 1137 1136; 963 1118 1119 1138 1137; 964 1119 1120 1139 1138;
    965 1120 1121 1140 1139; 966 1121 1122 1141 1140; 967 1122 1123 1142 1141;
    968 1123 1124 1143 1142; 969 1124 1125 1144 1143; 970 1125 1126 1145 1144;
    971 1126 459 460 1145; 972 1047 1127 1146 1046; 973 1127 1128 1147 1146;
    974 1128 1129 1148 1147; 975 1129 1130 1149 1148; 976 1130 1131 1150 1149;
    977 1131 1132 1151 1150; 978 1132 1133 1152 1151; 979 1133 1134 1153 1152;
    980 1134 1135 1154 1153; 981 1135 1136 1155 1154; 982 1136 1137 1156 1155;
    983 1137 1138 1157 1156; 984 1138 1139 1158 1157; 985 1139 1140 1159 1158;
    986 1140 1141 1160 1159; 987 1141 1142 1161 1160; 988 1142 1143 1162 1161;
    989 1143 1144 1163 1162; 990 1144 1145 1164 1163; 991 1145 460 461 1164;
    992 1046 1146 1165 1045; 993 1146 1147 1166 1165; 994 1147 1148 1167 1166;
    995 1148 1149 1168 1167; 996 1149 1150 1169 1168; 997 1150 1151 1170 1169;
    998 1151 1152 1171 1170; 999 1152 1153 1172 1171; 1000 1153 1154 1173 1172;
    1001 1154 1155 1174 1173; 1002 1155 1156 1175 1174; 1003 1156 1157 1176 1175;
    1004 1157 1158 1177 1176; 1005 1158 1159 1178 1177; 1006 1159 1160 1179 1178;
    1007 1160 1161 1180 1179; 1008 1161 1162 1181 1180; 1009 1162 1163 1182 1181;
    1010 1163 1164 1183 1182; 1011 1164 461 462 1183; 1012 1045 1165 1184 1044;
    1013 1165 1166 1185 1184; 1014 1166 1167 1186 1185; 1015 1167 1168 1187 1186;
    1016 1168 1169 1188 1187; 1017 1169 1170 1189 1188; 1018 1170 1171 1190 1189;
    1019 1171 1172 1191 1190; 1020 1172 1173 1192 1191; 1021 1173 1174 1193 1192;
    1022 1174 1175 1194 1193; 1023 1175 1176 1195 1194; 1024 1176 1177 1196 1195;
    1025 1177 1178 1197 1196; 1026 1178 1179 1198 1197; 1027 1179 1180 1199 1198;
    1028 1180 1181 1200 1199; 1029 1181 1182 1201 1200; 1030 1182 1183 1202 1201;
    1031 1183 462 463 1202; 1032 1044 1184 1203 1043; 1033 1184 1185 1204 1203;
    1034 1185 1186 1205 1204; 1035 1186 1187 1206 1205; 1036 1187 1188 1207 1206;
    1037 1188 1189 1208 1207; 1038 1189 1190 1209 1208; 1039 1190 1191 1210 1209;
    1040 1191 1192 1211 1210; 1041 1192 1193 1212 1211; 1042 1193 1194 1213 1212;
    1043 1194 1195 1214 1213; 1044 1195 1196 1215 1214; 1045 1196 1197 1216 1215;
    1046 1197 1198 1217 1216; 1047 1198 1199 1218 1217; 1048 1199 1200 1219 1218;
    1049 1200 1201 1220 1219; 1050 1201 1202 1221 1220; 1051 1202 463 464 1221;
    1052 1043 1203 1222 1042; 1053 1203 1204 1223 1222; 1054 1204 1205 1224 1223;
    1055 1205 1206 1225 1224; 1056 1206 1207 1226 1225; 1057 1207 1208 1227 1226;
    1058 1208 1209 1228 1227; 1059 1209 1210 1229 1228; 1060 1210 1211 1230 1229;
    1061 1211 1212 1231 1230; 1062 1212 1213 1232 1231; 1063 1213 1214 1233 1232;
    1064 1214 1215 1234 1233; 1065 1215 1216 1235 1234; 1066 1216 1217 1236 1235;
    1067 1217 1218 1237 1236; 1068 1218 1219 1238 1237; 1069 1219 1220 1239 1238;
    1070 1220 1221 1240 1239; 1071 1221 464 465 1240; 1072 1042 1222 1241 1041;
    1073 1222 1223 1242 1241; 1074 1223 1224 1243 1242; 1075 1224 1225 1244 1243;
    1076 1225 1226 1245 1244; 1077 1226 1227 1246 1245; 1078 1227 1228 1247 1246;
    1079 1228 1229 1248 1247; 1080 1229 1230 1249 1248; 1081 1230 1231 1250 1249;
    1082 1231 1232 1251 1250; 1083 1232 1233 1252 1251; 1084 1233 1234 1253 1252;
    1085 1234 1235 1254 1253; 1086 1235 1236 1255 1254; 1087 1236 1237 1256 1255;
    1088 1237 1238 1257 1256; 1089 1238 1239 1258 1257; 1090 1239 1240 1259 1258;
    1091 1240 465 466 1259; 1092 1041 1241 1260 1040; 1093 1241 1242 1261 1260;
    1094 1242 1243 1262 1261; 1095 1243 1244 1263 1262; 1096 1244 1245 1264 1263;
    1097 1245 1246 1265 1264; 1098 1246 1247 1266 1265; 1099 1247 1248 1267 1266;
    1100 1248 1249 1268 1267; 1101 1249 1250 1269 1268; 1102 1250 1251 1270 1269;
    1103 1251 1252 1271 1270; 1104 1252 1253 1272 1271; 1105 1253 1254 1273 1272;
    1106 1254 1255 1274 1273; 1107 1255 1256 1275 1274; 1108 1256 1257 1276 1275;
    1109 1257 1258 1277 1276; 1110 1258 1259 1278 1277; 1111 1259 466 467 1278;
    1112 1040 1260 1279 1039; 1113 1260 1261 1280 1279; 1114 1261 1262 1281 1280;
    1115 1262 1263 1282 1281; 1116 1263 1264 1283 1282; 1117 1264 1265 1284 1283;
    1118 1265 1266 1285 1284; 1119 1266 1267 1286 1285; 1120 1267 1268 1287 1286;
    1121 1268 1269 1288 1287; 1122 1269 1270 1289 1288; 1123 1270 1271 1290 1289;
    1124 1271 1272 1291 1290; 1125 1272 1273 1292 1291; 1126 1273 1274 1293 1292;
    1127 1274 1275 1294 1293; 1128 1275 1276 1295 1294; 1129 1276 1277 1296 1295;
    1130 1277 1278 1297 1296; 1131 1278 467 468 1297; 1132 1039 1279 1298 1038;
    1133 1279 1280 1299 1298; 1134 1280 1281 1300 1299; 1135 1281 1282 1301 1300;
    1136 1282 1283 1302 1301; 1137 1283 1284 1303 1302; 1138 1284 1285 1304 1303;
    1139 1285 1286 1305 1304; 1140 1286 1287 1306 1305; 1141 1287 1288 1307 1306;
    1142 1288 1289 1308 1307; 1143 1289 1290 1309 1308; 1144 1290 1291 1310 1309;
    1145 1291 1292 1311 1310; 1146 1292 1293 1312 1311; 1147 1293 1294 1313 1312;
    1148 1294 1295 1314 1313; 1149 1295 1296 1315 1314; 1150 1296 1297 1316 1315;
    1151 1297 468 469 1316; 1152 1038 1298 1317 1037; 1153 1298 1299 1318 1317;
    1154 1299 1300 1319 1318; 1155 1300 1301 1320 1319; 1156 1301 1302 1321 1320;
    1157 1302 1303 1322 1321; 1158 1303 1304 1323 1322; 1159 1304 1305 1324 1323;
    1160 1305 1306 1325 1324; 1161 1306 1307 1326 1325; 1162 1307 1308 1327 1326;
    1163 1308 1309 1328 1327; 1164 1309 1310 1329 1328; 1165 1310 1311 1330 1329;
    1166 1311 1312 1331 1330; 1167 1312 1313 1332 1331; 1168 1313 1314 1333 1332;
    1169 1314 1315 1334 1333; 1170 1315 1316 1335 1334; 1171 1316 469 470 1335;
    1172 1037 1317 1336 1036; 1173 1317 1318 1337 1336; 1174 1318 1319 1338 1337;
    1175 1319 1320 1339 1338; 1176 1320 1321 1340 1339; 1177 1321 1322 1341 1340;
    1178 1322 1323 1342 1341; 1179 1323 1324 1343 1342; 1180 1324 1325 1344 1343;
    1181 1325 1326 1345 1344; 1182 1326 1327 1346 1345; 1183 1327 1328 1347 1346;
    1184 1328 1329 1348 1347; 1185 1329 1330 1349 1348; 1186 1330 1331 1350 1349;
    1187 1331 1332 1351 1350; 1188 1332 1333 1352 1351; 1189 1333 1334 1353 1352;
    1190 1334 1335 1354 1353; 1191 1335 470 471 1354; 1192 1036 1336 1355 1035;
    1193 1336 1337 1356 1355; 1194 1337 1338 1357 1356; 1195 1338 1339 1358 1357;
    1196 1339 1340 1359 1358; 1197 1340 1341 1360 1359; 1198 1341 1342 1361 1360;
    1199 1342 1343 1362 1361; 1200 1343 1344 1363 1362; 1201 1344 1345 1364 1363;
    1202 1345 1346 1365 1364; 1203 1346 1347 1366 1365; 1204 1347 1348 1367 1366;
    1205 1348 1349 1368 1367; 1206 1349 1350 1369 1368; 1207 1350 1351 1370 1369;
    1208 1351 1352 1371 1370; 1209 1352 1353 1372 1371; 1210 1353 1354 1373 1372;
    1211 1354 471 472 1373; 1212 1035 1355 1374 1034; 1213 1355 1356 1375 1374;
    1214 1356 1357 1376 1375; 1215 1357 1358 1377 1376; 1216 1358 1359 1378 1377;
    1217 1359 1360 1379 1378; 1218 1360 1361 1380 1379; 1219 1361 1362 1381 1380;
    1220 1362 1363 1382 1381; 1221 1363 1364 1383 1382; 1222 1364 1365 1384 1383;
    1223 1365 1366 1385 1384; 1224 1366 1367 1386 1385; 1225 1367 1368 1387 1386;
    1226 1368 1369 1388 1387; 1227 1369 1370 1389 1388; 1228 1370 1371 1390 1389;
    1229 1371 1372 1391 1390; 1230 1372 1373 1392 1391; 1231 1373 472 473 1392;
    1232 1034 1374 1393 1033; 1233 1374 1375 1394 1393; 1234 1375 1376 1395 1394;
    1235 1376 1377 1396 1395; 1236 1377 1378 1397 1396; 1237 1378 1379 1398 1397;
    1238 1379 1380 1399 1398; 1239 1380 1381 1400 1399; 1240 1381 1382 1401 1400;
    1241 1382 1383 1402 1401; 1242 1383 1384 1403 1402; 1243 1384 1385 1404 1403;
    1244 1385 1386 1405 1404; 1245 1386 1387 1406 1405; 1246 1387 1388 1407 1406;
    1247 1388 1389 1408 1407; 1248 1389 1390 1409 1408; 1249 1390 1391 1410 1409;
    1250 1391 1392 1411 1410; 1251 1392 473 474 1411; 1252 1033 1393 1412 1032;
    1253 1393 1394 1413 1412; 1254 1394 1395 1414 1413; 1255 1395 1396 1415 1414;
    1256 1396 1397 1416 1415; 1257 1397 1398 1417 1416; 1258 1398 1399 1418 1417;
    1259 1399 1400 1419 1418; 1260 1400 1401 1420 1419; 1261 1401 1402 1421 1420;
    1262 1402 1403 1422 1421; 1263 1403 1404 1423 1422; 1264 1404 1405 1424 1423;
    1265 1405 1406 1425 1424; 1266 1406 1407 1426 1425; 1267 1407 1408 1427 1426;
    1268 1408 1409 1428 1427; 1269 1409 1410 1429 1428; 1270 1410 1411 1430 1429;
    1271 1411 474 475 1430; 1272 1032 1412 1431 1031; 1273 1412 1413 1432 1431;
    1274 1413 1414 1433 1432; 1275 1414 1415 1434 1433; 1276 1415 1416 1435 1434;
    1277 1416 1417 1436 1435; 1278 1417 1418 1437 1436; 1279 1418 1419 1438 1437;
    1280 1419 1420 1439 1438; 1281 1420 1421 1440 1439; 1282 1421 1422 1441 1440;
    1283 1422 1423 1442 1441; 1284 1423 1424 1443 1442; 1285 1424 1425 1444 1443;
    1286 1425 1426 1445 1444; 1287 1426 1427 1446 1445; 1288 1427 1428 1447 1446;
    1289 1428 1429 1448 1447; 1290 1429 1430 1449 1448; 1291 1430 475 476 1449;
    1292 1031 1431 1450 1030; 1293 1431 1432 1451 1450; 1294 1432 1433 1452 1451;
    1295 1433 1434 1453 1452; 1296 1434 1435 1454 1453; 1297 1435 1436 1455 1454;
    1298 1436 1437 1456 1455; 1299 1437 1438 1457 1456; 1300 1438 1439 1458 1457;
    1301 1439 1440 1459 1458; 1302 1440 1441 1460 1459; 1303 1441 1442 1461 1460;
    1304 1442 1443 1462 1461; 1305 1443 1444 1463 1462; 1306 1444 1445 1464 1463;
    1307 1445 1446 1465 1464; 1308 1446 1447 1466 1465; 1309 1447 1448 1467 1466;
    1310 1448 1449 1468 1467; 1311 1449 476 477 1468; 1312 1030 1450 1469 1029;
    1313 1450 1451 1470 1469; 1314 1451 1452 1471 1470; 1315 1452 1453 1472 1471;
    1316 1453 1454 1473 1472; 1317 1454 1455 1474 1473; 1318 1455 1456 1475 1474;
    1319 1456 1457 1476 1475; 1321 1458 1459 1478 1477; 1322 1459 1460 1479 1478;
    1323 1460 1461 1480 1479; 1324 1461 1462 1481 1480; 1325 1462 1463 1482 1481;
    1326 1463 1464 1483 1482; 1327 1464 1465 1484 1483; 1328 1465 1466 1485 1484;
    1329 1466 1467 1486 1485; 1330 1467 1468 1487 1486; 1331 1468 477 478 1487;
    1332 1029 1469 1488 1028; 1333 1469 1470 1489 1488; 1334 1470 1471 1490 1489;
    1335 1471 1472 1491 1490; 1336 1472 1473 1492 1491; 1337 1473 1474 1493 1492;
    1338 1474 1475 1494 1493; 1339 1475 1476 1495 1494; 1340 1476 1477 1496 1495;
    1341 1477 1478 1497 1496; 1342 1478 1479 1498 1497; 1343 1479 1480 1499 1498;
    1344 1480 1481 1500 1499; 1345 1481 1482 1501 1500; 1346 1482 1483 1502 1501;
    1347 1483 1484 1503 1502; 1348 1484 1485 1504 1503; 1349 1485 1486 1505 1504;
    1350 1486 1487 1506 1505; 1351 1487 478 479 1506; 1352 1028 1488 1507 1027;
    1353 1488 1489 1508 1507; 1354 1489 1490 1509 1508; 1355 1490 1491 1510 1509;
    1356 1491 1492 1511 1510; 1357 1492 1493 1512 1511; 1358 1493 1494 1513 1512;
    1359 1494 1495 1514 1513; 1360 1495 1496 1515 1514; 1361 1496 1497 1516 1515;
    1362 1497 1498 1517 1516; 1363 1498 1499 1518 1517; 1364 1499 1500 1519 1518;
    1365 1500 1501 1520 1519; 1366 1501 1502 1521 1520; 1367 1502 1503 1522 1521;
    1368 1503 1504 1523 1522; 1369 1504 1505 1524 1523; 1370 1505 1506 1525 1524;
    1371 1506 479 480 1525; 1372 1027 1507 1526 1026; 1373 1507 1508 1527 1526;
    1374 1508 1509 1528 1527; 1375 1509 1510 1529 1528; 1376 1510 1511 1530 1529;
    1377 1511 1512 1531 1530; 1378 1512 1513 1532 1531; 1379 1513 1514 1533 1532;
    1380 1514 1515 1534 1533; 1381 1515 1516 1535 1534; 1382 1516 1517 1536 1535;
    1383 1517 1518 1537 1536; 1384 1518 1519 1538 1537; 1385 1519 1520 1539 1538;
    1386 1520 1521 1540 1539; 1387 1521 1522 1541 1540; 1388 1522 1523 1542 1541;
    1389 1523 1524 1543 1542; 1390 1524 1525 1544 1543; 1391 1525 480 481 1544;
    1392 1026 1526 1545 1025; 1393 1526 1527 1546 1545; 1394 1527 1528 1547 1546;
    1395 1528 1529 1548 1547; 1396 1529 1530 1549 1548; 1397 1530 1531 1550 1549;
    1398 1531 1532 1551 1550; 1399 1532 1533 1552 1551; 1400 1533 1534 1553 1552;
    1401 1534 1535 1554 1553; 1402 1535 1536 1555 1554; 1403 1536 1537 1556 1555;
    1404 1537 1538 1557 1556; 1405 1538 1539 1558 1557; 1406 1539 1540 1559 1558;
    1407 1540 1541 1560 1559; 1408 1541 1542 1561 1560; 1409 1542 1543 1562 1561;
    1410 1543 1544 1563 1562; 1411 1544 481 482 1563; 1412 1025 1545 1564 1024;
    1413 1545 1546 1565 1564; 1414 1546 1547 1566 1565; 1415 1547 1548 1567 1566;
    1416 1548 1549 1568 1567; 1417 1549 1550 1569 1568; 1418 1550 1551 1570 1569;
    1419 1551 1552 1571 1570; 1420 1552 1553 1572 1571; 1421 1553 1554 1573 1572;
    1422 1554 1555 1574 1573; 1423 1555 1556 1575 1574; 1424 1556 1557 1576 1575;
    1425 1557 1558 1577 1576; 1426 1558 1559 1578 1577; 1427 1559 1560 1579 1578;
    1428 1560 1561 1580 1579; 1429 1561 1562 1581 1580; 1430 1562 1563 1582 1581;
    1431 1563 482 483 1582; 1432 1024 1564 1583 1023; 1433 1564 1565 1584 1583;
    1434 1565 1566 1585 1584; 1435 1566 1567 1586 1585; 1436 1567 1568 1587 1586;
    1437 1568 1569 1588 1587; 1438 1569 1570 1589 1588; 1439 1570 1571 1590 1589;
    1440 1571 1572 1591 1590; 1441 1572 1573 1592 1591; 1442 1573 1574 1593 1592;
    1443 1574 1575 1594 1593; 1444 1575 1576 1595 1594; 1445 1576 1577 1596 1595;
    1446 1577 1578 1597 1596; 1447 1578 1579 1598 1597; 1448 1579 1580 1599 1598;
    1449 1580 1581 1600 1599; 1450 1581 1582 1601 1600; 1451 1582 483 484 1601;
    1452 1023 1583 1602 1022; 1453 1583 1584 1603 1602; 1454 1584 1585 1604 1603;
    1455 1585 1586 1605 1604; 1456 1586 1587 1606 1605; 1457 1587 1588 1607 1606;
    1458 1588 1589 1608 1607; 1459 1589 1590 1609 1608; 1460 1590 1591 1610 1609;
    1461 1591 1592 1611 1610; 1462 1592 1593 1612 1611; 1463 1593 1594 1613 1612;
    1464 1594 1595 1614 1613; 1465 1595 1596 1615 1614; 1466 1596 1597 1616 1615;
    1467 1597 1598 1617 1616; 1468 1598 1599 1618 1617; 1469 1599 1600 1619 1618;
    1470 1600 1601 1620 1619; 1471 1601 484 485 1620; 1472 1022 1602 1621 1021;
    1473 1602 1603 1622 1621; 1474 1603 1604 1623 1622; 1475 1604 1605 1624 1623;
    1476 1605 1606 1625 1624; 1477 1606 1607 1626 1625; 1478 1607 1608 1627 1626;
    1479 1608 1609 1628 1627; 1480 1609 1610 1629 1628; 1481 1610 1611 1630 1629;
    1482 1611 1612 1631 1630; 1483 1612 1613 1632 1631; 1484 1613 1614 1633 1632;
    1485 1614 1615 1634 1633; 1486 1615 1616 1635 1634; 1487 1616 1617 1636 1635;
    1488 1617 1618 1637 1636; 1489 1618 1619 1638 1637; 1490 1619 1620 1639 1638;
    1491 1620 485 486 1639; 1492 1021 1621 1640 1020; 1493 1621 1622 1641 1640;
    1494 1622 1623 1642 1641; 1495 1623 1624 1643 1642; 1496 1624 1625 1644 1643;
    1497 1625 1626 1645 1644; 1498 1626 1627 1646 1645; 1499 1627 1628 1647 1646;
    1500 1628 1629 1648 1647; 1501 1629 1630 1649 1648; 1502 1630 1631 1650 1649;
    1503 1631 1632 1651 1650; 1504 1632 1633 1652 1651; 1505 1633 1634 1653 1652;
    1506 1634 1635 1654 1653; 1507 1635 1636 1655 1654; 1508 1636 1637 1656 1655;
    1509 1637 1638 1657 1656; 1510 1638 1639 1658 1657; 1511 1639 486 487 1658;
    1512 1020 1640 1659 1019; 1513 1640 1641 1660 1659; 1514 1641 1642 1661 1660;
    1515 1642 1643 1662 1661; 1516 1643 1644 1663 1662; 1517 1644 1645 1664 1663;
    1518 1645 1646 1665 1664; 1519 1646 1647 1666 1665; 1520 1647 1648 1667 1666;
    1521 1648 1649 1668 1667; 1522 1649 1650 1669 1668; 1523 1650 1651 1670 1669;
    1524 1651 1652 1671 1670; 1525 1652 1653 1672 1671; 1526 1653 1654 1673 1672;
    1527 1654 1655 1674 1673; 1528 1655 1656 1675 1674; 1529 1656 1657 1676 1675;
    1530 1657 1658 1677 1676; 1531 1658 487 488 1677; 1532 1019 1659 1678 1018;
    1533 1659 1660 1679 1678; 1534 1660 1661 1680 1679; 1535 1661 1662 1681 1680;
    1536 1662 1663 1682 1681; 1537 1663 1664 1683 1682; 1538 1664 1665 1684 1683;
    1539 1665 1666 1685 1684; 1540 1666 1667 1686 1685; 1541 1667 1668 1687 1686;
    1542 1668 1669 1688 1687; 1543 1669 1670 1689 1688; 1544 1670 1671 1690 1689;
    1545 1671 1672 1691 1690; 1546 1672 1673 1692 1691; 1547 1673 1674 1693 1692;
    1548 1674 1675 1694 1693; 1549 1675 1676 1695 1694; 1550 1676 1677 1696 1695;
    1551 1677 488 489 1696; 1552 1018 1678 1697 1017; 1553 1678 1679 1698 1697;
    1554 1679 1680 1699 1698; 1555 1680 1681 1700 1699; 1556 1681 1682 1701 1700;
    1557 1682 1683 1702 1701; 1558 1683 1684 1703 1702; 1559 1684 1685 1704 1703;
    1560 1685 1686 1705 1704; 1561 1686 1687 1706 1705; 1562 1687 1688 1707 1706;
    1563 1688 1689 1708 1707; 1564 1689 1690 1709 1708; 1565 1690 1691 1710 1709;
    1566 1691 1692 1711 1710; 1567 1692 1693 1712 1711; 1568 1693 1694 1713 1712;
    1569 1694 1695 1714 1713; 1570 1695 1696 1715 1714; 1571 1696 489 490 1715;
    1572 1017 1697 1716 1016; 1573 1697 1698 1717 1716; 1574 1698 1699 1718 1717;
    1575 1699 1700 1719 1718; 1576 1700 1701 1720 1719; 1577 1701 1702 1721 1720;
    1578 1702 1703 1722 1721; 1579 1703 1704 1723 1722; 1580 1704 1705 1724 1723;
    1581 1705 1706 1725 1724; 1582 1706 1707 1726 1725; 1583 1707 1708 1727 1726;
    1584 1708 1709 1728 1727; 1585 1709 1710 1729 1728; 1586 1710 1711 1730 1729;
    1587 1711 1712 1731 1730; 1588 1712 1713 1732 1731; 1589 1713 1714 1733 1732;
