6661.Bridge3-ULS.STD
Can anyone in the group, please help me out for run this attached file. For me it taking more than 5 hours.
Would you be able to provide details of the software and version you're using and your post can be moved to a more appropriate forum.
Thanks for your response.
I am using STAAD.Pro CONNECT Edition V22 Update 11
I have run the file in my system and found similar time to complete the run. Considering huge number of load combinations along with plates need a considerable amount of time to run the model. I was wondering if you could decrease the number of load combinations for the model. I understand you have vehicle load in the model and tried to simulate the loading in every possible position to get the accurate result. In that case if you can find out few critical load position and use them instead of all the generated loads, it will help you to reduce the load combination number which in turn will reduce the run time.
