Floor Load Generation Error - Complex 3D Quadrilaterals
I am modeling a 3d steel truss/frame pedestrian bridge and am running into an issue with the floor load command. Every time I try to apply floor loads to a group I have entitled "DECK"  (see attached Command File) I receive an error stating that "Cannot Generate Load for Command".
I have made several attempts to resolve this issue by adjusting the X, Y, and Z ranges for the floor load command or by creating a "TEST" group of only one panel. I still receive the same error or it will only model on a panel in the middle of the span (not the panel in the TEST group).
Any guidance is much appreciated.
STAAD SPACE DXF IMPORT OF BRIDGE LAYOUT-ATTEMPT 2.DXF
START JOB INFORMATION
ENGINEER DATE 17-Jul-23
END JOB INFORMATION
INPUT WIDTH 79
UNIT INCHES KIP
SET FLOOR LOAD TOLERANCE 0.083
JOINT COORDINATES
416 14989.4 0 -10710.4; 417 15102.1 0 -10669.1; 418 15025.3 10.3344 -10504.8;
419 14921.3 10.3344 -10564.8; 420 14921.5 16.2659 -10356.1;
421 14829.3 16.2659 -10432.9; 422 14793.8 21.5452 -10227.3;
423 14716.1 21.5452 -10318.8; 424 14645.9 25.2359 -10122.2;
425 14585.1 25.2359 -10225.6; 426 14482.3 26.9059 -10044;
427 14440 26.9059 -10156.3; 429 13808.8 26.9133 -10146.2;
430 13604.1 23.5723 -10105.5; 431 13661.6 23.5723 -10210.8;
432 13452.9 18.9136 -10205.8; 433 13527.6 18.9136 -10299.7;
434 13321.2 13.632 -10330.4; 435 13410.8 13.632 -10410.2;
436 13212.7 6.8933 -10475.7; 437 13314.6 6.8933 -10539; 438 13130.6 0 -10637.5;
439 13241.9 0 -10682.4; 440 13229 0 -9207.07; 441 13347.5 0 -9187.77;
442 13388.7 6.9355 -9341.37; 443 13276.5 6.9355 -9383.91;
444 13459.7 13.7094 -9483.66; 445 13358.2 13.7094 -9547.73;
446 13557.6 19.1417 -9608.94; 447 13471 19.1417 -9691.96;
448 13610.3 23.8462 -9810.79; 449 13678.6 23.8462 -9712.15;
450 13817.7 27.3722 -9789.15; 451 13770.4 27.3722 -9899.44;
452 14437.9 25.1436 -9791.25; 453 14484.5 25.1436 -9901.86;
454 14577.6 20.7649 -9715.19; 455 14645.2 20.7649 -9814.29;
456 14699.2 14.8447 -9612.8; 457 14785.3 14.8447 -9696.41;
458 14798 7.6776 -9488.2; 459 14899.1 7.6776 -9552.95;
460 13368.1 3.4678 -9264.57; 461 13424.2 10.4033 -9412.52;
462 13508.6 16.4255 -9546.3; 463 13618.1 21.8579 -9660.54;
464 13893.6 28.4807 -9813; 465 13969.4 29.1014 -9836.85;
466 14048.5 29.7221 -9845.09; 467 14127.6 30 -9853.33;
468 14206.8 29.6499 -9845.63; 469 14285.9 28.382 -9837.92;
470 14361.9 27.0133 -9814.59; 471 14638.4 17.8048 -9664;
472 14748.6 11.5164 -9550.5; 473 14990.3 0 -9367.19;
474 14944.7 3.8388 -9460.07; 476 14715.3 17.8048 -9755.35;
477 14564.8 23.2738 -9858.08; 478 14385 27.0133 -9938.62;
480 13868.8 28.4807 -9935.86; 481 13690.4 25.6092 -9855.12;
482 13540.6 21.8579 -9751.37; 483 13414.6 16.4255 -9619.85;
484 13317.3 10.4033 -9465.82; 485 13252.7 3.4678 -9295.49;
486 13171.6 3.44 -10556.6; 487 13266.9 10.34 -10403.1;
488 13387.1 16.2728 -10268.1; 489 13528.5 21.5544 -10155.6;
491 13770.2 26.9133 -10032.6; 492 13868.7 28.2824 -10002.4;