    1590 1714 1715 1734 1733; 1591 1715 490 491 1734; 1592 1016 1716 1735 1015;
    1593 1716 1717 1736 1735; 1594 1717 1718 1737 1736; 1595 1718 1719 1738 1737;
    1596 1719 1720 1739 1738; 1597 1720 1721 1740 1739; 1598 1721 1722 1741 1740;
    1599 1722 1723 1742 1741; 1600 1723 1724 1743 1742; 1601 1724 1725 1744 1743;
    1602 1725 1726 1745 1744; 1603 1726 1727 1746 1745; 1604 1727 1728 1747 1746;
    1605 1728 1729 1748 1747; 1606 1729 1730 1749 1748; 1607 1730 1731 1750 1749;
    1608 1731 1732 1751 1750; 1609 1732 1733 1752 1751; 1610 1733 1734 1753 1752;
    1611 1734 491 492 1753; 1612 1015 1735 1754 1014; 1613 1735 1736 1755 1754;
    1614 1736 1737 1756 1755; 1615 1737 1738 1757 1756; 1616 1738 1739 1758 1757;
    1617 1739 1740 1759 1758; 1618 1740 1741 1760 1759; 1619 1741 1742 1761 1760;
    1620 1742 1743 1762 1761; 1621 1743 1744 1763 1762; 1622 1744 1745 1764 1763;
    1623 1745 1746 1765 1764; 1624 1746 1747 1766 1765; 1625 1747 1748 1767 1766;
    1626 1748 1749 1768 1767; 1627 1749 1750 1769 1768; 1628 1750 1751 1770 1769;
    1629 1751 1752 1771 1770; 1630 1752 1753 1772 1771; 1631 1753 492 493 1772;
    1632 1014 1754 1773 1013; 1633 1754 1755 1774 1773; 1634 1755 1756 1775 1774;
    1635 1756 1757 1776 1775; 1636 1757 1758 1777 1776; 1637 1758 1759 1778 1777;
    1638 1759 1760 1779 1778; 1639 1760 1761 1780 1779; 1640 1761 1762 1781 1780;
    1641 1762 1763 1782 1781; 1642 1763 1764 1783 1782; 1643 1764 1765 1784 1783;
    1644 1765 1766 1785 1784; 1645 1766 1767 1786 1785; 1646 1767 1768 1787 1786;
    1647 1768 1769 1788 1787; 1648 1769 1770 1789 1788; 1649 1770 1771 1790 1789;
    1650 1771 1772 1791 1790; 1651 1772 493 494 1791; 1652 1013 1773 1792 1012;
    1653 1773 1774 1793 1792; 1654 1774 1775 1794 1793; 1655 1775 1776 1795 1794;
    1656 1776 1777 1796 1795; 1657 1777 1778 1797 1796; 1658 1778 1779 1798 1797;
    1659 1779 1780 1799 1798; 1660 1780 1781 1800 1799; 1661 1781 1782 1801 1800;
    1662 1782 1783 1802 1801; 1663 1783 1784 1803 1802; 1664 1784 1785 1804 1803;
    1665 1785 1786 1805 1804; 1666 1786 1787 1806 1805; 1667 1787 1788 1807 1806;
    1668 1788 1789 1808 1807; 1669 1789 1790 1809 1808; 1670 1790 1791 1810 1809;
    1671 1791 494 495 1810; 1672 1012 1792 1811 1011; 1673 1792 1793 1812 1811;
    1674 1793 1794 1813 1812; 1675 1794 1795 1814 1813; 1676 1795 1796 1815 1814;
    1677 1796 1797 1816 1815; 1678 1797 1798 1817 1816; 1679 1798 1799 1818 1817;
    1680 1799 1800 1819 1818; 1681 1800 1801 1820 1819; 1682 1801 1802 1821 1820;
    1683 1802 1803 1822 1821; 1684 1803 1804 1823 1822; 1685 1804 1805 1824 1823;
    1686 1805 1806 1825 1824; 1687 1806 1807 1826 1825; 1688 1807 1808 1827 1826;
    1689 1808 1809 1828 1827; 1690 1809 1810 1829 1828; 1691 1810 495 496 1829;
    1692 1011 1811 1830 1010; 1693 1811 1812 1831 1830; 1694 1812 1813 1832 1831;
    1695 1813 1814 1833 1832; 1696 1814 1815 1834 1833; 1697 1815 1816 1835 1834;
    1698 1816 1817 1836 1835; 1699 1817 1818 1837 1836; 1700 1818 1819 1838 1837;
    1701 1819 1820 1839 1838; 1702 1820 1821 1840 1839; 1703 1821 1822 1841 1840;
    1704 1822 1823 1842 1841; 1705 1823 1824 1843 1842; 1706 1824 1825 1844 1843;
    1707 1825 1826 1845 1844; 1708 1826 1827 1846 1845; 1709 1827 1828 1847 1846;
    1710 1828 1829 1848 1847; 1711 1829 496 497 1848; 1712 1010 1830 1849 1009;
    1713 1830 1831 1850 1849; 1714 1831 1832 1851 1850; 1715 1832 1833 1852 1851;
    1716 1833 1834 1853 1852; 1717 1834 1835 1854 1853; 1718 1835 1836 1855 1854;
    1719 1836 1837 1856 1855; 1720 1837 1838 1857 1856; 1721 1838 1839 1858 1857;
    1722 1839 1840 1859 1858; 1723 1840 1841 1860 1859; 1724 1841 1842 1861 1860;
    1725 1842 1843 1862 1861; 1726 1843 1844 1863 1862; 1727 1844 1845 1864 1863;
    1728 1845 1846 1865 1864; 1729 1846 1847 1866 1865; 1730 1847 1848 1867 1866;
    1731 1848 497 498 1867; 1732 1009 1849 1868 1008; 1733 1849 1850 1869 1868;
    1734 1850 1851 1870 1869; 1735 1851 1852 1871 1870; 1736 1852 1853 1872 1871;
    1737 1853 1854 1873 1872; 1738 1854 1855 1874 1873; 1739 1855 1856 1875 1874;
    1740 1856 1857 1876 1875; 1741 1857 1858 1877 1876; 1742 1858 1859 1878 1877;
    1743 1859 1860 1879 1878; 1744 1860 1861 1880 1879; 1745 1861 1862 1881 1880;
    1746 1862 1863 1882 1881; 1747 1863 1864 1883 1882; 1748 1864 1865 1884 1883;
    1749 1865 1866 1885 1884; 1750 1866 1867 1886 1885; 1751 1867 498 499 1886;
    1752 1008 1868 1887 1007; 1753 1868 1869 1888 1887; 1754 1869 1870 1889 1888;
    1755 1870 1871 1890 1889; 1756 1871 1872 1891 1890; 1757 1872 1873 1892 1891;
    1758 1873 1874 1893 1892; 1759 1874 1875 1894 1893; 1760 1875 1876 1895 1894;
    1761 1876 1877 1896 1895; 1762 1877 1878 1897 1896; 1763 1878 1879 1898 1897;
    1764 1879 1880 1899 1898; 1765 1880 1881 1900 1899; 1766 1881 1882 1901 1900;
    1767 1882 1883 1902 1901; 1768 1883 1884 1903 1902; 1769 1884 1885 1904 1903;
    1770 1885 1886 1905 1904; 1771 1886 499 500 1905; 1772 1007 1887 1906 1006;
    1773 1887 1888 1907 1906; 1774 1888 1889 1908 1907; 1775 1889 1890 1909 1908;
    1776 1890 1891 1910 1909; 1777 1891 1892 1911 1910; 1778 1892 1893 1912 1911;
    1779 1893 1894 1913 1912; 1780 1894 1895 1914 1913; 1781 1895 1896 1915 1914;
    1782 1896 1897 1916 1915; 1783 1897 1898 1917 1916; 1784 1898 1899 1918 1917;
    1785 1899 1900 1919 1918; 1786 1900 1901 1920 1919; 1787 1901 1902 1921 1920;
    1788 1902 1903 1922 1921; 1789 1903 1904 1923 1922; 1790 1904 1905 1924 1923;
    1791 1905 500 501 1924; 1792 1006 1906 1925 1005; 1793 1906 1907 1926 1925;
    1794 1907 1908 1927 1926; 1795 1908 1909 1928 1927; 1796 1909 1910 1929 1928;
    1797 1910 1911 1930 1929; 1798 1911 1912 1931 1930; 1799 1912 1913 1932 1931;
    1800 1913 1914 1933 1932; 1801 1914 1915 1934 1933; 1802 1915 1916 1935 1934;
    1803 1916 1917 1936 1935; 1804 1917 1918 1937 1936; 1805 1918 1919 1938 1937;
    1806 1919 1920 1939 1938; 1807 1920 1921 1940 1939; 1808 1921 1922 1941 1940;
    1809 1922 1923 1942 1941; 1810 1923 1924 1943 1942; 1811 1924 501 502 1943;
    1812 1005 1925 1944 1004; 1813 1925 1926 1945 1944; 1814 1926 1927 1946 1945;
    1815 1927 1928 1947 1946; 1816 1928 1929 1948 1947; 1817 1929 1930 1949 1948;
    1818 1930 1931 1950 1949; 1819 1931 1932 1951 1950; 1820 1932 1933 1952 1951;
    1821 1933 1934 1953 1952; 1822 1934 1935 1954 1953; 1823 1935 1936 1955 1954;
    1824 1936 1937 1956 1955; 1825 1937 1938 1957 1956; 1826 1938 1939 1958 1957;
    1827 1939 1940 1959 1958; 1828 1940 1941 1960 1959; 1829 1941 1942 1961 1960;
    1830 1942 1943 1962 1961; 1831 1943 502 503 1962; 1832 1004 1944 1963 1003;
    1833 1944 1945 1964 1963; 1834 1945 1946 1965 1964; 1835 1946 1947 1966 1965;
    1836 1947 1948 1967 1966; 1837 1948 1949 1968 1967; 1838 1949 1950 1969 1968;
    1839 1950 1951 1970 1969; 1840 1951 1952 1971 1970; 1841 1952 1953 1972 1971;
    1842 1953 1954 1973 1972; 1843 1954 1955 1974 1973; 1844 1955 1956 1975 1974;
    1845 1956 1957 1976 1975; 1846 1957 1958 1977 1976; 1847 1958 1959 1978 1977;
    1848 1959 1960 1979 1978; 1849 1960 1961 1980 1979; 1850 1961 1962 1981 1980;
    1851 1962 503 504 1981; 1852 1003 1963 1982 1002; 1853 1963 1964 1983 1982;
    1854 1964 1965 1984 1983; 1855 1965 1966 1985 1984; 1856 1966 1967 1986 1985;
    1857 1967 1968 1987 1986; 1858 1968 1969 1988 1987; 1859 1969 1970 1989 1988;
    1860 1970 1971 1990 1989; 1861 1971 1972 1991 1990; 1862 1972 1973 1992 1991;
    1863 1973 1974 1993 1992; 1864 1974 1975 1994 1993; 1865 1975 1976 1995 1994;
    1866 1976 1977 1996 1995; 1867 1977 1978 1997 1996; 1868 1978 1979 1998 1997;
    1869 1979 1980 1999 1998; 1870 1980 1981 2000 1999; 1871 1981 504 505 2000;
    1872 1002 1982 2001 1001; 1873 1982 1983 2002 2001; 1874 1983 1984 2003 2002;
    1875 1984 1985 2004 2003; 1876 1985 1986 2005 2004; 1877 1986 1987 2006 2005;
    1878 1987 1988 2007 2006; 1879 1988 1989 2008 2007; 1880 1989 1990 2009 2008;
    1881 1990 1991 2010 2009; 1882 1991 1992 2011 2010; 1883 1992 1993 2012 2011;
    1884 1993 1994 2013 2012; 1885 1994 1995 2014 2013; 1886 1995 1996 2015 2014;
    1887 1996 1997 2016 2015; 1888 1997 1998 2017 2016; 1889 1998 1999 2018 2017;
    1890 1999 2000 2019 2018; 1891 2000 505 506 2019; 1892 1001 2001 2020 1000;
    1893 2001 2002 2021 2020; 1894 2002 2003 2022 2021; 1895 2003 2004 2023 2022;
    1896 2004 2005 2024 2023; 1897 2005 2006 2025 2024; 1898 2006 2007 2026 2025;
    1899 2007 2008 2027 2026; 1900 2008 2009 2028 2027; 1901 2009 2010 2029 2028;
    1902 2010 2011 2030 2029; 1903 2011 2012 2031 2030; 1904 2012 2013 2032 2031;
    1905 2013 2014 2033 2032; 1906 2014 2015 2034 2033; 1907 2015 2016 2035 2034;
    1908 2016 2017 2036 2035; 1909 2017 2018 2037 2036; 1910 2018 2019 2038 2037;
    1911 2019 506 507 2038; 1912 1000 2020 2039 999; 1913 2020 2021 2040 2039;
    1914 2021 2022 2041 2040; 1915 2022 2023 2042 2041; 1916 2023 2024 2043 2042;
    1917 2024 2025 2044 2043; 1918 2025 2026 2045 2044; 1919 2026 2027 2046 2045;
    1920 2027 2028 2047 2046; 1921 2028 2029 2048 2047; 1922 2029 2030 2049 2048;
    1923 2030 2031 2050 2049; 1924 2031 2032 2051 2050; 1925 2032 2033 2052 2051;
    1926 2033 2034 2053 2052; 1927 2034 2035 2054 2053; 1928 2035 2036 2055 2054;
    1929 2036 2037 2056 2055; 1930 2037 2038 2057 2056; 1931 2038 507 508 2057;
    1932 999 2039 2058 998; 1933 2039 2040 2059 2058; 1934 2040 2041 2060 2059;
    1935 2041 2042 2061 2060; 1936 2042 2043 2062 2061; 1937 2043 2044 2063 2062;
    1938 2044 2045 2064 2063; 1939 2045 2046 2065 2064; 1940 2046 2047 2066 2065;
    1941 2047 2048 2067 2066; 1942 2048 2049 2068 2067; 1943 2049 2050 2069 2068;
    1944 2050 2051 2070 2069; 1945 2051 2052 2071 2070; 1946 2052 2053 2072 2071;
    1947 2053 2054 2073 2072; 1948 2054 2055 2074 2073; 1949 2055 2056 2075 2074;
    1950 2056 2057 2076 2075; 1951 2057 508 509 2076; 1952 998 2058 2077 997;
    1953 2058 2059 2078 2077; 1954 2059 2060 2079 2078; 1955 2060 2061 2080 2079;
    1956 2061 2062 2081 2080; 1957 2062 2063 2082 2081; 1958 2063 2064 2083 2082;
    1959 2064 2065 2084 2083; 1960 2065 2066 2085 2084; 1961 2066 2067 2086 2085;
    1962 2067 2068 2087 2086; 1963 2068 2069 2088 2087; 1964 2069 2070 2089 2088;
    1965 2070 2071 2090 2089; 1966 2071 2072 2091 2090; 1967 2072 2073 2092 2091;
    1968 2073 2074 2093 2092; 1969 2074 2075 2094 2093; 1970 2075 2076 2095 2094;
    1971 2076 509 510 2095; 1972 997 2077 2096 996; 1973 2077 2078 2097 2096;
    1974 2078 2079 2098 2097; 1975 2079 2080 2099 2098; 1976 2080 2081 2100 2099;
    1977 2081 2082 2101 2100; 1978 2082 2083 2102 2101; 1979 2083 2084 2103 2102;
    1980 2084 2085 2104 2103; 1981 2085 2086 2105 2104; 1982 2086 2087 2106 2105;
    1983 2087 2088 2107 2106; 1984 2088 2089 2108 2107; 1985 2089 2090 2109 2108;
    1986 2090 2091 2110 2109; 1987 2091 2092 2111 2110; 1988 2092 2093 2112 2111;
    1989 2093 2094 2113 2112; 1990 2094 2095 2114 2113; 1991 2095 510 511 2114;
    1992 996 2096 2115 995; 1993 2096 2097 2116 2115; 1994 2097 2098 2117 2116;
    1995 2098 2099 2118 2117; 1996 2099 2100 2119 2118; 1997 2100 2101 2120 2119;
    1998 2101 2102 2121 2120; 1999 2102 2103 2122 2121; 2000 2103 2104 2123 2122;
    2001 2104 2105 2124 2123; 2002 2105 2106 2125 2124; 2003 2106 2107 2126 2125;
    2004 2107 2108 2127 2126; 2005 2108 2109 2128 2127; 2006 2109 2110 2129 2128;
    2007 2110 2111 2130 2129; 2008 2111 2112 2131 2130; 2009 2112 2113 2132 2131;
    2010 2113 2114 2133 2132; 2011 2114 511 512 2133; 2012 995 2115 2134 994;
    2013 2115 2116 2135 2134; 2014 2116 2117 2136 2135; 2015 2117 2118 2137 2136;
    2016 2118 2119 2138 2137; 2017 2119 2120 2139 2138; 2018 2120 2121 2140 2139;
    2019 2121 2122 2141 2140; 2020 2122 2123 2142 2141; 2021 2123 2124 2143 2142;
    2022 2124 2125 2144 2143; 2023 2125 2126 2145 2144; 2024 2126 2127 2146 2145;
    2025 2127 2128 2147 2146; 2026 2128 2129 2148 2147; 2027 2129 2130 2149 2148;
    2028 2130 2131 2150 2149; 2029 2131 2132 2151 2150; 2030 2132 2133 2152 2151;
    2031 2133 512 513 2152; 2032 994 2134 2153 993; 2033 2134 2135 2154 2153;
    2034 2135 2136 2155 2154; 2035 2136 2137 2156 2155; 2036 2137 2138 2157 2156;
    2037 2138 2139 2158 2157; 2038 2139 2140 2159 2158; 2039 2140 2141 2160 2159;
    2040 2141 2142 2161 2160; 2041 2142 2143 2162 2161; 2042 2143 2144 2163 2162;
    2043 2144 2145 2164 2163; 2044 2145 2146 2165 2164; 2045 2146 2147 2166 2165;
    2046 2147 2148 2167 2166; 2047 2148 2149 2168 2167; 2048 2149 2150 2169 2168;
    2049 2150 2151 2170 2169; 2050 2151 2152 2171 2170; 2051 2152 513 514 2171;
    2052 993 2153 2172 992; 2053 2153 2154 2173 2172; 2054 2154 2155 2174 2173;
    2055 2155 2156 2175 2174; 2056 2156 2157 2176 2175; 2057 2157 2158 2177 2176;
    2058 2158 2159 2178 2177; 2059 2159 2160 2179 2178; 2060 2160 2161 2180 2179;
    2061 2161 2162 2181 2180; 2062 2162 2163 2182 2181; 2063 2163 2164 2183 2182;
    2064 2164 2165 2184 2183; 2065 2165 2166 2185 2184; 2066 2166 2167 2186 2185;
    2067 2167 2168 2187 2186; 2068 2168 2169 2188 2187; 2069 2169 2170 2189 2188;
    2070 2170 2171 2190 2189; 2071 2171 514 515 2190; 2072 992 2172 2191 991;
    2073 2172 2173 2192 2191; 2074 2173 2174 2193 2192; 2075 2174 2175 2194 2193;
    2076 2175 2176 2195 2194; 2077 2176 2177 2196 2195; 2078 2177 2178 2197 2196;
    2079 2178 2179 2198 2197; 2080 2179 2180 2199 2198; 2081 2180 2181 2200 2199;
    2082 2181 2182 2201 2200; 2083 2182 2183 2202 2201; 2084 2183 2184 2203 2202;
    2085 2184 2185 2204 2203; 2086 2185 2186 2205 2204; 2087 2186 2187 2206 2205;
    2088 2187 2188 2207 2206; 2089 2188 2189 2208 2207; 2090 2189 2190 2209 2208;
    2091 2190 515 516 2209; 2092 991 2191 2210 990; 2093 2191 2192 2211 2210;
    2094 2192 2193 2212 2211; 2095 2193 2194 2213 2212; 2096 2194 2195 2214 2213;
    2097 2195 2196 2215 2214; 2098 2196 2197 2216 2215; 2099 2197 2198 2217 2216;
    2100 2198 2199 2218 2217; 2101 2199 2200 2219 2218; 2102 2200 2201 2220 2219;
    2103 2201 2202 2221 2220; 2104 2202 2203 2222 2221; 2105 2203 2204 2223 2222;
    2106 2204 2205 2224 2223; 2107 2205 2206 2225 2224; 2108 2206 2207 2226 2225;
    2109 2207 2208 2227 2226; 2110 2208 2209 2228 2227; 2111 2209 516 517 2228;
    2112 990 2210 2229 989; 2113 2210 2211 2230 2229; 2114 2211 2212 2231 2230;
    2115 2212 2213 2232 2231; 2116 2213 2214 2233 2232; 2117 2214 2215 2234 2233;
    2118 2215 2216 2235 2234; 2119 2216 2217 2236 2235; 2120 2217 2218 2237 2236;
    2121 2218 2219 2238 2237; 2122 2219 2220 2239 2238; 2123 2220 2221 2240 2239;
    2124 2221 2222 2241 2240; 2125 2222 2223 2242 2241; 2126 2223 2224 2243 2242;
    2127 2224 2225 2244 2243; 2128 2225 2226 2245 2244; 2129 2226 2227 2246 2245;
    2130 2227 2228 2247 2246; 2131 2228 517 518 2247; 2132 989 2229 2248 988;
    2133 2229 2230 2249 2248; 2134 2230 2231 2250 2249; 2135 2231 2232 2251 2250;
    2136 2232 2233 2252 2251; 2137 2233 2234 2253 2252; 2138 2234 2235 2254 2253;
    2139 2235 2236 2255 2254; 2140 2236 2237 2256 2255; 2141 2237 2238 2257 2256;
    2142 2238 2239 2258 2257; 2143 2239 2240 2259 2258; 2144 2240 2241 2260 2259;
    2145 2241 2242 2261 2260; 2146 2242 2243 2262 2261; 2147 2243 2244 2263 2262;
    2148 2244 2245 2264 2263; 2149 2245 2246 2265 2264; 2150 2246 2247 2266 2265;
    2151 2247 518 519 2266; 2152 988 2248 2267 987; 2153 2248 2249 2268 2267;
    2154 2249 2250 2269 2268; 2155 2250 2251 2270 2269; 2156 2251 2252 2271 2270;
    2157 2252 2253 2272 2271; 2158 2253 2254 2273 2272; 2159 2254 2255 2274 2273;
    2160 2255 2256 2275 2274; 2161 2256 2257 2276 2275; 2162 2257 2258 2277 2276;
    2163 2258 2259 2278 2277; 2164 2259 2260 2279 2278; 2165 2260 2261 2280 2279;
    2166 2261 2262 2281 2280; 2167 2262 2263 2282 2281; 2168 2263 2264 2283 2282;
    2169 2264 2265 2284 2283; 2170 2265 2266 2285 2284; 2171 2266 519 520 2285;
    2172 987 2267 2286 986; 2173 2267 2268 2287 2286; 2174 2268 2269 2288 2287;
    2175 2269 2270 2289 2288; 2176 2270 2271 2290 2289; 2177 2271 2272 2291 2290;
    2178 2272 2273 2292 2291; 2179 2273 2274 2293 2292; 2180 2274 2275 2294 2293;
    2181 2275 2276 2295 2294; 2182 2276 2277 2296 2295; 2183 2277 2278 2297 2296;
    2184 2278 2279 2298 2297; 2185 2279 2280 2299 2298; 2186 2280 2281 2300 2299;
    2187 2281 2282 2301 2300; 2188 2282 2283 2302 2301; 2189 2283 2284 2303 2302;
    2190 2284 2285 2304 2303; 2191 2285 520 521 2304; 2192 986 2286 2305 985;
    2193 2286 2287 2306 2305; 2194 2287 2288 2307 2306; 2195 2288 2289 2308 2307;
    2196 2289 2290 2309 2308; 2197 2290 2291 2310 2309; 2198 2291 2292 2311 2310;
    2199 2292 2293 2312 2311; 2200 2293 2294 2313 2312; 2201 2294 2295 2314 2313;
    2202 2295 2296 2315 2314; 2203 2296 2297 2316 2315; 2204 2297 2298 2317 2316;
    2205 2298 2299 2318 2317; 2206 2299 2300 2319 2318; 2207 2300 2301 2320 2319;
    2208 2301 2302 2321 2320; 2209 2302 2303 2322 2321; 2210 2303 2304 2323 2322;
    2211 2304 521 522 2323; 2212 985 2305 2324 984; 2213 2305 2306 2325 2324;
