My company usually only use one wind definition for wins area load and factor it for different wind cases. I have 3 wind definitions, and I am getting these messages in Editor. Is it a warning message?
DEFINE WIND LOADTYPE 1 NESC HEAVYINT 0.008 0.008 HEIG 0 100TYPE 2 EXTREME WIND<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!CUSTOM:PARAMS !> END GENERATED DATA BLOCKINT 0.044 0.044 HEIG 0 100TYPE 3 CONCURRENT WIND / ICE<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!CUSTOM:PARAMS !> END GENERATED DATA BLOCKINT 0.013 0.013 HEIG 0 100
This seems to be a part from the editor file and not a warning. can you please upload the STAAD model for a quick check?
Sorry it's my first time using forum. You want to see the file or the text?
You can attach the .std file here using insert option.
Here you go. Thank you
ST-1.std
Thanks for sharing the file. I have run the model but found no such warning. There is only one type of warning in the file which is explained in the below link.
Load Case # XX is already defined in a previous envelope. The load case of final envelope type will override previous envelope type attributes
So the following message will appear in Editor when there is more than one wind area load?
<! STAAD PRO GENERATED DATA DO NOT MODIFY !!!CUSTOM:PARAMS!> END GENERATED DATA BLOCK