494 14383.9 28.2797 -10009.7; 495 14564.1 26.9059 -10083.1;
496 14719.8 23.5659 -10174.7; 497 14857.6 18.9055 -10291.7;
498 14973.4 13.6263 -10430.4; 499 15063.7 6.8896 -10587;
500 14955.4 6.8896 -10637.6; 501 14875.3 13.6263 -10498.9;
502 14772.7 18.9055 -10375.8; 503 14650.6 23.5659 -10272.2;
504 14512.5 26.9059 -10191; 505 14362.6 28.2797 -10134.6;
506 14285.2 28.8527 -10112.8; 507 14205.2 29.4256 -10104.6;
508 14125.3 30 -10096.5; 509 14045.1 29.4284 -10102.1;
510 13964.9 28.8554 -10107.7; 511 13886.9 28.2824 -10126.9;
512 13735.2 25.2428 -10178.5; 513 13594.6 21.5544 -10255.3;
514 13469.2 16.2728 -10354.9; 515 13362.7 10.34 -10474.6;
516 13278.3 3.44 -10610.7; 517 14883.3 0 -9314.64; 518 14843.7 3.8388 -9395.31;
519 13967.2 28.8554 -9972.27; 520 14126.4 30 -9974.9;
521 14285.6 28.382 -9975.29; 522 14384.5 27.6465 -9974.16;
523 13868.7 28.3815 -9968.78; 526 14842.2 11.5164 -9624.68;
528 13770.3 27.1427 -9966.01; 529 14483.4 26.0247 -9972.77;
530 13687.1 25.2428 -10069; 531 13688.7 25.426 -9962.4;
532 14564.5 25.0898 -9971.7; 533 14046.8 29.4284 -9973.58;
534 14205.6 29.4256 -9975.75; 535 14989.4 252 -10710.4;
536 15102.1 252 -10669.1; 537 15025.3 262.334 -10504.8;
538 14921.3 262.334 -10564.8; 539 14921.5 268.266 -10356.1;
540 14829.3 268.266 -10432.9; 541 14793.8 273.545 -10227.3;
542 14716.1 273.545 -10318.8; 543 14645.9 277.236 -10122.2;
544 14585.1 277.236 -10225.6; 546 13661.6 275.572 -10210.8;
547 13452.9 270.914 -10205.8; 548 13527.6 270.914 -10299.7;
549 13321.2 265.632 -10330.4; 550 13410.8 265.632 -10410.2;
551 13212.7 258.893 -10475.7; 552 13314.6 258.893 -10539;
553 13130.6 252 -10637.5; 554 13241.9 252 -10682.4; 555 13229 252 -9207.07;
556 13347.5 252 -9187.77; 557 13388.7 258.935 -9341.37;
558 13276.5 258.935 -9383.91; 559 13459.7 265.709 -9483.66;
560 13358.2 265.709 -9547.73; 561 13557.6 271.142 -9608.94;
562 13471 271.142 -9691.96; 563 13610.3 275.846 -9810.79;
564 13678.6 275.846 -9712.15; 565 14577.6 272.765 -9715.19;
566 14645.2 272.765 -9814.29; 567 14699.2 266.845 -9612.8;
568 14785.3 266.845 -9696.41; 569 14798 259.678 -9488.2;
570 14899.1 259.678 -9552.95; 571 13368.1 255.468 -9264.57;
572 13424.2 262.403 -9412.52; 573 13508.6 268.426 -9546.3;
574 13618.1 273.858 -9660.54; 575 13748.2 277.609 -9750.65;
576 13817.7 279.372 -9789.15; 577 13893.6 280.481 -9813;
578 13969.4 281.101 -9836.85; 579 14048.5 281.722 -9845.09;
580 14127.6 282 -9853.33; 581 14206.8 281.65 -9845.63;
582 14285.9 280.382 -9837.92; 583 14361.9 279.013 -9814.59;
584 14437.9 277.144 -9791.25; 585 14507.7 274.954 -9753.22;
586 14638.4 269.805 -9664; 587 14748.6 263.516 -9550.5;
588 14990.3 252 -9367.19; 589 14944.7 255.839 -9460.07;
591 14842.2 263.516 -9624.68; 592 14715.3 269.805 -9755.35;
593 14564.8 275.274 -9858.08; 594 13690.4 277.609 -9855.12;
595 13540.6 273.858 -9751.37; 596 13414.6 268.426 -9619.85;
597 13317.3 262.403 -9465.82; 598 13252.7 255.468 -9295.49;