    2214 2306 2307 2326 2325; 2215 2307 2308 2327 2326; 2216 2308 2309 2328 2327;
    2217 2309 2310 2329 2328; 2218 2310 2311 2330 2329; 2219 2311 2312 2331 2330;
    2220 2312 2313 2332 2331; 2221 2313 2314 2333 2332; 2222 2314 2315 2334 2333;
    2223 2315 2316 2335 2334; 2224 2316 2317 2336 2335; 2225 2317 2318 2337 2336;
    2226 2318 2319 2338 2337; 2227 2319 2320 2339 2338; 2228 2320 2321 2340 2339;
    2229 2321 2322 2341 2340; 2230 2322 2323 2342 2341; 2231 2323 522 523 2342;
    2232 984 2324 2343 983; 2233 2324 2325 2344 2343; 2234 2325 2326 2345 2344;
    2235 2326 2327 2346 2345; 2236 2327 2328 2347 2346; 2237 2328 2329 2348 2347;
    2238 2329 2330 2349 2348; 2239 2330 2331 2350 2349; 2240 2331 2332 2351 2350;
    2241 2332 2333 2352 2351; 2242 2333 2334 2353 2352; 2243 2334 2335 2354 2353;
    2244 2335 2336 2355 2354; 2245 2336 2337 2356 2355; 2246 2337 2338 2357 2356;
    2247 2338 2339 2358 2357; 2248 2339 2340 2359 2358; 2249 2340 2341 2360 2359;
    2250 2341 2342 2361 2360; 2251 2342 523 524 2361; 2252 983 2343 2362 982;
    2253 2343 2344 2363 2362; 2254 2344 2345 2364 2363; 2255 2345 2346 2365 2364;
    2256 2346 2347 2366 2365; 2257 2347 2348 2367 2366; 2258 2348 2349 2368 2367;
    2259 2349 2350 2369 2368; 2260 2350 2351 2370 2369; 2261 2351 2352 2371 2370;
    2262 2352 2353 2372 2371; 2263 2353 2354 2373 2372; 2264 2354 2355 2374 2373;
    2265 2355 2356 2375 2374; 2266 2356 2357 2376 2375; 2267 2357 2358 2377 2376;
    2268 2358 2359 2378 2377; 2269 2359 2360 2379 2378; 2270 2360 2361 2380 2379;
    2271 2361 524 525 2380; 2272 982 2362 2381 981; 2273 2362 2363 2382 2381;
    2274 2363 2364 2383 2382; 2275 2364 2365 2384 2383; 2276 2365 2366 2385 2384;
    2277 2366 2367 2386 2385; 2278 2367 2368 2387 2386; 2279 2368 2369 2388 2387;
    2280 2369 2370 2389 2388; 2281 2370 2371 2390 2389; 2282 2371 2372 2391 2390;
    2283 2372 2373 2392 2391; 2284 2373 2374 2393 2392; 2285 2374 2375 2394 2393;
    2286 2375 2376 2395 2394; 2287 2376 2377 2396 2395; 2288 2377 2378 2397 2396;
    2289 2378 2379 2398 2397; 2290 2379 2380 2399 2398; 2291 2380 525 526 2399;
    2292 981 2381 2400 980; 2293 2381 2382 2401 2400; 2294 2382 2383 2402 2401;
    2295 2383 2384 2403 2402; 2296 2384 2385 2404 2403; 2297 2385 2386 2405 2404;
    2298 2386 2387 2406 2405; 2299 2387 2388 2407 2406; 2300 2388 2389 2408 2407;
    2301 2389 2390 2409 2408; 2302 2390 2391 2410 2409; 2303 2391 2392 2411 2410;
    2304 2392 2393 2412 2411; 2305 2393 2394 2413 2412; 2306 2394 2395 2414 2413;
    2307 2395 2396 2415 2414; 2308 2396 2397 2416 2415; 2309 2397 2398 2417 2416;
    2310 2398 2399 2418 2417; 2311 2399 526 527 2418; 2312 980 2400 2419 979;
    2313 2400 2401 2420 2419; 2314 2401 2402 2421 2420; 2315 2402 2403 2422 2421;
    2316 2403 2404 2423 2422; 2317 2404 2405 2424 2423; 2318 2405 2406 2425 2424;
    2319 2406 2407 2426 2425; 2320 2407 2408 2427 2426; 2321 2408 2409 2428 2427;
    2322 2409 2410 2429 2428; 2323 2410 2411 2430 2429; 2324 2411 2412 2431 2430;
    2325 2412 2413 2432 2431; 2326 2413 2414 2433 2432; 2327 2414 2415 2434 2433;
    2328 2415 2416 2435 2434; 2329 2416 2417 2436 2435; 2330 2417 2418 2437 2436;
    2331 2418 527 528 2437; 2332 979 2419 2438 978; 2333 2419 2420 2439 2438;
    2334 2420 2421 2440 2439; 2335 2421 2422 2441 2440; 2336 2422 2423 2442 2441;
    2337 2423 2424 2443 2442; 2338 2424 2425 2444 2443; 2339 2425 2426 2445 2444;
    2340 2426 2427 2446 2445; 2341 2427 2428 2447 2446; 2342 2428 2429 2448 2447;
    2343 2429 2430 2449 2448; 2344 2430 2431 2450 2449; 2345 2431 2432 2451 2450;
    2346 2432 2433 2452 2451; 2347 2433 2434 2453 2452; 2348 2434 2435 2454 2453;
    2349 2435 2436 2455 2454; 2350 2436 2437 2456 2455; 2351 2437 528 529 2456;
    2352 978 2438 2457 4; 2353 2438 2439 2458 2457; 2354 2439 2440 2459 2458;
    2355 2440 2441 2460 2459; 2356 2441 2442 2461 2460; 2357 2442 2443 2462 2461;
    2358 2443 2444 2463 2462; 2359 2444 2445 2464 2463; 2360 2445 2446 2465 2464;
    2361 2446 2447 2466 2465; 2362 2447 2448 2467 2466; 2363 2448 2449 2468 2467;
    2364 2449 2450 2469 2468; 2365 2450 2451 2470 2469; 2366 2451 2452 2471 2470;
    2367 2452 2453 2472 2471; 2368 2453 2454 2473 2472; 2369 2454 2455 2474 2473;
    2370 2455 2456 2475 2474; 2371 2456 529 3 2475;
    START GROUP DEFINITION
    JOINT
    _APOYOS 311 318 325 332 339 346 353 360 367 374 381 829 835 842 849 856 863 -
    870 877 884 891 898
    _BASENODES 1 TO 4 457 TO 529 978 TO 2475
    _SETTLEMENT 1 TO 4 490 1017 1069 1706 2466
    ELEMENT
    END GROUP DEFINITION
    ELEMENT PROPERTY
    1 4 TO 1319 1321 TO 2371 THICKNESS 0.2
    DEFINE MATERIAL START
    ISOTROPIC G30
    E 2.57409e+06
    POISSON 0.17
    DENSITY 2.40261
    DAMP 0.05
    G 946436
    ALPHA 5e-06
    TYPE CONCRETE
    STRENGTH FCU 3000
    ISOTROPIC CONCRETE
    E 2.21466e+06
    POISSON 0.17
    DENSITY 2.4026
    ALPHA 5.5e-06
    DAMP 0.05
    TYPE CONCRETE
    STRENGTH FCU 3010
    G 946436
    END DEFINE MATERIAL
    CONSTANTS
    MATERIAL CONCRETE ALL
    SUPPORTS
    *Y SUBGRADE STATIC = 2116.73 TONF/M2/M / DYNAMIC = 2751.70 TONF/M2/M
    *X Z SUBGRADE STATIC = 1058.36 TONF/M2/M / DYNAMIC = 1375.85 TONF/M2/M
    4 TO 373 448 TO 817 PLATE MAT DIRECT X SUBGRADE 1058.36 PRINT
    1 892 TO 1319 1321 TO 2371 PLATE MAT DIRECT Y SUBGRADE 2116.73 PRINT
    SPRING COMPRESSION
    1 TO 4 457 TO 529 978 TO 2475 KFY
    SPRING COMPRESSION
    5 TO 456 530 TO 977 KFX
    LOAD 1 LOADTYPE None TITLE DL
    SELFWEIGHT Y -1
    JOINT LOAD
    311 318 325 332 339 346 353 360 367 374 381 829 835 842 849 856 863 870 877 -
    884 891 898 FY -4.215
    *cable trays load - 0.15 tonf/m every 3 m
    LOAD 2 LOADTYPE None TITLE H
    ELEMENT LOAD
    5 TRAP JT 0 0 0.478332 0.478341
    6 TRAP JT 0 0 0.478341 0.478332
    7 TRAP JT 0 0 0.478332 0.478341
    8 TRAP JT 0 0 0.478341 0.478332
    9 TRAP JT 0 0 0.478341 0.478341
    10 TRAP JT 0 0 0.478341 0.478341
    11 TRAP JT 0 0 0.478341 0.478341
    12 TRAP JT 0 0 0.478341 0.478341
    13 TRAP JT 0 0 0.478341 0.478341
    14 TRAP JT 0 0 0.478341 0.478341
    15 TRAP JT 0 0 0.478332 0.478341
    16 TRAP JT 0 0 0.478341 0.478332
    17 TRAP JT 0 0 0.478332 0.478341
    18 TRAP JT 0 0 0.478332 0.478332
    19 TRAP JT 0 0 0.478332 0.478332
    20 TRAP JT 0 0 0.478341 0.478332
    21 TRAP JT 0 0 0.478341 0.478341
    22 TRAP JT 0 0 0.478341 0.478341
    23 TRAP JT 0 0 0.478341 0.478341
    24 TRAP JT 0 0 0.478341 0.478341
    25 TRAP JT 0 0 0.478341 0.478341
    26 TRAP JT 0 0 0.478332 0.478341
    27 TRAP JT 0 0 0.478341 0.478332
    28 TRAP JT 0 0 0.478341 0.478341
    29 TRAP JT 0 0 0.478341 0.478341
    30 TRAP JT 0 0 0.478341 0.478341
    31 TRAP JT 0 0 0.478341 0.478341
    32 TRAP JT 0 0 0.478332 0.478341
    33 TRAP JT 0 0 0.478341 0.478332
    34 TRAP JT 0 0 0.478341 0.478341
    35 TRAP JT 0 0 0.478341 0.478341
    36 TRAP JT 0 0 0.478341 0.478341
    37 TRAP JT 0 0 0.478341 0.478341
    38 TRAP JT 0 0 0.478341 0.478341
    39 TRAP JT 0 0 0.478341 0.478341
    40 TRAP JT 0 0 0.478341 0.478341
    41 TRAP JT 0 0 0.478341 0.478341
    42 TRAP JT 0 0 0.478341 0.478341
    43 TRAP JT 0 0 0.478341 0.478341
    44 TRAP JT 0 0 0.478341 0.478341
    45 TRAP JT 0 0 0.478341 0.478341
    46 TRAP JT 0 0 0.478341 0.478341
    47 TRAP JT 0 0 0.478341 0.478341
    48 TRAP JT 0 0 0.478341 0.478341
    49 TRAP JT 0 0 0.478341 0.478341
    50 TRAP JT 0 0 0.478341 0.478341
    51 TRAP JT 0 0 0.478341 0.478341
    52 TRAP JT 0 0 0.478341 0.478341
    53 TRAP JT 0 0 0.478341 0.478341
    54 TRAP JT 0 0 0.478341 0.478341
    55 TRAP JT 0 0 0.478341 0.478341
    56 TRAP JT 0 0 0.478341 0.478341
    57 TRAP JT 0 0 0.478341 0.478341
    58 TRAP JT 0 0 0.478341 0.478341
    59 TRAP JT 0 0 0.478341 0.478341
    60 TRAP JT 0 0 0.478341 0.478341
    61 TRAP JT 0 0 0.478341 0.478341
    62 TRAP JT 0 0 0.478341 0.478341
    63 TRAP JT 0 0 0.478341 0.478341
    64 TRAP JT 0 0 0.478341 0.478341
    65 TRAP JT 0 0 0.478341 0.478341
    66 TRAP JT 0 0 0.478341 0.478341
    67 TRAP JT 0 0 0.478341 0.478341
    68 TRAP JT 0 0 0.478341 0.478341
    69 TRAP JT 0 0 0.478341 0.478341
    70 TRAP JT 0 0 0.478341 0.478341
    71 TRAP JT 0 0 0.478341 0.478341
    72 TRAP JT 0 0 0.478341 0.478341
    73 TRAP JT 0 0 0.478341 0.478341
    74 TRAP JT 0 0 0.478341 0.478341
    75 TRAP JT 0 0 0.478341 0.478341
    76 TRAP JT 0 0 0.478341 0.478341
    77 TRAP JT 0 0 0.478341 0.478341
    78 TRAP JT 0.478341 0.478341 0.956673 0.956673
    79 TRAP JT 0.478341 0.478332 0.956673 0.956673
    80 TRAP JT 0.478332 0.478341 0.956673 0.956673
    81 TRAP JT 0.478341 0.478332 0.956673 0.956673
    82 TRAP JT 0.478332 0.478341 0.956673 0.956673
    83 TRAP JT 0.478341 0.478341 0.956673 0.956673
    84 TRAP JT 0.478341 0.478341 0.956673 0.956673
    85 TRAP JT 0.478341 0.478341 0.956673 0.956673
    86 TRAP JT 0.478341 0.478341 0.956673 0.956673
    87 TRAP JT 0.478341 0.478341 0.956673 0.956673
    88 TRAP JT 0.478341 0.478341 0.956673 0.956673
    89 TRAP JT 0.478341 0.478332 0.956673 0.956673
    90 TRAP JT 0.478332 0.478341 0.956673 0.956673
    91 TRAP JT 0.478341 0.478332 0.956673 0.956673
    92 TRAP JT 0.478332 0.478332 0.956673 0.956673
    93 TRAP JT 0.478332 0.478332 0.956673 0.956673
    94 TRAP JT 0.478332 0.478341 0.956673 0.956673
    95 TRAP JT 0.478341 0.478341 0.956673 0.956673
    96 TRAP JT 0.478341 0.478341 0.956673 0.956673
    97 TRAP JT 0.478341 0.478341 0.956673 0.956673
    98 TRAP JT 0.478341 0.478341 0.956673 0.956673
    99 TRAP JT 0.478341 0.478341 0.956673 0.956673
    100 TRAP JT 0.478341 0.478332 0.956673 0.956673
    101 TRAP JT 0.478332 0.478341 0.956673 0.956673
    102 TRAP JT 0.478341 0.478341 0.956673 0.956673
    103 TRAP JT 0.478341 0.478341 0.956673 0.956673
    104 TRAP JT 0.478341 0.478341 0.956673 0.956673
    105 TRAP JT 0.478341 0.478341 0.956673 0.956673
    106 TRAP JT 0.478341 0.478332 0.956673 0.956673
    107 TRAP JT 0.478332 0.478341 0.956673 0.956673
    108 TRAP JT 0.478341 0.478341 0.956673 0.956673
    109 TRAP JT 0.478341 0.478341 0.956673 0.956673
    110 TRAP JT 0.478341 0.478341 0.956673 0.956673
    111 TRAP JT 0.478341 0.478341 0.956673 0.956673
    112 TRAP JT 0.478341 0.478341 0.956673 0.956673
    113 TRAP JT 0.478341 0.478341 0.956673 0.956673
    114 TRAP JT 0.478341 0.478341 0.956673 0.956673
    115 TRAP JT 0.478341 0.478341 0.956673 0.956673
    116 TRAP JT 0.478341 0.478341 0.956673 0.956673
    117 TRAP JT 0.478341 0.478341 0.956673 0.956673
    118 TRAP JT 0.478341 0.478341 0.956673 0.956673
    119 TRAP JT 0.478341 0.478341 0.956673 0.956673
    120 TRAP JT 0.478341 0.478341 0.956673 0.956673
    121 TRAP JT 0.478341 0.478341 0.956673 0.956673
    122 TRAP JT 0.478341 0.478341 0.956673 0.956673
    123 TRAP JT 0.478341 0.478341 0.956673 0.956673
    124 TRAP JT 0.478341 0.478341 0.956673 0.956673
    125 TRAP JT 0.478341 0.478341 0.956673 0.956673
    126 TRAP JT 0.478341 0.478341 0.956673 0.956673
    127 TRAP JT 0.478341 0.478341 0.956673 0.956673
    128 TRAP JT 0.478341 0.478341 0.956673 0.956673
    129 TRAP JT 0.478341 0.478341 0.956673 0.956673
    130 TRAP JT 0.478341 0.478341 0.956673 0.956673
    131 TRAP JT 0.478341 0.478341 0.956673 0.956673
    132 TRAP JT 0.478341 0.478341 0.956673 0.956673
    133 TRAP JT 0.478341 0.478341 0.956673 0.956673
    134 TRAP JT 0.478341 0.478341 0.956673 0.956673
    135 TRAP JT 0.478341 0.478341 0.956673 0.956673
    136 TRAP JT 0.478341 0.478341 0.956673 0.956673
    137 TRAP JT 0.478341 0.478341 0.956673 0.956673
    138 TRAP JT 0.478341 0.478341 0.956673 0.956673
    139 TRAP JT 0.478341 0.478341 0.956673 0.956673
    140 TRAP JT 0.478341 0.478341 0.956673 0.956673
    141 TRAP JT 0.478341 0.478341 0.956673 0.956673
    142 TRAP JT 0.478341 0.478341 0.956673 0.956673
    143 TRAP JT 0.478341 0.478341 0.956673 0.956673
    144 TRAP JT 0.478341 0.478341 0.956673 0.956673
    145 TRAP JT 0.478341 0.478341 0.956673 0.956673
    146 TRAP JT 0.478341 0.478341 0.956673 0.956673
    147 TRAP JT 0.478341 0.478341 0.956673 0.956673
    148 TRAP JT 0.478341 0.478341 0.956673 0.956673
    149 TRAP JT 0.478341 0.478341 0.956673 0.956673
    150 TRAP JT 0.478341 0.478341 0.956673 0.956673
    151 TRAP JT 0.478341 0.478341 0.956673 0.956673
    152 TRAP JT 0.956673 0.956673 1.435 1.435
    153 TRAP JT 0.956673 0.956673 1.435 1.435
    154 TRAP JT 0.956673 0.956673 1.435 1.435
    155 TRAP JT 0.956673 0.956673 1.435 1.435
    156 TRAP JT 0.956673 0.956673 1.435 1.435
    157 TRAP JT 0.956673 0.956673 1.435 1.435
    158 TRAP JT 0.956673 0.956673 1.435 1.435
    159 TRAP JT 0.956673 0.956673 1.435 1.435
    160 TRAP JT 0.956673 0.956673 1.435 1.435
    161 TRAP JT 0.956673 0.956673 1.435 1.435
    162 TRAP JT 0.956673 0.956673 1.435 1.435
    163 TRAP JT 0.956673 0.956673 1.435 1.435
    164 TRAP JT 0.956673 0.956673 1.435 1.435
    165 TRAP JT 0.956673 0.956673 1.435 1.435
    166 TRAP JT 0.956673 0.956673 1.435 1.435
    167 TRAP JT 0.956673 0.956673 1.435 1.435
    168 TRAP JT 0.956673 0.956673 1.435 1.435
    169 TRAP JT 0.956673 0.956673 1.435 1.435
    170 TRAP JT 0.956673 0.956673 1.435 1.435
    171 TRAP JT 0.956673 0.956673 1.435 1.435
    172 TRAP JT 0.956673 0.956673 1.435 1.435
    173 TRAP JT 0.956673 0.956673 1.435 1.435
    174 TRAP JT 0.956673 0.956673 1.435 1.435
    175 TRAP JT 0.956673 0.956673 1.435 1.435
    176 TRAP JT 0.956673 0.956673 1.435 1.435
    177 TRAP JT 0.956673 0.956673 1.435 1.435
    178 TRAP JT 0.956673 0.956673 1.435 1.435
    179 TRAP JT 0.956673 0.956673 1.435 1.435
    180 TRAP JT 0.956673 0.956673 1.435 1.435
    181 TRAP JT 0.956673 0.956673 1.435 1.435
    182 TRAP JT 0.956673 0.956673 1.435 1.435
    183 TRAP JT 0.956673 0.956673 1.435 1.435
    184 TRAP JT 0.956673 0.956673 1.435 1.435
    185 TRAP JT 0.956673 0.956673 1.435 1.435
    186 TRAP JT 0.956673 0.956673 1.435 1.435
    187 TRAP JT 0.956673 0.956673 1.435 1.435
    188 TRAP JT 0.956673 0.956673 1.435 1.435
    189 TRAP JT 0.956673 0.956673 1.435 1.435
    190 TRAP JT 0.956673 0.956673 1.435 1.435
    191 TRAP JT 0.956673 0.956673 1.435 1.435
    192 TRAP JT 0.956673 0.956673 1.435 1.435
    193 TRAP JT 0.956673 0.956673 1.435 1.435
    194 TRAP JT 0.956673 0.956673 1.435 1.435
    195 TRAP JT 0.956673 0.956673 1.435 1.435
    196 TRAP JT 0.956673 0.956673 1.435 1.435
    197 TRAP JT 0.956673 0.956673 1.435 1.435
    198 TRAP JT 0.956673 0.956673 1.435 1.435
    199 TRAP JT 0.956673 0.956673 1.435 1.435
    200 TRAP JT 0.956673 0.956673 1.435 1.435
    201 TRAP JT 0.956673 0.956673 1.435 1.435
    202 TRAP JT 0.956673 0.956673 1.435 1.435
    203 TRAP JT 0.956673 0.956673 1.435 1.435
    204 TRAP JT 0.956673 0.956673 1.435 1.435
    205 TRAP JT 0.956673 0.956673 1.435 1.435
    206 TRAP JT 0.956673 0.956673 1.435 1.435
    207 TRAP JT 0.956673 0.956673 1.435 1.435
    208 TRAP JT 0.956673 0.956673 1.435 1.435
    209 TRAP JT 0.956673 0.956673 1.435 1.435
    210 TRAP JT 0.956673 0.956673 1.435 1.435
    211 TRAP JT 0.956673 0.956673 1.435 1.435
    212 TRAP JT 0.956673 0.956673 1.435 1.435
    213 TRAP JT 0.956673 0.956673 1.435 1.435
    214 TRAP JT 0.956673 0.956673 1.435 1.435
    215 TRAP JT 0.956673 0.956673 1.435 1.435
    216 TRAP JT 0.956673 0.956673 1.435 1.435
    217 TRAP JT 0.956673 0.956673 1.435 1.435
    218 TRAP JT 0.956673 0.956673 1.435 1.435
    219 TRAP JT 0.956673 0.956673 1.435 1.435
    220 TRAP JT 0.956673 0.956673 1.435 1.435
    221 TRAP JT 0.956673 0.956673 1.435 1.435
    222 TRAP JT 0.956673 0.956673 1.435 1.435
    223 TRAP JT 0.956673 0.956673 1.435 1.435
    224 TRAP JT 0.956673 0.956673 1.435 1.435
    225 TRAP JT 0.956673 0.956673 1.435 1.435
    226 TRAP JT 1.435 1.435 1.91334 1.91334
    227 TRAP JT 1.435 1.435 1.91334 1.91334
    228 TRAP JT 1.435 1.435 1.91334 1.91334
    229 TRAP JT 1.435 1.435 1.91334 1.91334
    230 TRAP JT 1.435 1.435 1.91334 1.91334
    231 TRAP JT 1.435 1.435 1.91334 1.91334
    232 TRAP JT 1.435 1.435 1.91334 1.91334
    233 TRAP JT 1.435 1.435 1.91334 1.91334
    234 TRAP JT 1.435 1.435 1.91334 1.91334
    235 TRAP JT 1.435 1.435 1.91334 1.91334
    236 TRAP JT 1.435 1.435 1.91334 1.91334
    237 TRAP JT 1.435 1.435 1.91334 1.91334
    238 TRAP JT 1.435 1.435 1.91334 1.91334
    239 TRAP JT 1.435 1.435 1.91334 1.91334
    240 TRAP JT 1.435 1.435 1.91334 1.91334
    241 TRAP JT 1.435 1.435 1.91334 1.91334
    242 TRAP JT 1.435 1.435 1.91334 1.91334
    243 TRAP JT 1.435 1.435 1.91334 1.91334
    244 TRAP JT 1.435 1.435 1.91334 1.91334
    245 TRAP JT 1.435 1.435 1.91334 1.91334
    246 TRAP JT 1.435 1.435 1.91334 1.91334
    247 TRAP JT 1.435 1.435 1.91334 1.91334
    248 TRAP JT 1.435 1.435 1.91334 1.91334
    249 TRAP JT 1.435 1.435 1.91334 1.91334
    250 TRAP JT 1.435 1.435 1.91334 1.91334
    251 TRAP JT 1.435 1.435 1.91334 1.91334
    252 TRAP JT 1.435 1.435 1.91334 1.91334
    253 TRAP JT 1.435 1.435 1.91334 1.91334
    254 TRAP JT 1.435 1.435 1.91334 1.91334
    255 TRAP JT 1.435 1.435 1.91334 1.91334
    256 TRAP JT 1.435 1.435 1.91334 1.91334
