how to find maximum force or moment in a member consisting of different combinations in staad pro?
i have this model and i have to find maximum forces for each member that which combination gives max forces for each member.
is there any way that i click the member and it shows the maximum forces and moment from the given given combos that for this particular member this combo gives the max force and moment..
thanks alot.
greenhouse COLD FORM V7.STD
  • 1) In the Results menu in the Postprocessing workflow select the required combinations in the Select Load Case icon.
    2) Right click on the member in question an select New View to show the particular member only.
    3) Turn on the required diagram (axial force, shear force or bending moment).
    4) In the results menu, select Envelope option from the Load drop down list.
    5) To switch on the values on the diagrams, go to Annotate -> Beam Results and select the required values.
