STAAD PRO ONLY DESIGNED IN FOR DEAD AND LIVE LOAD COMBINATION WHILE 63 COMBINATIONS ARE THERE WOR THE CRANE EARTHQUAKE AND WIND LOAD AND DID NOT UNDERSTAND WHAT IS THE CAUSE
ATTCHED STAAD FILE FOR YOUR REFERENCE
YMS.STD
I just checked the member number 1 and found the critical load case as 158.
So, it is clear that STAAD is taking other combinations also.
I have checked one more member 50, where critical case is 100 due to slenderness check. But internally it is checking for other cases and that can be verified from output file. As all other ratio is less than that of slenderness criteria, STAAD reports slendernes as critical; and 100 as critcal load case.
OK GOT IT !!!! THERE IS ANOTHER ISSUE WITH LOAD WHICH IS RESLOVE NOW!!!