    257 TRAP JT 1.435 1.435 1.91334 1.91334
    258 TRAP JT 1.435 1.435 1.91334 1.91334
    259 TRAP JT 1.435 1.435 1.91334 1.91334
    260 TRAP JT 1.435 1.435 1.91334 1.91334
    261 TRAP JT 1.435 1.435 1.91334 1.91334
    262 TRAP JT 1.435 1.435 1.91334 1.91334
    263 TRAP JT 1.435 1.435 1.91334 1.91334
    264 TRAP JT 1.435 1.435 1.91334 1.91334
    265 TRAP JT 1.435 1.435 1.91334 1.91334
    266 TRAP JT 1.435 1.435 1.91334 1.91334
    267 TRAP JT 1.435 1.435 1.91334 1.91334
    268 TRAP JT 1.435 1.435 1.91334 1.91334
    269 TRAP JT 1.435 1.435 1.91334 1.91334
    270 TRAP JT 1.435 1.435 1.91334 1.91334
    271 TRAP JT 1.435 1.435 1.91334 1.91334
    272 TRAP JT 1.435 1.435 1.91334 1.91334
    273 TRAP JT 1.435 1.435 1.91334 1.91334
    274 TRAP JT 1.435 1.435 1.91334 1.91334
    275 TRAP JT 1.435 1.435 1.91334 1.91334
    276 TRAP JT 1.435 1.435 1.91334 1.91334
    277 TRAP JT 1.435 1.435 1.91334 1.91334
    278 TRAP JT 1.435 1.435 1.91334 1.91334
    279 TRAP JT 1.435 1.435 1.91334 1.91334
    280 TRAP JT 1.435 1.435 1.91334 1.91334
    281 TRAP JT 1.435 1.435 1.91334 1.91334
    282 TRAP JT 1.435 1.435 1.91334 1.91334
    283 TRAP JT 1.435 1.435 1.91334 1.91334
    284 TRAP JT 1.435 1.435 1.91334 1.91334
    285 TRAP JT 1.435 1.435 1.91334 1.91334
    286 TRAP JT 1.435 1.435 1.91334 1.91334
    287 TRAP JT 1.435 1.435 1.91334 1.91334
    288 TRAP JT 1.435 1.435 1.91334 1.91334
    289 TRAP JT 1.435 1.435 1.91334 1.91334
    290 TRAP JT 1.435 1.435 1.91334 1.91334
    291 TRAP JT 1.435 1.435 1.91334 1.91334
    292 TRAP JT 1.435 1.435 1.91334 1.91334
    293 TRAP JT 1.435 1.435 1.91334 1.91334
    294 TRAP JT 1.435 1.435 1.91334 1.91334
    295 TRAP JT 1.435 1.435 1.91334 1.91334
    296 TRAP JT 1.435 1.435 1.91334 1.91334
    297 TRAP JT 1.435 1.435 1.91334 1.91334
    298 TRAP JT 1.435 1.435 1.91334 1.91334
    299 TRAP JT 1.435 1.435 1.91334 1.91334
    300 TRAP JT 1.91334 1.91334 2.39167 2.39167
    301 TRAP JT 1.91334 1.91334 2.39167 2.39167
    302 TRAP JT 1.91334 1.91334 2.39167 2.39167
    303 TRAP JT 1.91334 1.91334 2.39167 2.39167
    304 TRAP JT 1.91334 1.91334 2.39167 2.39167
    305 TRAP JT 1.91334 1.91334 2.39167 2.39167
    306 TRAP JT 1.91334 1.91334 2.39167 2.39167
    307 TRAP JT 1.91334 1.91334 2.39167 2.39167
    308 TRAP JT 1.91334 1.91334 2.39167 2.39167
    309 TRAP JT 1.91334 1.91334 2.39167 2.39167
    310 TRAP JT 1.91334 1.91334 2.39167 2.39167
    311 TRAP JT 1.91334 1.91334 2.39167 2.39167
    312 TRAP JT 1.91334 1.91334 2.39167 2.39167
    313 TRAP JT 1.91334 1.91334 2.39167 2.39167
    314 TRAP JT 1.91334 1.91334 2.39167 2.39167
    315 TRAP JT 1.91334 1.91334 2.39167 2.39167
    316 TRAP JT 1.91334 1.91334 2.39167 2.39167
    317 TRAP JT 1.91334 1.91334 2.39167 2.39167
    318 TRAP JT 1.91334 1.91334 2.39167 2.39167
    319 TRAP JT 1.91334 1.91334 2.39167 2.39167
    320 TRAP JT 1.91334 1.91334 2.39167 2.39167
    321 TRAP JT 1.91334 1.91334 2.39167 2.39167
    322 TRAP JT 1.91334 1.91334 2.39167 2.39167
    323 TRAP JT 1.91334 1.91334 2.39167 2.39167
    324 TRAP JT 1.91334 1.91334 2.39167 2.39167
    325 TRAP JT 1.91334 1.91334 2.39167 2.39167
    326 TRAP JT 1.91334 1.91334 2.39167 2.39167
    327 TRAP JT 1.91334 1.91334 2.39167 2.39167
    328 TRAP JT 1.91334 1.91334 2.39167 2.39167
    329 TRAP JT 1.91334 1.91334 2.39167 2.39167
    330 TRAP JT 1.91334 1.91334 2.39167 2.39167
    331 TRAP JT 1.91334 1.91334 2.39167 2.39167
    332 TRAP JT 1.91334 1.91334 2.39167 2.39167
    333 TRAP JT 1.91334 1.91334 2.39167 2.39167
    334 TRAP JT 1.91334 1.91334 2.39167 2.39167
    335 TRAP JT 1.91334 1.91334 2.39167 2.39167
    336 TRAP JT 1.91334 1.91334 2.39167 2.39167
    337 TRAP JT 1.91334 1.91334 2.39167 2.39167
    338 TRAP JT 1.91334 1.91334 2.39167 2.39167
    339 TRAP JT 1.91334 1.91334 2.39167 2.39167
    340 TRAP JT 1.91334 1.91334 2.39167 2.39167
    341 TRAP JT 1.91334 1.91334 2.39167 2.39167
    342 TRAP JT 1.91334 1.91334 2.39167 2.39167
    343 TRAP JT 1.91334 1.91334 2.39167 2.39167
    344 TRAP JT 1.91334 1.91334 2.39167 2.39167
    345 TRAP JT 1.91334 1.91334 2.39167 2.39167
    346 TRAP JT 1.91334 1.91334 2.39167 2.39167
    347 TRAP JT 1.91334 1.91334 2.39167 2.39167
    348 TRAP JT 1.91334 1.91334 2.39167 2.39167
    349 TRAP JT 1.91334 1.91334 2.39167 2.39167
    350 TRAP JT 1.91334 1.91334 2.39167 2.39167
    351 TRAP JT 1.91334 1.91334 2.39167 2.39167
    352 TRAP JT 1.91334 1.91334 2.39167 2.39167
    353 TRAP JT 1.91334 1.91334 2.39167 2.39167
    354 TRAP JT 1.91334 1.91334 2.39167 2.39167
    355 TRAP JT 1.91334 1.91334 2.39167 2.39167
    356 TRAP JT 1.91334 1.91334 2.39167 2.39167
    357 TRAP JT 1.91334 1.91334 2.39167 2.39167
    358 TRAP JT 1.91334 1.91334 2.39167 2.39167
    359 TRAP JT 1.91334 1.91334 2.39167 2.39167
    360 TRAP JT 1.91334 1.91334 2.39167 2.39167
    361 TRAP JT 1.91334 1.91334 2.39167 2.39167
    362 TRAP JT 1.91334 1.91334 2.39167 2.39167
    363 TRAP JT 1.91334 1.91334 2.39167 2.39167
    364 TRAP JT 1.91334 1.91334 2.39167 2.39167
    365 TRAP JT 1.91334 1.91334 2.39167 2.39167
    366 TRAP JT 1.91334 1.91334 2.39167 2.39167
    367 TRAP JT 1.91334 1.91334 2.39167 2.39167
    368 TRAP JT 1.91334 1.91334 2.39167 2.39167
    369 TRAP JT 1.91334 1.91334 2.39167 2.39167
    370 TRAP JT 1.91334 1.91334 2.39167 2.39167
    371 TRAP JT 1.91334 1.91334 2.39167 2.39167
    372 TRAP JT 1.91334 1.91334 2.39167 2.39167
    373 TRAP JT 1.91334 1.91334 2.39167 2.39167
    374 TRAP JT 2.39167 2.39167 2.87 2.87
    375 TRAP JT 2.39167 2.39167 2.87 2.87
    376 TRAP JT 2.39167 2.39167 2.87 2.87
    377 TRAP JT 2.39167 2.39167 2.87 2.87
    378 TRAP JT 2.39167 2.39167 2.87 2.87
    379 TRAP JT 2.39167 2.39167 2.87 2.87
    380 TRAP JT 2.39167 2.39167 2.87 2.87
    381 TRAP JT 2.39167 2.39167 2.87 2.87
    382 TRAP JT 2.39167 2.39167 2.87 2.87
    383 TRAP JT 2.39167 2.39167 2.87 2.87
    384 TRAP JT 2.39167 2.39167 2.87 2.87
    385 TRAP JT 2.39167 2.39167 2.87 2.87
    386 TRAP JT 2.39167 2.39167 2.87 2.87
    387 TRAP JT 2.39167 2.39167 2.87 2.87
    388 TRAP JT 2.39167 2.39167 2.87 2.87
    389 TRAP JT 2.39167 2.39167 2.87 2.87
    390 TRAP JT 2.39167 2.39167 2.87 2.87
    391 TRAP JT 2.39167 2.39167 2.87 2.87
    392 TRAP JT 2.39167 2.39167 2.87 2.87
    393 TRAP JT 2.39167 2.39167 2.87 2.87
    394 TRAP JT 2.39167 2.39167 2.87 2.87
    395 TRAP JT 2.39167 2.39167 2.87 2.87
    396 TRAP JT 2.39167 2.39167 2.87 2.87
    397 TRAP JT 2.39167 2.39167 2.87 2.87
    398 TRAP JT 2.39167 2.39167 2.87 2.87
    399 TRAP JT 2.39167 2.39167 2.87 2.87
    400 TRAP JT 2.39167 2.39167 2.87 2.87
    401 TRAP JT 2.39167 2.39167 2.87 2.87
    402 TRAP JT 2.39167 2.39167 2.87 2.87
    403 TRAP JT 2.39167 2.39167 2.87 2.87
    404 TRAP JT 2.39167 2.39167 2.87 2.87
    405 TRAP JT 2.39167 2.39167 2.87 2.87
    406 TRAP JT 2.39167 2.39167 2.87 2.87
    407 TRAP JT 2.39167 2.39167 2.87 2.87
    408 TRAP JT 2.39167 2.39167 2.87 2.87
    409 TRAP JT 2.39167 2.39167 2.87 2.87
    410 TRAP JT 2.39167 2.39167 2.87 2.87
    411 TRAP JT 2.39167 2.39167 2.87 2.87
    412 TRAP JT 2.39167 2.39167 2.87 2.87
    413 TRAP JT 2.39167 2.39167 2.87 2.87
    414 TRAP JT 2.39167 2.39167 2.87 2.87
    415 TRAP JT 2.39167 2.39167 2.87 2.87
    416 TRAP JT 2.39167 2.39167 2.87 2.87
    417 TRAP JT 2.39167 2.39167 2.87 2.87
    418 TRAP JT 2.39167 2.39167 2.87 2.87
    419 TRAP JT 2.39167 2.39167 2.87 2.87
    420 TRAP JT 2.39167 2.39167 2.87 2.87
    421 TRAP JT 2.39167 2.39167 2.87 2.87
    422 TRAP JT 2.39167 2.39167 2.87 2.87
    423 TRAP JT 2.39167 2.39167 2.87 2.87
    424 TRAP JT 2.39167 2.39167 2.87 2.87
    425 TRAP JT 2.39167 2.39167 2.87 2.87
    426 TRAP JT 2.39167 2.39167 2.87 2.87
    427 TRAP JT 2.39167 2.39167 2.87 2.87
    428 TRAP JT 2.39167 2.39167 2.87 2.87
    429 TRAP JT 2.39167 2.39167 2.87 2.87
    430 TRAP JT 2.39167 2.39167 2.87 2.87
    431 TRAP JT 2.39167 2.39167 2.87 2.87
    432 TRAP JT 2.39167 2.39167 2.87 2.87
    433 TRAP JT 2.39167 2.39167 2.87 2.87
    434 TRAP JT 2.39167 2.39167 2.87 2.87
    435 TRAP JT 2.39167 2.39167 2.87 2.87
    436 TRAP JT 2.39167 2.39167 2.87 2.87
    437 TRAP JT 2.39167 2.39167 2.87 2.87
    438 TRAP JT 2.39167 2.39167 2.87 2.87
    439 TRAP JT 2.39167 2.39167 2.87 2.87
    440 TRAP JT 2.39167 2.39167 2.87 2.87
    441 TRAP JT 2.39167 2.39167 2.87 2.87
    442 TRAP JT 2.39167 2.39167 2.87 2.87
    443 TRAP JT 2.39167 2.39167 2.87 2.87
    444 TRAP JT 2.39167 2.39167 2.87 2.87
    445 TRAP JT 2.39167 2.39167 2.87 2.87
    446 TRAP JT 2.39167 2.39167 2.87 2.87
    447 TRAP JT 2.39167 2.39167 2.87 2.87
    448 TRAP JT 0 0 0.478341 0.478341
    449 TRAP JT 0 0 0.478332 0.478341
    450 TRAP JT 0 0 0.478341 0.478332
    451 TRAP JT 0 0 0.478332 0.478341
    452 TRAP JT 0 0 0.478341 0.478332
    453 TRAP JT 0 0 0.478341 0.478341
    454 TRAP JT 0 0 0.478341 0.478341
    455 TRAP JT 0 0 0.478341 0.478341
    456 TRAP JT 0 0 0.478341 0.478341
    457 TRAP JT 0 0 0.478341 0.478341
    458 TRAP JT 0 0 0.478341 0.478341
    459 TRAP JT 0 0 0.478332 0.478341
    460 TRAP JT 0 0 0.478341 0.478332
    461 TRAP JT 0 0 0.478332 0.478341
    462 TRAP JT 0 0 0.478332 0.478332
    463 TRAP JT 0 0 0.478332 0.478332
    464 TRAP JT 0 0 0.478341 0.478332
    465 TRAP JT 0 0 0.478341 0.478341
    466 TRAP JT 0 0 0.478341 0.478341
    467 TRAP JT 0 0 0.478341 0.478341
    468 TRAP JT 0 0 0.478341 0.478341
    469 TRAP JT 0 0 0.478341 0.478341
    470 TRAP JT 0 0 0.478332 0.478341
    471 TRAP JT 0 0 0.478341 0.478332
    472 TRAP JT 0 0 0.478341 0.478341
    473 TRAP JT 0 0 0.478341 0.478341
    474 TRAP JT 0 0 0.478341 0.478341
    475 TRAP JT 0 0 0.478341 0.478341
    476 TRAP JT 0 0 0.478332 0.478341
    477 TRAP JT 0 0 0.478341 0.478332
    478 TRAP JT 0 0 0.478341 0.478341
    479 TRAP JT 0 0 0.478341 0.478341
    480 TRAP JT 0 0 0.478341 0.478341
    481 TRAP JT 0 0 0.478341 0.478341
    482 TRAP JT 0 0 0.478341 0.478341
    483 TRAP JT 0 0 0.478341 0.478341
    484 TRAP JT 0 0 0.478341 0.478341
    485 TRAP JT 0 0 0.478341 0.478341
    486 TRAP JT 0 0 0.478341 0.478341
    487 TRAP JT 0 0 0.478341 0.478341
    488 TRAP JT 0 0 0.478341 0.478341
    489 TRAP JT 0 0 0.478341 0.478341
    490 TRAP JT 0 0 0.478341 0.478341
    491 TRAP JT 0 0 0.478341 0.478341
    492 TRAP JT 0 0 0.478341 0.478341
    493 TRAP JT 0 0 0.478341 0.478341
    494 TRAP JT 0 0 0.478341 0.478341
    495 TRAP JT 0 0 0.478341 0.478341
    496 TRAP JT 0 0 0.478341 0.478341
    497 TRAP JT 0 0 0.478341 0.478341
    498 TRAP JT 0 0 0.478341 0.478341
    499 TRAP JT 0 0 0.478341 0.478341
    500 TRAP JT 0 0 0.478341 0.478341
    501 TRAP JT 0 0 0.478341 0.478341
    502 TRAP JT 0 0 0.478341 0.478341
    503 TRAP JT 0 0 0.478341 0.478341
    504 TRAP JT 0 0 0.478341 0.478341
    505 TRAP JT 0 0 0.478341 0.478341
    506 TRAP JT 0 0 0.478341 0.478341
    507 TRAP JT 0 0 0.478341 0.478341
    508 TRAP JT 0 0 0.478341 0.478341
    509 TRAP JT 0 0 0.478341 0.478341
    510 TRAP JT 0 0 0.478341 0.478341
    511 TRAP JT 0 0 0.478341 0.478341
    512 TRAP JT 0 0 0.478341 0.478341
    513 TRAP JT 0 0 0.478341 0.478341
    514 TRAP JT 0 0 0.478341 0.478341
    515 TRAP JT 0 0 0.478341 0.478341
    516 TRAP JT 0 0 0.478341 0.478341
    517 TRAP JT 0 0 0.478341 0.478341
    518 TRAP JT 0 0 0.478341 0.478341
    519 TRAP JT 0 0 0.478341 0.478341
    520 TRAP JT 0 0 0.478341 0.478341
    521 TRAP JT 0 0 0.478341 0.478341
    522 TRAP JT 0.478341 0.478341 0.956673 0.956673
    523 TRAP JT 0.478341 0.478332 0.956673 0.956673
    524 TRAP JT 0.478332 0.478341 0.956673 0.956673
    525 TRAP JT 0.478341 0.478332 0.956673 0.956673
    526 TRAP JT 0.478332 0.478341 0.956673 0.956673
    527 TRAP JT 0.478341 0.478341 0.956673 0.956673
    528 TRAP JT 0.478341 0.478341 0.956673 0.956673
    529 TRAP JT 0.478341 0.478341 0.956673 0.956673
    530 TRAP JT 0.478341 0.478341 0.956673 0.956673
    531 TRAP JT 0.478341 0.478341 0.956673 0.956673
    532 TRAP JT 0.478341 0.478341 0.956673 0.956673
    533 TRAP JT 0.478341 0.478332 0.956673 0.956673
    534 TRAP JT 0.478332 0.478341 0.956673 0.956673
    535 TRAP JT 0.478341 0.478332 0.956673 0.956673
    536 TRAP JT 0.478332 0.478332 0.956673 0.956673
    537 TRAP JT 0.478332 0.478332 0.956673 0.956673
    538 TRAP JT 0.478332 0.478341 0.956673 0.956673
    539 TRAP JT 0.478341 0.478341 0.956673 0.956673
    540 TRAP JT 0.478341 0.478341 0.956673 0.956673
    541 TRAP JT 0.478341 0.478341 0.956673 0.956673
    542 TRAP JT 0.478341 0.478341 0.956673 0.956673
    543 TRAP JT 0.478341 0.478341 0.956673 0.956673
    544 TRAP JT 0.478341 0.478332 0.956673 0.956673
    545 TRAP JT 0.478332 0.478341 0.956673 0.956673
    546 TRAP JT 0.478341 0.478341 0.956673 0.956673
    547 TRAP JT 0.478341 0.478341 0.956673 0.956673
    548 TRAP JT 0.478341 0.478341 0.956673 0.956673
    549 TRAP JT 0.478341 0.478341 0.956673 0.956673
    550 TRAP JT 0.478341 0.478332 0.956673 0.956673
    551 TRAP JT 0.478332 0.478341 0.956673 0.956673
    552 TRAP JT 0.478341 0.478341 0.956673 0.956673
    553 TRAP JT 0.478341 0.478341 0.956673 0.956673
    554 TRAP JT 0.478341 0.478341 0.956673 0.956673
    555 TRAP JT 0.478341 0.478341 0.956673 0.956673
    556 TRAP JT 0.478341 0.478341 0.956673 0.956673
    557 TRAP JT 0.478341 0.478341 0.956673 0.956673
    558 TRAP JT 0.478341 0.478341 0.956673 0.956673
    559 TRAP JT 0.478341 0.478341 0.956673 0.956673
    560 TRAP JT 0.478341 0.478341 0.956673 0.956673
    561 TRAP JT 0.478341 0.478341 0.956673 0.956673
    562 TRAP JT 0.478341 0.478341 0.956673 0.956673
    563 TRAP JT 0.478341 0.478341 0.956673 0.956673
    564 TRAP JT 0.478341 0.478341 0.956673 0.956673
    565 TRAP JT 0.478341 0.478341 0.956673 0.956673
    566 TRAP JT 0.478341 0.478341 0.956673 0.956673
    567 TRAP JT 0.478341 0.478341 0.956673 0.956673
    568 TRAP JT 0.478341 0.478341 0.956673 0.956673
    569 TRAP JT 0.478341 0.478341 0.956673 0.956673
    570 TRAP JT 0.478341 0.478341 0.956673 0.956673
    571 TRAP JT 0.478341 0.478341 0.956673 0.956673
    572 TRAP JT 0.478341 0.478341 0.956673 0.956673
    573 TRAP JT 0.478341 0.478341 0.956673 0.956673
    574 TRAP JT 0.478341 0.478341 0.956673 0.956673
    575 TRAP JT 0.478341 0.478341 0.956673 0.956673
    576 TRAP JT 0.478341 0.478341 0.956673 0.956673
    577 TRAP JT 0.478341 0.478341 0.956673 0.956673
    578 TRAP JT 0.478341 0.478341 0.956673 0.956673
    579 TRAP JT 0.478341 0.478341 0.956673 0.956673
    580 TRAP JT 0.478341 0.478341 0.956673 0.956673
    581 TRAP JT 0.478341 0.478341 0.956673 0.956673
    582 TRAP JT 0.478341 0.478341 0.956673 0.956673
    583 TRAP JT 0.478341 0.478341 0.956673 0.956673
    584 TRAP JT 0.478341 0.478341 0.956673 0.956673
    585 TRAP JT 0.478341 0.478341 0.956673 0.956673
    586 TRAP JT 0.478341 0.478341 0.956673 0.956673
    587 TRAP JT 0.478341 0.478341 0.956673 0.956673
    588 TRAP JT 0.478341 0.478341 0.956673 0.956673
    589 TRAP JT 0.478341 0.478341 0.956673 0.956673
    590 TRAP JT 0.478341 0.478341 0.956673 0.956673
    591 TRAP JT 0.478341 0.478341 0.956673 0.956673
    592 TRAP JT 0.478341 0.478341 0.956673 0.956673
    593 TRAP JT 0.478341 0.478341 0.956673 0.956673
    594 TRAP JT 0.478341 0.478341 0.956673 0.956673
    595 TRAP JT 0.478341 0.478341 0.956673 0.956673
    596 TRAP JT 0.956673 0.956673 1.435 1.435
    597 TRAP JT 0.956673 0.956673 1.435 1.435
    598 TRAP JT 0.956673 0.956673 1.435 1.435
    599 TRAP JT 0.956673 0.956673 1.435 1.435
    600 TRAP JT 0.956673 0.956673 1.435 1.435
    601 TRAP JT 0.956673 0.956673 1.435 1.435
    602 TRAP JT 0.956673 0.956673 1.435 1.435
    603 TRAP JT 0.956673 0.956673 1.435 1.435
    604 TRAP JT 0.956673 0.956673 1.435 1.435
    605 TRAP JT 0.956673 0.956673 1.435 1.435
    606 TRAP JT 0.956673 0.956673 1.435 1.435
    607 TRAP JT 0.956673 0.956673 1.435 1.435
    608 TRAP JT 0.956673 0.956673 1.435 1.435
    609 TRAP JT 0.956673 0.956673 1.435 1.435
    610 TRAP JT 0.956673 0.956673 1.435 1.435
    611 TRAP JT 0.956673 0.956673 1.435 1.435
    612 TRAP JT 0.956673 0.956673 1.435 1.435
    613 TRAP JT 0.956673 0.956673 1.435 1.435
    614 TRAP JT 0.956673 0.956673 1.435 1.435
    615 TRAP JT 0.956673 0.956673 1.435 1.435
    616 TRAP JT 0.956673 0.956673 1.435 1.435
    617 TRAP JT 0.956673 0.956673 1.435 1.435
    618 TRAP JT 0.956673 0.956673 1.435 1.435
    619 TRAP JT 0.956673 0.956673 1.435 1.435
    620 TRAP JT 0.956673 0.956673 1.435 1.435
    621 TRAP JT 0.956673 0.956673 1.435 1.435
    622 TRAP JT 0.956673 0.956673 1.435 1.435
    623 TRAP JT 0.956673 0.956673 1.435 1.435
    624 TRAP JT 0.956673 0.956673 1.435 1.435
    625 TRAP JT 0.956673 0.956673 1.435 1.435
    626 TRAP JT 0.956673 0.956673 1.435 1.435
    627 TRAP JT 0.956673 0.956673 1.435 1.435
    628 TRAP JT 0.956673 0.956673 1.435 1.435
    629 TRAP JT 0.956673 0.956673 1.435 1.435
    630 TRAP JT 0.956673 0.956673 1.435 1.435
    631 TRAP JT 0.956673 0.956673 1.435 1.435
    632 TRAP JT 0.956673 0.956673 1.435 1.435
    633 TRAP JT 0.956673 0.956673 1.435 1.435