600 13172 252 -10556.6; 601 13266.9 262.34 -10403.1;
602 13387.1 268.273 -10268.1; 603 13528.5 273.554 -10155.6;
605 14564.1 278.906 -10083.1; 606 14719.8 275.566 -10174.7;
607 14857.6 270.905 -10291.7; 608 14973.4 265.626 -10430.4;
609 15063.7 258.89 -10587; 610 14955.4 258.89 -10637.6;
611 14875.3 265.626 -10498.9; 612 14772.7 270.905 -10375.8;
613 14650.6 275.566 -10272.2; 614 14512.5 278.906 -10191;
615 14440 278.906 -10156.3; 616 14362.6 280.28 -10134.6;
617 14285.2 280.853 -10112.8; 618 14205.2 281.426 -10104.6;
619 14125.3 282 -10096.5; 620 14045.1 281.428 -10102.1;
621 13964.9 280.855 -10107.7; 622 13886.9 280.282 -10126.9;
623 13808.8 278.913 -10146.2; 624 13735.2 277.243 -10178.5;
625 13594.6 273.554 -10255.3; 626 13469.2 268.273 -10354.9;
627 13362.7 262.34 -10474.6; 628 13278.3 255.44 -10610.7;
629 14883.3 252 -9314.64; 630 14843.7 255.839 -9395.31;
631 13964.9 371.19 -10107.7; 632 13967.2 371.19 -9972.27;
633 13969.4 371.19 -9836.85; 635 14126.4 378 -9974.9; 636 14127.6 378 -9853.33;
637 14285.2 370.884 -10112.8; 639 14285.6 370.884 -9975.29;
640 14285.9 370.884 -9837.92; 641 14046.8 374.595 -9973.58;
642 14206 374.442 -9975.14; 643 13687.1 277.243 -10069;
644 13688.7 277.426 -9962.4; 645 14564.5 277.09 -9971.7;
646 14045.1 374.595 -10102.1; 647 14048.5 374.595 -9845.09;
648 14205.2 374.442 -10104.6; 649 14206.8 374.442 -9845.63;
650 14125.7 378 -10095.8; 654 13748.2 151.609 -9750.65;
655 13690.4 151.609 -9855.12; 656 14564.8 149.274 -9858.08;
657 14507.7 149.274 -9753.22; 658 13748.2 25.6092 -9750.65;
659 13688.7 330 -9962.4; 660 13813.3 353.883 -9967.67;
662 13690.4 330 -9855.12; 663 13687.1 330 -10069; 664 14564.5 330 -9971.7;
665 14564.1 330 -10083.1; 666 14564.8 330 -9858.08; 667 14440 353.254 -10156.3;
668 14437.9 353.254 -9791.25; 669 13808.8 353.883 -10146.2;
670 13817.7 353.883 -9789.15; 671 14438 353.363 -9973.8;
672 14512.5 152.906 -10191; 673 14564.1 152.906 -10083.1;
674 13735.2 151.243 -10178.5; 675 13687.1 151.243 -10069;
676 13604.1 275.321 -10105.5; 677 14507.7 22.9543 -9753.22;
MEMBER INCIDENCES
240 416 417; 241 419 418; 242 421 420; 243 423 422; 244 425 424; 245 427 426;
246 429 491; 247 431 430; 248 433 432; 249 435 434; 250 437 436; 251 438 439;
252 440 441; 253 443 442; 254 445 444; 255 447 446; 256 448 449; 257 451 450;
258 453 452; 259 455 454; 260 457 456; 261 459 458; 262 441 460; 263 442 461;
264 444 462; 265 446 463; 266 449 658; 267 450 464; 268 465 466; 269 467 468;
270 469 470; 271 452 677; 272 454 471; 273 456 472; 274 474 473; 275 526 459;
276 476 457; 277 477 455; 278 478 453; 279 480 519; 280 481 451; 281 482 448;
282 483 447; 283 484 445; 284 485 443; 285 438 486; 286 436 487; 287 434 488;
288 432 489; 289 430 530; 290 491 492; 291 521 494; 292 426 495; 293 424 496;
294 422 497; 295 420 498; 296 418 499; 297 500 416; 298 501 419; 299 502 421;
300 503 423; 301 504 425; 302 505 427; 303 507 506; 304 509 508; 305 511 510;
