I am trying to determine the weight capacity of the columns on my footing.
Which software you are using? Can you please share a sample model and explain what you are looking for?
For example for that specific column, I would like to know how much weight it carries so that I can know that weight that the footing below it will carry. Also I am using staad pro connect.
I believe there is a support at the bottom of the column. You can analyze the structure and get the reaction for that support which you can use as load for foundation design.
How do I do that?
Please upload the file here.