    634 TRAP JT 0.956673 0.956673 1.435 1.435
    635 TRAP JT 0.956673 0.956673 1.435 1.435
    636 TRAP JT 0.956673 0.956673 1.435 1.435
    637 TRAP JT 0.956673 0.956673 1.435 1.435
    638 TRAP JT 0.956673 0.956673 1.435 1.435
    639 TRAP JT 0.956673 0.956673 1.435 1.435
    640 TRAP JT 0.956673 0.956673 1.435 1.435
    641 TRAP JT 0.956673 0.956673 1.435 1.435
    642 TRAP JT 0.956673 0.956673 1.435 1.435
    643 TRAP JT 0.956673 0.956673 1.435 1.435
    644 TRAP JT 0.956673 0.956673 1.435 1.435
    645 TRAP JT 0.956673 0.956673 1.435 1.435
    646 TRAP JT 0.956673 0.956673 1.435 1.435
    647 TRAP JT 0.956673 0.956673 1.435 1.435
    648 TRAP JT 0.956673 0.956673 1.435 1.435
    649 TRAP JT 0.956673 0.956673 1.435 1.435
    650 TRAP JT 0.956673 0.956673 1.435 1.435
    651 TRAP JT 0.956673 0.956673 1.435 1.435
    652 TRAP JT 0.956673 0.956673 1.435 1.435
    653 TRAP JT 0.956673 0.956673 1.435 1.435
    654 TRAP JT 0.956673 0.956673 1.435 1.435
    655 TRAP JT 0.956673 0.956673 1.435 1.435
    656 TRAP JT 0.956673 0.956673 1.435 1.435
    657 TRAP JT 0.956673 0.956673 1.435 1.435
    658 TRAP JT 0.956673 0.956673 1.435 1.435
    659 TRAP JT 0.956673 0.956673 1.435 1.435
    660 TRAP JT 0.956673 0.956673 1.435 1.435
    661 TRAP JT 0.956673 0.956673 1.435 1.435
    662 TRAP JT 0.956673 0.956673 1.435 1.435
    663 TRAP JT 0.956673 0.956673 1.435 1.435
    664 TRAP JT 0.956673 0.956673 1.435 1.435
    665 TRAP JT 0.956673 0.956673 1.435 1.435
    666 TRAP JT 0.956673 0.956673 1.435 1.435
    667 TRAP JT 0.956673 0.956673 1.435 1.435
    668 TRAP JT 0.956673 0.956673 1.435 1.435
    669 TRAP JT 0.956673 0.956673 1.435 1.435
    670 TRAP JT 1.435 1.435 1.91334 1.91334
    671 TRAP JT 1.435 1.435 1.91334 1.91334
    672 TRAP JT 1.435 1.435 1.91334 1.91334
    673 TRAP JT 1.435 1.435 1.91334 1.91334
    674 TRAP JT 1.435 1.435 1.91334 1.91334
    675 TRAP JT 1.435 1.435 1.91334 1.91334
    676 TRAP JT 1.435 1.435 1.91334 1.91334
    677 TRAP JT 1.435 1.435 1.91334 1.91334
    678 TRAP JT 1.435 1.435 1.91334 1.91334
    679 TRAP JT 1.435 1.435 1.91334 1.91334
    680 TRAP JT 1.435 1.435 1.91334 1.91334
    681 TRAP JT 1.435 1.435 1.91334 1.91334
    682 TRAP JT 1.435 1.435 1.91334 1.91334
    683 TRAP JT 1.435 1.435 1.91334 1.91334
    684 TRAP JT 1.435 1.435 1.91334 1.91334
    685 TRAP JT 1.435 1.435 1.91334 1.91334
    686 TRAP JT 1.435 1.435 1.91334 1.91334
    687 TRAP JT 1.435 1.435 1.91334 1.91334
    688 TRAP JT 1.435 1.435 1.91334 1.91334
    689 TRAP JT 1.435 1.435 1.91334 1.91334
    690 TRAP JT 1.435 1.435 1.91334 1.91334
    691 TRAP JT 1.435 1.435 1.91334 1.91334
    692 TRAP JT 1.435 1.435 1.91334 1.91334
    693 TRAP JT 1.435 1.435 1.91334 1.91334
    694 TRAP JT 1.435 1.435 1.91334 1.91334
    695 TRAP JT 1.435 1.435 1.91334 1.91334
    696 TRAP JT 1.435 1.435 1.91334 1.91334
    697 TRAP JT 1.435 1.435 1.91334 1.91334
    698 TRAP JT 1.435 1.435 1.91334 1.91334
    699 TRAP JT 1.435 1.435 1.91334 1.91334
    700 TRAP JT 1.435 1.435 1.91334 1.91334
    701 TRAP JT 1.435 1.435 1.91334 1.91334
    702 TRAP JT 1.435 1.435 1.91334 1.91334
    703 TRAP JT 1.435 1.435 1.91334 1.91334
    704 TRAP JT 1.435 1.435 1.91334 1.91334
    705 TRAP JT 1.435 1.435 1.91334 1.91334
    706 TRAP JT 1.435 1.435 1.91334 1.91334
    707 TRAP JT 1.435 1.435 1.91334 1.91334
    708 TRAP JT 1.435 1.435 1.91334 1.91334
    709 TRAP JT 1.435 1.435 1.91334 1.91334
    710 TRAP JT 1.435 1.435 1.91334 1.91334
    711 TRAP JT 1.435 1.435 1.91334 1.91334
    712 TRAP JT 1.435 1.435 1.91334 1.91334
    713 TRAP JT 1.435 1.435 1.91334 1.91334
    714 TRAP JT 1.435 1.435 1.91334 1.91334
    715 TRAP JT 1.435 1.435 1.91334 1.91334
    716 TRAP JT 1.435 1.435 1.91334 1.91334
    717 TRAP JT 1.435 1.435 1.91334 1.91334
    718 TRAP JT 1.435 1.435 1.91334 1.91334
    719 TRAP JT 1.435 1.435 1.91334 1.91334
    720 TRAP JT 1.435 1.435 1.91334 1.91334
    721 TRAP JT 1.435 1.435 1.91334 1.91334
    722 TRAP JT 1.435 1.435 1.91334 1.91334
    723 TRAP JT 1.435 1.435 1.91334 1.91334
    724 TRAP JT 1.435 1.435 1.91334 1.91334
    725 TRAP JT 1.435 1.435 1.91334 1.91334
    726 TRAP JT 1.435 1.435 1.91334 1.91334
    727 TRAP JT 1.435 1.435 1.91334 1.91334
    728 TRAP JT 1.435 1.435 1.91334 1.91334
    729 TRAP JT 1.435 1.435 1.91334 1.91334
    730 TRAP JT 1.435 1.435 1.91334 1.91334
    731 TRAP JT 1.435 1.435 1.91334 1.91334
    732 TRAP JT 1.435 1.435 1.91334 1.91334
    733 TRAP JT 1.435 1.435 1.91334 1.91334
    734 TRAP JT 1.435 1.435 1.91334 1.91334
    735 TRAP JT 1.435 1.435 1.91334 1.91334
    736 TRAP JT 1.435 1.435 1.91334 1.91334
    737 TRAP JT 1.435 1.435 1.91334 1.91334
    738 TRAP JT 1.435 1.435 1.91334 1.91334
    739 TRAP JT 1.435 1.435 1.91334 1.91334
    740 TRAP JT 1.435 1.435 1.91334 1.91334
    741 TRAP JT 1.435 1.435 1.91334 1.91334
    742 TRAP JT 1.435 1.435 1.91334 1.91334
    743 TRAP JT 1.435 1.435 1.91334 1.91334
    744 TRAP JT 1.91334 1.91334 2.39167 2.39167
    745 TRAP JT 1.91334 1.91334 2.39167 2.39167
    746 TRAP JT 1.91334 1.91334 2.39167 2.39167
    747 TRAP JT 1.91334 1.91334 2.39167 2.39167
    748 TRAP JT 1.91334 1.91334 2.39167 2.39167
    749 TRAP JT 1.91334 1.91334 2.39167 2.39167
    750 TRAP JT 1.91334 1.91334 2.39167 2.39167
    751 TRAP JT 1.91334 1.91334 2.39167 2.39167
    752 TRAP JT 1.91334 1.91334 2.39167 2.39167
    753 TRAP JT 1.91334 1.91334 2.39167 2.39167
    754 TRAP JT 1.91334 1.91334 2.39167 2.39167
    755 TRAP JT 1.91334 1.91334 2.39167 2.39167
    756 TRAP JT 1.91334 1.91334 2.39167 2.39167
    757 TRAP JT 1.91334 1.91334 2.39167 2.39167
    758 TRAP JT 1.91334 1.91334 2.39167 2.39167
    759 TRAP JT 1.91334 1.91334 2.39167 2.39167
    760 TRAP JT 1.91334 1.91334 2.39167 2.39167
    761 TRAP JT 1.91334 1.91334 2.39167 2.39167
    762 TRAP JT 1.91334 1.91334 2.39167 2.39167
    763 TRAP JT 1.91334 1.91334 2.39167 2.39167
    764 TRAP JT 1.91334 1.91334 2.39167 2.39167
    765 TRAP JT 1.91334 1.91334 2.39167 2.39167
    766 TRAP JT 1.91334 1.91334 2.39167 2.39167
    767 TRAP JT 1.91334 1.91334 2.39167 2.39167
    768 TRAP JT 1.91334 1.91334 2.39167 2.39167
    769 TRAP JT 1.91334 1.91334 2.39167 2.39167
    770 TRAP JT 1.91334 1.91334 2.39167 2.39167
    771 TRAP JT 1.91334 1.91334 2.39167 2.39167
    772 TRAP JT 1.91334 1.91334 2.39167 2.39167
    773 TRAP JT 1.91334 1.91334 2.39167 2.39167
    774 TRAP JT 1.91334 1.91334 2.39167 2.39167
    775 TRAP JT 1.91334 1.91334 2.39167 2.39167
    776 TRAP JT 1.91334 1.91334 2.39167 2.39167
    777 TRAP JT 1.91334 1.91334 2.39167 2.39167
    778 TRAP JT 1.91334 1.91334 2.39167 2.39167
    779 TRAP JT 1.91334 1.91334 2.39167 2.39167
    780 TRAP JT 1.91334 1.91334 2.39167 2.39167
    781 TRAP JT 1.91334 1.91334 2.39167 2.39167
    782 TRAP JT 1.91334 1.91334 2.39167 2.39167
    783 TRAP JT 1.91334 1.91334 2.39167 2.39167
    784 TRAP JT 1.91334 1.91334 2.39167 2.39167
    785 TRAP JT 1.91334 1.91334 2.39167 2.39167
    786 TRAP JT 1.91334 1.91334 2.39167 2.39167
    787 TRAP JT 1.91334 1.91334 2.39167 2.39167
    788 TRAP JT 1.91334 1.91334 2.39167 2.39167
    789 TRAP JT 1.91334 1.91334 2.39167 2.39167
    790 TRAP JT 1.91334 1.91334 2.39167 2.39167
    791 TRAP JT 1.91334 1.91334 2.39167 2.39167
    792 TRAP JT 1.91334 1.91334 2.39167 2.39167
    793 TRAP JT 1.91334 1.91334 2.39167 2.39167
    794 TRAP JT 1.91334 1.91334 2.39167 2.39167
    795 TRAP JT 1.91334 1.91334 2.39167 2.39167
    796 TRAP JT 1.91334 1.91334 2.39167 2.39167
    797 TRAP JT 1.91334 1.91334 2.39167 2.39167
    798 TRAP JT 1.91334 1.91334 2.39167 2.39167
    799 TRAP JT 1.91334 1.91334 2.39167 2.39167
    800 TRAP JT 1.91334 1.91334 2.39167 2.39167
    801 TRAP JT 1.91334 1.91334 2.39167 2.39167
    802 TRAP JT 1.91334 1.91334 2.39167 2.39167
    803 TRAP JT 1.91334 1.91334 2.39167 2.39167
    804 TRAP JT 1.91334 1.91334 2.39167 2.39167
    805 TRAP JT 1.91334 1.91334 2.39167 2.39167
    806 TRAP JT 1.91334 1.91334 2.39167 2.39167
    807 TRAP JT 1.91334 1.91334 2.39167 2.39167
    808 TRAP JT 1.91334 1.91334 2.39167 2.39167
    809 TRAP JT 1.91334 1.91334 2.39167 2.39167
    810 TRAP JT 1.91334 1.91334 2.39167 2.39167
    811 TRAP JT 1.91334 1.91334 2.39167 2.39167
    812 TRAP JT 1.91334 1.91334 2.39167 2.39167
    813 TRAP JT 1.91334 1.91334 2.39167 2.39167
    814 TRAP JT 1.91334 1.91334 2.39167 2.39167
    815 TRAP JT 1.91334 1.91334 2.39167 2.39167
    816 TRAP JT 1.91334 1.91334 2.39167 2.39167
    817 TRAP JT 1.91334 1.91334 2.39167 2.39167
    818 TRAP JT 2.39167 2.39167 2.87 2.87
    819 TRAP JT 2.39167 2.39167 2.87 2.87
    820 TRAP JT 2.39167 2.39167 2.87 2.87
    821 TRAP JT 2.39167 2.39167 2.87 2.87
    822 TRAP JT 2.39167 2.39167 2.87 2.87
    823 TRAP JT 2.39167 2.39167 2.87 2.87
    824 TRAP JT 2.39167 2.39167 2.87 2.87
    825 TRAP JT 2.39167 2.39167 2.87 2.87
    826 TRAP JT 2.39167 2.39167 2.87 2.87
    827 TRAP JT 2.39167 2.39167 2.87 2.87
    828 TRAP JT 2.39167 2.39167 2.87 2.87
    829 TRAP JT 2.39167 2.39167 2.87 2.87
    830 TRAP JT 2.39167 2.39167 2.87 2.87
    831 TRAP JT 2.39167 2.39167 2.87 2.87
    832 TRAP JT 2.39167 2.39167 2.87 2.87
    833 TRAP JT 2.39167 2.39167 2.87 2.87
    834 TRAP JT 2.39167 2.39167 2.87 2.87
    835 TRAP JT 2.39167 2.39167 2.87 2.87
    836 TRAP JT 2.39167 2.39167 2.87 2.87
    837 TRAP JT 2.39167 2.39167 2.87 2.87
    838 TRAP JT 2.39167 2.39167 2.87 2.87
    839 TRAP JT 2.39167 2.39167 2.87 2.87
    840 TRAP JT 2.39167 2.39167 2.87 2.87
    841 TRAP JT 2.39167 2.39167 2.87 2.87
    842 TRAP JT 2.39167 2.39167 2.87 2.87
    843 TRAP JT 2.39167 2.39167 2.87 2.87
    844 TRAP JT 2.39167 2.39167 2.87 2.87
    845 TRAP JT 2.39167 2.39167 2.87 2.87
    846 TRAP JT 2.39167 2.39167 2.87 2.87
    847 TRAP JT 2.39167 2.39167 2.87 2.87
    848 TRAP JT 2.39167 2.39167 2.87 2.87
    849 TRAP JT 2.39167 2.39167 2.87 2.87
    850 TRAP JT 2.39167 2.39167 2.87 2.87
    851 TRAP JT 2.39167 2.39167 2.87 2.87
    852 TRAP JT 2.39167 2.39167 2.87 2.87
    853 TRAP JT 2.39167 2.39167 2.87 2.87
    854 TRAP JT 2.39167 2.39167 2.87 2.87
    855 TRAP JT 2.39167 2.39167 2.87 2.87
    856 TRAP JT 2.39167 2.39167 2.87 2.87
    857 TRAP JT 2.39167 2.39167 2.87 2.87
    858 TRAP JT 2.39167 2.39167 2.87 2.87
    859 TRAP JT 2.39167 2.39167 2.87 2.87
    860 TRAP JT 2.39167 2.39167 2.87 2.87
    861 TRAP JT 2.39167 2.39167 2.87 2.87
    862 TRAP JT 2.39167 2.39167 2.87 2.87
    863 TRAP JT 2.39167 2.39167 2.87 2.87
    864 TRAP JT 2.39167 2.39167 2.87 2.87
    865 TRAP JT 2.39167 2.39167 2.87 2.87
    866 TRAP JT 2.39167 2.39167 2.87 2.87
    867 TRAP JT 2.39167 2.39167 2.87 2.87
    868 TRAP JT 2.39167 2.39167 2.87 2.87
    869 TRAP JT 2.39167 2.39167 2.87 2.87
    870 TRAP JT 2.39167 2.39167 2.87 2.87
    871 TRAP JT 2.39167 2.39167 2.87 2.87
    872 TRAP JT 2.39167 2.39167 2.87 2.87
    873 TRAP JT 2.39167 2.39167 2.87 2.87
    874 TRAP JT 2.39167 2.39167 2.87 2.87
    875 TRAP JT 2.39167 2.39167 2.87 2.87
    876 TRAP JT 2.39167 2.39167 2.87 2.87
    877 TRAP JT 2.39167 2.39167 2.87 2.87
    878 TRAP JT 2.39167 2.39167 2.87 2.87
    879 TRAP JT 2.39167 2.39167 2.87 2.87
    880 TRAP JT 2.39167 2.39167 2.87 2.87
    881 TRAP JT 2.39167 2.39167 2.87 2.87
    882 TRAP JT 2.39167 2.39167 2.87 2.87
    883 TRAP JT 2.39167 2.39167 2.87 2.87
    884 TRAP JT 2.39167 2.39167 2.87 2.87
    885 TRAP JT 2.39167 2.39167 2.87 2.87
    886 TRAP JT 2.39167 2.39167 2.87 2.87
    887 TRAP JT 2.39167 2.39167 2.87 2.87
    888 TRAP JT 2.39167 2.39167 2.87 2.87
    889 TRAP JT 2.39167 2.39167 2.87 2.87
    890 TRAP JT 2.39167 2.39167 2.87 2.87
    891 TRAP JT 2.39167 2.39167 2.87 2.87
    *Static earth pressure
    LOAD 3 LOADTYPE None TITLE LL
    ELEMENT LOAD
    1 892 TO 1319 1321 TO 2371 PR GY -0.1
    *Services allowance loads 100 kgf/m2
    LOAD 9 LOADTYPE None TITLE F
    JOINT LOAD
    884 891 898 FZ 1.686
    *Friction loads due to the pipeline (W*0.4)
    LOAD 10 LOADTYPE None TITLE EX+
    SELFWEIGHT X 0.3
    ELEMENT LOAD
    5 TRAP GX JT 3.28 3.28 2.73334 2.73332
    6 TRAP GX JT 3.28 3.28 2.73332 2.73334
    7 TRAP GX JT 3.28 3.28 2.73334 2.73332
    8 TRAP GX JT 3.28 3.28 2.73332 2.73334
    9 TRAP GX JT 3.28 3.28 2.73332 2.73332
    10 TRAP GX JT 3.28 3.28 2.73332 2.73332
    11 TRAP GX JT 3.28 3.28 2.73332 2.73332
    12 TRAP GX JT 3.28 3.28 2.73332 2.73332
    13 TRAP GX JT 3.28 3.28 2.73332 2.73332
    14 TRAP GX JT 3.28 3.28 2.73332 2.73332
    15 TRAP GX JT 3.28 3.28 2.73334 2.73332
    16 TRAP GX JT 3.28 3.28 2.73332 2.73334
    17 TRAP GX JT 3.28 3.28 2.73334 2.73332
    18 TRAP GX JT 3.28 3.28 2.73334 2.73334
    19 TRAP GX JT 3.28 3.28 2.73334 2.73334
    20 TRAP GX JT 3.28 3.28 2.73332 2.73334
    21 TRAP GX JT 3.28 3.28 2.73332 2.73332
    22 TRAP GX JT 3.28 3.28 2.73332 2.73332
    23 TRAP GX JT 3.28 3.28 2.73332 2.73332
    24 TRAP GX JT 3.28 3.28 2.73332 2.73332
    25 TRAP GX JT 3.28 3.28 2.73332 2.73332
    26 TRAP GX JT 3.28 3.28 2.73334 2.73332
    27 TRAP GX JT 3.28 3.28 2.73332 2.73334
    28 TRAP GX JT 3.28 3.28 2.73332 2.73332
    29 TRAP GX JT 3.28 3.28 2.73332 2.73332
    30 TRAP GX JT 3.28 3.28 2.73332 2.73332
    31 TRAP GX JT 3.28 3.28 2.73332 2.73332
    32 TRAP GX JT 3.28 3.28 2.73334 2.73332
    33 TRAP GX JT 3.28 3.28 2.73332 2.73334
    34 TRAP GX JT 3.28 3.28 2.73332 2.73332
    35 TRAP GX JT 3.28 3.28 2.73332 2.73332
    36 TRAP GX JT 3.28 3.28 2.73332 2.73332
    37 TRAP GX JT 3.28 3.28 2.73332 2.73332
    38 TRAP GX JT 3.28 3.28 2.73332 2.73332
    39 TRAP GX JT 3.28 3.28 2.73332 2.73332
    40 TRAP GX JT 3.28 3.28 2.73332 2.73332
    41 TRAP GX JT 3.28 3.28 2.73332 2.73332
    42 TRAP GX JT 3.28 3.28 2.73332 2.73332
    43 TRAP GX JT 3.28 3.28 2.73332 2.73332
    44 TRAP GX JT 3.28 3.28 2.73332 2.73332
    45 TRAP GX JT 3.28 3.28 2.73332 2.73332
    46 TRAP GX JT 3.28 3.28 2.73332 2.73332
    47 TRAP GX JT 3.28 3.28 2.73332 2.73332
    48 TRAP GX JT 3.28 3.28 2.73332 2.73332
    49 TRAP GX JT 3.28 3.28 2.73332 2.73332
    50 TRAP GX JT 3.28 3.28 2.73332 2.73332
    51 TRAP GX JT 3.28 3.28 2.73332 2.73332
    52 TRAP GX JT 3.28 3.28 2.73332 2.73332
    53 TRAP GX JT 3.28 3.28 2.73332 2.73332
    54 TRAP GX JT 3.28 3.28 2.73332 2.73332
    55 TRAP GX JT 3.28 3.28 2.73332 2.73332
    56 TRAP GX JT 3.28 3.28 2.73332 2.73332
    57 TRAP GX JT 3.28 3.28 2.73332 2.73332
    58 TRAP GX JT 3.28 3.28 2.73332 2.73332
    59 TRAP GX JT 3.28 3.28 2.73332 2.73332
    60 TRAP GX JT 3.28 3.28 2.73332 2.73332
    61 TRAP GX JT 3.28 3.28 2.73332 2.73332
    62 TRAP GX JT 3.28 3.28 2.73332 2.73332
    63 TRAP GX JT 3.28 3.28 2.73332 2.73332
    64 TRAP GX JT 3.28 3.28 2.73332 2.73332
    65 TRAP GX JT 3.28 3.28 2.73332 2.73332
    66 TRAP GX JT 3.28 3.28 2.73332 2.73332
    67 TRAP GX JT 3.28 3.28 2.73332 2.73332
    68 TRAP GX JT 3.28 3.28 2.73332 2.73332
    69 TRAP GX JT 3.28 3.28 2.73332 2.73332
    70 TRAP GX JT 3.28 3.28 2.73332 2.73332
    71 TRAP GX JT 3.28 3.28 2.73332 2.73332
    72 TRAP GX JT 3.28 3.28 2.73332 2.73332
    73 TRAP GX JT 3.28 3.28 2.73332 2.73332
    74 TRAP GX JT 3.28 3.28 2.73332 2.73332
    75 TRAP GX JT 3.28 3.28 2.73332 2.73332
    76 TRAP GX JT 3.28 3.28 2.73332 2.73332
    77 TRAP GX JT 3.28 3.28 2.73332 2.73332
    78 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    79 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    80 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    81 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    82 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    83 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    84 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    85 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    86 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    87 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    88 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    89 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    90 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    91 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    92 TRAP GX JT 2.73334 2.73334 2.18666 2.18666
    93 TRAP GX JT 2.73334 2.73334 2.18666 2.18666
    94 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    95 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    96 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    97 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    98 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    99 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    100 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    101 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    102 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    103 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    104 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    105 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    106 TRAP GX JT 2.73332 2.73334 2.18666 2.18666
    107 TRAP GX JT 2.73334 2.73332 2.18666 2.18666
