I have created a model in the physical modeller (attached).
I have defined all bracing members as trusses.
I am getting errors in the cross-bracing when I run the analysis. It says "Zero Stiffness in Direction..."
What is the best way to model these cross-bracing members to avoid this error?
Thank-You
Structure 1.zip
To avoid this, in the Physical Modeler go to File -> Options -> Analysis Model and uncheck the option "Add intermediate nodes at intersections".
Answer Verified By: Ryan Hill
