Design of ground supported slabs
I am trying to design a ground supported slab using RCDC and i keep getting this error. what is the work around.
Thanks in advance
  • Hello,
    The warning shown here is realted to the manual input you are providing. If you are okay with with input you can proceed.
    But, RCDC is not equipped to design ground supported slab. RCDC can only design suspended floor and roof slab using moment coefficient method described in different International country code. For ground supported slab the design criteria and boundary conditions are totally different. You may use RCDC FE along with STAAD.Pro to model and design those kind of slabs.
    Thanks & Regards,
    Abhisek Mandal
    Global Technical Support