    108 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    109 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    110 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    111 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    112 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    113 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    114 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    115 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    116 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    117 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    118 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    119 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    120 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    121 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    122 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    123 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    124 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    125 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    126 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    127 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    128 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    129 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    130 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    131 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    132 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    133 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    134 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    135 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    136 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    137 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    138 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    139 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    140 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    141 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    142 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    143 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    144 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    145 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    146 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    147 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    148 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    149 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    150 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    151 TRAP GX JT 2.73332 2.73332 2.18666 2.18666
    152 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    153 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    154 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    155 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    156 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    157 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    158 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    159 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    160 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    161 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    162 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    163 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    164 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    165 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    166 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    167 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    168 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    169 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    170 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    171 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    172 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    173 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    174 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    175 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    176 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    177 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    178 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    179 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    180 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    181 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    182 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    183 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    184 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    185 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    186 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    187 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    188 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    189 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    190 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    191 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    192 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    193 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    194 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    195 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    196 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    197 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    198 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    199 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    200 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    201 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    202 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    203 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    204 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    205 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    206 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    207 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    208 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    209 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    210 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    211 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    212 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    213 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    214 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    215 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    216 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    217 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    218 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    219 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    220 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    221 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    222 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    223 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    224 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    225 TRAP GX JT 2.18666 2.18666 1.63999 1.63999
    226 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    227 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    228 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    229 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    230 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    231 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    232 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    233 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    234 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    235 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    236 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    237 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    238 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    239 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    240 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    241 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    242 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    243 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    244 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    245 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    246 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    247 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    248 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    249 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    250 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    251 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    252 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    253 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    254 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    255 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    256 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    257 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    258 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    259 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    260 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    261 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    262 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    263 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    264 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    265 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    266 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    267 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    268 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    269 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    270 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    271 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    272 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    273 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    274 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    275 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    276 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    277 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    278 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    279 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    280 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    281 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    282 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    283 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    284 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    285 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    286 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    287 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    288 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    289 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    290 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    291 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    292 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    293 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    294 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    295 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    296 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    297 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    298 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    299 TRAP GX JT 1.63999 1.63999 1.09333 1.09333
    300 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    301 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    302 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    303 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    304 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    305 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    306 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    307 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    308 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    309 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    310 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    311 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    312 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    313 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    314 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    315 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    316 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    317 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    318 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    319 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    320 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    321 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    322 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    323 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    324 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    325 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    326 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    327 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    328 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    329 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    330 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    331 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    332 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    333 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    334 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    335 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    336 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    337 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    338 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    339 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    340 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    341 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    342 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    343 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    344 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    345 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    346 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    347 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    348 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    349 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    350 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    351 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    352 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    353 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    354 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    355 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    356 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    357 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    358 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    359 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    360 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    361 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    362 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    363 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    364 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    365 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    366 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    367 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    368 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    369 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    370 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    371 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    372 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    373 TRAP GX JT 1.09333 1.09333 0.546666 0.546666
    374 TRAP GX JT 0.546666 0.546666 0 0
    375 TRAP GX JT 0.546666 0.546666 0 0
    376 TRAP GX JT 0.546666 0.546666 0 0
    377 TRAP GX JT 0.546666 0.546666 0 0
    378 TRAP GX JT 0.546666 0.546666 0 0
    379 TRAP GX JT 0.546666 0.546666 0 0
    380 TRAP GX JT 0.546666 0.546666 0 0
    381 TRAP GX JT 0.546666 0.546666 0 0
    382 TRAP GX JT 0.546666 0.546666 0 0
    383 TRAP GX JT 0.546666 0.546666 0 0
    384 TRAP GX JT 0.546666 0.546666 0 0
    385 TRAP GX JT 0.546666 0.546666 0 0
    386 TRAP GX JT 0.546666 0.546666 0 0
    387 TRAP GX JT 0.546666 0.546666 0 0
    388 TRAP GX JT 0.546666 0.546666 0 0
    389 TRAP GX JT 0.546666 0.546666 0 0
    390 TRAP GX JT 0.546666 0.546666 0 0
    391 TRAP GX JT 0.546666 0.546666 0 0
    392 TRAP GX JT 0.546666 0.546666 0 0
    393 TRAP GX JT 0.546666 0.546666 0 0
    394 TRAP GX JT 0.546666 0.546666 0 0
    395 TRAP GX JT 0.546666 0.546666 0 0
