STEEL STRUCTURE WITH MIXED CONCRETE COLUMN DESIGN IN STAAD PRO
Hello as we know when a project has some columbs which are steel and some which are concrete,we will not be able to design pedestal as concrete and steel are both on the same level.
Is there any trick to design this type of building pedestals?
Parents Reply
  • My intention was design these concrete columns and to design pedestals which will support these steel columns.
    As we know if all columns were steel,we could be able to design pedestals without even modelling concrete columns direct in the model.
    If i model concrete columns below the steel columns,which parameters do i need to assign on a joint of steel column and concrete column so as to make sure that my steel columns are pinned support?and when i want the steel columns to be fixed on the pedestal what parameters do i need to assign?