306 512 429; 307 513 431; 308 514 433; 309 515 435; 310 516 437; 311 517 518;
312 510 519; 313 508 520; 314 506 521; 315 521 522; 316 523 519; 317 519 533;
318 520 534; 319 485 460; 320 484 461; 321 483 462; 322 482 463; 323 480 464;
324 474 518; 325 526 472; 326 476 471; 327 477 677; 328 478 470; 329 516 486;
330 515 487; 331 514 488; 332 513 489; 333 512 530; 334 511 492; 335 505 494;
336 504 495; 337 503 496; 338 502 497; 339 501 498; 340 500 499; 341 491 528;
342 492 523; 343 494 522; 344 426 529; 345 530 531; 346 495 532; 347 509 533;
348 533 466; 349 507 534; 350 534 468; 351 473 517; 352 439 486; 353 437 486;
354 437 487; 355 435 487; 356 435 488; 357 433 488; 358 433 489; 359 431 489;
360 431 530; 361 429 530; 362 429 492; 363 510 492; 364 510 533; 365 508 533;
366 508 534; 367 506 534; 368 506 494; 369 427 494; 370 427 495; 371 425 495;
372 425 496; 373 423 496; 374 423 497; 375 421 497; 376 421 498; 377 419 498;
378 419 499; 379 416 499; 380 474 517; 381 474 458; 382 526 458; 383 526 456;
384 476 456; 385 476 454; 386 477 454; 387 477 452; 388 478 452; 389 478 469;
390 534 469; 391 534 467; 392 533 467; 393 533 465; 394 480 465; 395 480 450;
396 481 450; 403 481 449; 404 482 449; 405 482 446; 406 483 446; 407 483 444;
408 484 444; 409 484 442; 410 485 442; 411 485 441; 412 519 465; 413 520 467;
414 521 469; 415 534 521; 416 533 520; 419 532 477; 420 531 481; 421 529 453;
422 522 478; 423 523 480; 424 528 451; 425 531 528; 426 528 523; 427 529 532;
428 522 529; 429 518 458; 430 439 516; 431 437 515; 432 435 514; 433 433 513;
434 429 511; 435 510 509; 436 508 507; 437 506 505; 438 425 503; 439 423 502;
440 421 501; 441 419 500; 442 499 417; 443 498 418; 444 497 420; 445 496 422;
446 495 424; 447 494 426; 448 492 519; 449 530 491; 450 489 430; 451 488 432;
452 487 434; 453 486 436; 454 440 485; 455 443 484; 456 445 483; 457 447 482;
458 448 481; 459 451 480; 460 521 478; 461 453 477; 462 455 476; 463 457 526;
464 459 474; 465 472 458; 466 471 456; 467 470 452; 468 468 469; 469 466 467;
470 464 465; 471 463 449; 472 462 446; 473 461 444; 474 460 442; 475 431 512;
476 427 504; 477 535 536; 478 538 537; 479 540 539; 480 542 541; 481 544 543;
482 546 676; 483 548 547; 484 550 549; 485 552 551; 486 553 554; 487 555 556;
488 558 557; 489 560 559; 490 562 561; 491 563 564; 492 566 565; 493 568 567;
494 570 569; 495 556 571; 496 571 557; 497 557 572; 498 572 559; 499 559 573;
500 573 561; 501 561 574; 502 574 564; 503 564 575; 504 576 577; 505 577 578;
506 578 579; 507 579 580; 508 580 581; 509 581 582; 510 582 583; 511 583 584;
512 584 585; 513 565 586; 514 586 567; 515 567 587; 516 587 569; 517 589 588;
518 570 589; 519 591 570; 520 568 591; 521 592 568; 522 566 592; 523 593 566;
524 563 594; 525 595 563; 526 562 595; 527 596 562; 528 560 596; 529 597 560;
530 558 597; 531 598 558; 532 555 598; 533 553 600; 534 600 551; 535 551 601;
536 601 549; 537 549 602; 538 602 547; 539 547 603; 540 603 676; 541 676 643;