    396 TRAP GX JT 0.546666 0.546666 0 0
    397 TRAP GX JT 0.546666 0.546666 0 0
    398 TRAP GX JT 0.546666 0.546666 0 0
    399 TRAP GX JT 0.546666 0.546666 0 0
    400 TRAP GX JT 0.546666 0.546666 0 0
    401 TRAP GX JT 0.546666 0.546666 0 0
    402 TRAP GX JT 0.546666 0.546666 0 0
    403 TRAP GX JT 0.546666 0.546666 0 0
    404 TRAP GX JT 0.546666 0.546666 0 0
    405 TRAP GX JT 0.546666 0.546666 0 0
    406 TRAP GX JT 0.546666 0.546666 0 0
    407 TRAP GX JT 0.546666 0.546666 0 0
    408 TRAP GX JT 0.546666 0.546666 0 0
    409 TRAP GX JT 0.546666 0.546666 0 0
    410 TRAP GX JT 0.546666 0.546666 0 0
    411 TRAP GX JT 0.546666 0.546666 0 0
    412 TRAP GX JT 0.546666 0.546666 0 0
    413 TRAP GX JT 0.546666 0.546666 0 0
    414 TRAP GX JT 0.546666 0.546666 0 0
    415 TRAP GX JT 0.546666 0.546666 0 0
    416 TRAP GX JT 0.546666 0.546666 0 0
    417 TRAP GX JT 0.546666 0.546666 0 0
    418 TRAP GX JT 0.546666 0.546666 0 0
    419 TRAP GX JT 0.546666 0.546666 0 0
    420 TRAP GX JT 0.546666 0.546666 0 0
    421 TRAP GX JT 0.546666 0.546666 0 0
    422 TRAP GX JT 0.546666 0.546666 0 0
    423 TRAP GX JT 0.546666 0.546666 0 0
    424 TRAP GX JT 0.546666 0.546666 0 0
    425 TRAP GX JT 0.546666 0.546666 0 0
    426 TRAP GX JT 0.546666 0.546666 0 0
    427 TRAP GX JT 0.546666 0.546666 0 0
    428 TRAP GX JT 0.546666 0.546666 0 0
    429 TRAP GX JT 0.546666 0.546666 0 0
    430 TRAP GX JT 0.546666 0.546666 0 0
    431 TRAP GX JT 0.546666 0.546666 0 0
    432 TRAP GX JT 0.546666 0.546666 0 0
    433 TRAP GX JT 0.546666 0.546666 0 0
    434 TRAP GX JT 0.546666 0.546666 0 0
    435 TRAP GX JT 0.546666 0.546666 0 0
    436 TRAP GX JT 0.546666 0.546666 0 0
    437 TRAP GX JT 0.546666 0.546666 0 0
    438 TRAP GX JT 0.546666 0.546666 0 0
    439 TRAP GX JT 0.546666 0.546666 0 0
    440 TRAP GX JT 0.546666 0.546666 0 0
    441 TRAP GX JT 0.546666 0.546666 0 0
    442 TRAP GX JT 0.546666 0.546666 0 0
    443 TRAP GX JT 0.546666 0.546666 0 0
    444 TRAP GX JT 0.546666 0.546666 0 0
    445 TRAP GX JT 0.546666 0.546666 0 0
    446 TRAP GX JT 0.546666 0.546666 0 0
    447 TRAP GX JT 0.546666 0.546666 0 0
    LOAD 11 LOADTYPE None TITLE EX-
    SELFWEIGHT X -0.3
    ELEMENT LOAD
    449 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    450 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    451 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    452 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    453 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    454 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    455 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    456 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    457 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    458 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    459 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    460 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    461 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    462 TRAP GX JT -3.28 -3.28 -2.73334 -2.73334
    463 TRAP GX JT -3.28 -3.28 -2.73334 -2.73334
    464 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    465 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    466 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    467 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    468 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    469 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    470 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    471 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    472 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    473 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    474 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    475 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    476 TRAP GX JT -3.28 -3.28 -2.73334 -2.73332
    477 TRAP GX JT -3.28 -3.28 -2.73332 -2.73334
    478 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    479 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    480 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    481 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    482 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    483 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    484 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    485 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    486 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    487 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    488 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    489 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    490 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    491 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    492 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    493 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    494 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    495 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    496 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    497 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    498 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    499 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    500 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    501 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    502 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    503 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    504 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    505 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    506 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    507 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    508 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    509 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    510 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    511 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    512 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    513 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    514 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    515 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    516 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    517 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    518 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    519 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    520 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    521 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    522 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    523 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    524 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    525 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    526 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    527 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    528 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    529 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    530 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    531 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    532 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    533 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    534 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    535 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    536 TRAP GX JT -2.73334 -2.73334 -2.18666 -2.18666
    537 TRAP GX JT -2.73334 -2.73334 -2.18666 -2.18666
    538 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    539 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    540 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    541 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    542 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    543 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    544 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    545 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    546 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    547 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    548 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    549 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    550 TRAP GX JT -2.73332 -2.73334 -2.18666 -2.18666
    551 TRAP GX JT -2.73334 -2.73332 -2.18666 -2.18666
    552 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    553 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    554 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    555 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    556 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    557 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    558 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    559 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    560 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    561 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    562 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    563 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    564 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    565 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    566 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    567 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    568 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    569 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    570 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    571 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    572 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    573 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    574 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    575 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    576 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    577 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    578 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    579 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    580 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    581 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    582 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    583 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    584 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    585 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    586 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    587 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    588 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    589 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    590 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    591 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    592 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    593 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    594 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    595 TRAP GX JT -2.73332 -2.73332 -2.18666 -2.18666
    596 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    597 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    598 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    599 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    600 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    601 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    602 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    603 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    604 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    605 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    606 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    607 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    608 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    609 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    610 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    611 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    612 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    613 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    614 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    615 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    616 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    617 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    618 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    619 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    620 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    621 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    622 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    623 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    624 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    625 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    626 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    627 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    628 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    629 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    630 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    631 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    632 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    633 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    634 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    635 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    636 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    637 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    638 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    639 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    640 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    641 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    642 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    643 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    644 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    645 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    646 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    647 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    648 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    649 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    650 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    651 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    652 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    653 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    654 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    655 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    656 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    657 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    658 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    659 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    660 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    661 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    662 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    663 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    664 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    665 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    666 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    667 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    668 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    669 TRAP GX JT -2.18666 -2.18666 -1.63999 -1.63999
