WITH OUT VERTICAL HEXA (28-06-23).STD
I can't get any soft store in the model-
We had discussions on different plan configuration in -
SIG Workshop: Special Considerations of Seismic Analysis- Torsional Irregularity Checks
https://wcc.on24.com/webcast/previewlobby?e=2312407&k=13FD3B4778E7CDAB19DAB67BE52EFE0F
You may check this.
WRONG FILE SORRYWITHOUT SHEARWALL VERTICAL HEXA (27-06-2023).STD
I can see that steel bracings are used in the model. If you remove the bracings, there would not b such issues.
0363.WITHOUT SHEARWALL VERTICAL HEXA (27-06-2023).STD
steel bracings are to make hexagrid pattern do you have any hexagrid model without soft story