    670 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    671 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    672 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    673 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    674 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    675 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    676 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    677 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    678 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    679 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    680 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    681 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    682 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    683 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    684 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    685 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    686 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    687 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    688 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    689 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    690 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    691 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    692 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    693 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    694 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    695 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    696 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    697 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    698 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    699 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    700 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    701 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    702 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    703 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    704 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    705 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    706 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    707 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    708 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    709 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    710 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    711 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    712 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    713 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    714 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    715 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    716 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    717 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    718 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    719 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    720 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    721 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    722 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    723 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    724 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    725 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    726 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    727 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    728 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    729 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    730 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    731 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    732 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    733 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    734 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    735 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    736 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    737 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    738 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    739 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    740 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    741 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    742 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    743 TRAP GX JT -1.63999 -1.63999 -1.09333 -1.09333
    744 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    745 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    746 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    747 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    748 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    749 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    750 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    751 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    752 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    753 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    754 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    755 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    756 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    757 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    758 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    759 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    760 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    761 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    762 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    763 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    764 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    765 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    766 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    767 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    768 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    769 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    770 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    771 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    772 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    773 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    774 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    775 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    776 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    777 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    778 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    779 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    780 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    781 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    782 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    783 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    784 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    785 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    786 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    787 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    788 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    789 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    790 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    791 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    792 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    793 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    794 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    795 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    796 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    797 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    798 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    799 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    800 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    801 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    802 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    803 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    804 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    805 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    806 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    807 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    808 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    809 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    810 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    811 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    812 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    813 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    814 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    815 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    816 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    817 TRAP GX JT -1.09333 -1.09333 -0.546666 -0.546666
    818 TRAP GX JT -0.546666 -0.546666 0 0
    819 TRAP GX JT -0.546666 -0.546666 0 0
    820 TRAP GX JT -0.546666 -0.546666 0 0
    821 TRAP GX JT -0.546666 -0.546666 0 0
    822 TRAP GX JT -0.546666 -0.546666 0 0
    823 TRAP GX JT -0.546666 -0.546666 0 0
    824 TRAP GX JT -0.546666 -0.546666 0 0
    825 TRAP GX JT -0.546666 -0.546666 0 0
    826 TRAP GX JT -0.546666 -0.546666 0 0
    827 TRAP GX JT -0.546666 -0.546666 0 0
    828 TRAP GX JT -0.546666 -0.546666 0 0
    829 TRAP GX JT -0.546666 -0.546666 0 0
    830 TRAP GX JT -0.546666 -0.546666 0 0
    831 TRAP GX JT -0.546666 -0.546666 0 0
    832 TRAP GX JT -0.546666 -0.546666 0 0
    833 TRAP GX JT -0.546666 -0.546666 0 0
    834 TRAP GX JT -0.546666 -0.546666 0 0
    835 TRAP GX JT -0.546666 -0.546666 0 0
    836 TRAP GX JT -0.546666 -0.546666 0 0
    837 TRAP GX JT -0.546666 -0.546666 0 0
    838 TRAP GX JT -0.546666 -0.546666 0 0
    839 TRAP GX JT -0.546666 -0.546666 0 0
    840 TRAP GX JT -0.546666 -0.546666 0 0
    841 TRAP GX JT -0.546666 -0.546666 0 0
    842 TRAP GX JT -0.546666 -0.546666 0 0
    843 TRAP GX JT -0.546666 -0.546666 0 0
    844 TRAP GX JT -0.546666 -0.546666 0 0
    845 TRAP GX JT -0.546666 -0.546666 0 0
    846 TRAP GX JT -0.546666 -0.546666 0 0
    847 TRAP GX JT -0.546666 -0.546666 0 0
    848 TRAP GX JT -0.546666 -0.546666 0 0
    849 TRAP GX JT -0.546666 -0.546666 0 0
    850 TRAP GX JT -0.546666 -0.546666 0 0
    851 TRAP GX JT -0.546666 -0.546666 0 0
    852 TRAP GX JT -0.546666 -0.546666 0 0
    853 TRAP GX JT -0.546666 -0.546666 0 0
    854 TRAP GX JT -0.546666 -0.546666 0 0
    855 TRAP GX JT -0.546666 -0.546666 0 0
    856 TRAP GX JT -0.546666 -0.546666 0 0
    857 TRAP GX JT -0.546666 -0.546666 0 0
    858 TRAP GX JT -0.546666 -0.546666 0 0
    859 TRAP GX JT -0.546666 -0.546666 0 0
    860 TRAP GX JT -0.546666 -0.546666 0 0
    861 TRAP GX JT -0.546666 -0.546666 0 0
    862 TRAP GX JT -0.546666 -0.546666 0 0
    863 TRAP GX JT -0.546666 -0.546666 0 0
    864 TRAP GX JT -0.546666 -0.546666 0 0
    865 TRAP GX JT -0.546666 -0.546666 0 0
    866 TRAP GX JT -0.546666 -0.546666 0 0
    867 TRAP GX JT -0.546666 -0.546666 0 0
    868 TRAP GX JT -0.546666 -0.546666 0 0
    869 TRAP GX JT -0.546666 -0.546666 0 0
    870 TRAP GX JT -0.546666 -0.546666 0 0
    871 TRAP GX JT -0.546666 -0.546666 0 0
    872 TRAP GX JT -0.546666 -0.546666 0 0
    873 TRAP GX JT -0.546666 -0.546666 0 0
    874 TRAP GX JT -0.546666 -0.546666 0 0
    875 TRAP GX JT -0.546666 -0.546666 0 0
    876 TRAP GX JT -0.546666 -0.546666 0 0
    877 TRAP GX JT -0.546666 -0.546666 0 0
    878 TRAP GX JT -0.546666 -0.546666 0 0
    879 TRAP GX JT -0.546666 -0.546666 0 0
    880 TRAP GX JT -0.546666 -0.546666 0 0
    881 TRAP GX JT -0.546666 -0.546666 0 0
    882 TRAP GX JT -0.546666 -0.546666 0 0
    883 TRAP GX JT -0.546666 -0.546666 0 0
    884 TRAP GX JT -0.546666 -0.546666 0 0
    885 TRAP GX JT -0.546666 -0.546666 0 0
    886 TRAP GX JT -0.546666 -0.546666 0 0
    887 TRAP GX JT -0.546666 -0.546666 0 0
    888 TRAP GX JT -0.546666 -0.546666 0 0
    889 TRAP GX JT -0.546666 -0.546666 0 0
    890 TRAP GX JT -0.546666 -0.546666 0 0
    891 TRAP GX JT -0.546666 -0.546666 0 0
    448 TRAP GX JT -3.28 -3.28 -2.73332 -2.73332
    LOAD 12 LOADTYPE None TITLE EZ+
    SELFWEIGHT Z 0.3
    LOAD 13 LOADTYPE None TITLE EV
    SELFWEIGHT Y 0.15
    LOAD 17 LOADTYPE None TITLE EZ-
    SELFWEIGHT Z -0.3
    **Pre analisis para que funcione con cada caso independiente
    PERFORM ANALYSIS
    *RESORTE
    CHANGE
    *LRFD LOAD COMBINATIONS
    LOAD 100 LOADTYPE None TITLE [LRFD] 1.4D
    REPEAT LOAD
    1 1.4
    PERFORM ANALYSIS
    CHANGE
    LOAD 101 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + 1.6(L+TH+F) + 0.5T
    REPEAT LOAD
    1 1.2 2 1.6 3 1.6 9 1.6
    PERFORM ANALYSIS
    CHANGE
    LOAD 114 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX+Z- + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 10 1.0 17 0.3 13 1.0 3 0.5 9 0.5
    PERFORM ANALYSIS
    CHANGE
    LOAD 115 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX+Z+ + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 10 1.0 12 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 116 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX-Z- + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 11 1.0 13 1.0 17 0.3
    PERFORM ANALYSIS
    CHANGE
    LOAD 117 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX-Z+ + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 11 1.0 12 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 118 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ+X- + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 12 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 119 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ+X+ + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 12 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 120 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ-X- + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 17 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 121 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ-X+ + EV + 0.5L
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 17 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 122 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX+Z- + EV
    REPEAT LOAD
    PERFORM ANALYSIS
    CHANGE
    LOAD 123 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX+Z+ + EV
    REPEAT LOAD
    1 1.2 2 1.6 10 1.0 12 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 124 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX-Z- + EV
    REPEAT LOAD
    1 1.2 2 1.6 3 0.5 9 0.5 11 1.0 17 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 125 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EX-Z+ + EV
    REPEAT LOAD
    PERFORM ANALYSIS
    CHANGE
    LOAD 126 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ+X- + EV
    REPEAT LOAD
    1 1.2 2 1.6 12 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 127 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ+X+ + EV
    REPEAT LOAD
    1 1.2 2 1.6 12 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 128 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ-X- + EV
    REPEAT LOAD
    1 1.2 2 1.6 17 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 129 LOADTYPE None TITLE [LRFD] 1.2D + 1.6H + EZ-X+ + EV
    REPEAT LOAD
    1 1.2 2 1.6 17 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 200 LOADTYPE None TITLE [ASD] D + H + L
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 9 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 207 LOADTYPE None TITLE [ASD] D + H + L + EX+Z- + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 10 1.0 17 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 208 LOADTYPE None TITLE [ASD] D + H + L + EX+Z+ + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 10 1.0 12 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 209 LOADTYPE None TITLE [ASD] D + H + L + EX-Z- + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 11 1.0 17 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 210 LOADTYPE None TITLE [ASD] D + H + L + EX-Z+ + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 11 1.0 12 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 211 LOADTYPE None TITLE [ASD] D + H + L + EZ+X- + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 12 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 212 LOADTYPE None TITLE [ASD] D + H + L + EZ+X+ + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 12 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 213 LOADTYPE None TITLE [ASD] D + H + L + EZ-X- + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 17 1.0 11 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 214 LOADTYPE None TITLE [ASD] D + H + L + EZ-X+ + EV
    REPEAT LOAD
    1 1.0 2 1.0 3 1.0 17 1.0 10 0.3 13 1.0
    PERFORM ANALYSIS
    CHANGE
    LOAD 215 LOADTYPE None TITLE [ASD] D + H + 0.7EX+Z+ + EV
    REPEAT LOAD
    1 0.9 2 1.0 10 0.7 12 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 216 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EX-Z- + EV
    REPEAT LOAD
    1 0.9 2 1.0 10 0.7 17 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 217 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EX-Z+ + EV
    REPEAT LOAD
    1 0.9 2 1.0 11 0.7 12 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 218 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EZ+X- + EV
    REPEAT LOAD
    1 0.9 2 1.0 12 0.7 11 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 219 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EZ+X+ + EV
    REPEAT LOAD
    1 0.9 2 1.0 12 0.7 10 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 220 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EZ-X- + EV
    REPEAT LOAD
    1 0.9 2 1.0 17 0.7 11 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    LOAD 221 LOADTYPE None TITLE [ASD] 0.9D + H + 0.7EZ-X+ + EV
    REPEAT LOAD
    1 0.9 2 1.0 17 0.7 10 0.21 13 0.7
    PERFORM ANALYSIS
    CHANGE
    FINISH
  • In your model I have created a Group named "GA" and assigned nodes 3 to 5 in it. After the analysis I selected the group "GA" in the Ranges and I can see that only nodes 3 to 5 are shown in the results tables. Are you not getting the same? If not, then please upgrade to the most recent STAAD.Pro CE version 22.12.00.142 and check again.