542 605 543; 543 543 606; 544 606 541; 545 541 607; 546 607 539; 547 539 608;
548 608 537; 549 537 609; 550 609 536; 551 610 535; 552 538 610; 553 611 538;
554 540 611; 555 612 540; 556 542 612; 557 613 542; 558 544 613; 559 614 544;
560 615 614; 561 616 615; 562 617 616; 563 618 617; 564 619 618; 565 620 619;
566 621 620; 567 622 621; 568 623 622; 569 624 623; 570 546 624; 571 625 546;
572 548 625; 573 626 548; 574 550 626; 575 627 550; 576 552 627; 577 628 552;
578 554 628; 579 630 629; 580 569 630; 581 631 632; 582 632 633; 583 650 635;
584 635 636; 585 637 639; 586 639 640; 587 632 641; 588 641 635; 589 635 642;
590 642 639; 591 598 571; 592 597 572; 593 596 573; 594 595 574; 595 575 594;
596 589 630; 597 591 587; 598 592 586; 599 593 585; 600 628 600; 601 627 601;
602 626 602; 603 625 603; 604 624 643; 605 614 605; 606 613 606; 607 612 607;
608 611 608; 609 610 609; 610 643 644; 611 644 594; 612 605 645; 613 645 593;
614 646 641; 615 641 647; 616 648 642; 617 642 649; 618 588 629; 619 554 600;
620 552 600; 621 552 601; 622 550 601; 623 550 602; 624 548 602; 625 548 603;
626 546 603; 627 546 643; 628 631 641; 629 650 641; 630 650 642; 631 637 642;
632 544 605; 633 544 606; 634 542 606; 635 542 607; 636 540 607; 637 540 608;
638 538 608; 639 538 609; 640 609 535; 641 589 629; 642 589 569; 643 591 569;
644 591 567; 645 592 567; 646 592 565; 647 593 565; 648 642 640; 649 642 636;
650 641 636; 651 641 633; 652 594 564; 653 595 564; 654 595 561; 655 596 561;
656 596 559; 657 597 559; 658 597 557; 659 598 557; 660 598 556; 661 555 440;
662 556 441; 663 557 442; 664 558 443; 665 559 444; 666 561 446; 668 576 450;
669 578 465; 670 467 580; 671 582 469; 672 584 452; 673 565 454; 674 567 456;
675 569 458; 676 629 517; 677 588 473; 678 570 459; 679 568 457; 681 593 477;
682 645 532; 683 594 481; 684 563 448; 685 562 447; 686 560 445; 687 588 459;
688 568 459; 689 568 455; 690 656 455; 691 629 458; 692 567 458; 693 567 454;
694 657 454; 695 584 469; 696 580 469; 697 580 465; 698 576 465; 699 654 449;
700 561 449; 701 561 444; 702 557 444; 703 557 441; 704 558 440; 705 558 445;
706 562 445; 707 562 448; 708 655 448; 709 563 655; 710 566 656; 711 585 677;
712 565 657; 713 584 657; 714 657 452; 715 575 658; 716 564 654; 717 576 654;
718 654 450; 719 644 531; 720 659 660; 721 639 671; 722 536 417; 723 535 416;
724 538 419; 725 537 418; 726 539 420; 727 540 421; 728 541 422; 729 542 423;
731 544 425; 732 605 495; 733 615 427; 734 617 506; 735 619 508; 736 614 504;
737 621 510; 738 623 429; 739 546 431; 740 548 433; 741 550 435; 742 552 437;
743 554 439; 744 624 512; 745 643 530; 746 676 430; 747 547 432; 748 549 434;
749 551 436; 750 553 438; 751 636 580; 752 633 578; 753 662 594; 754 640 582;
755 619 650; 756 631 621; 757 637 617; 758 663 643; 759 659 644; 760 664 645;
761 665 605; 762 666 593; 763 575 576; 764 637 667; 765 648 637; 766 646 650;
767 663 659; 768 659 662; 769 633 647; 770 636 649; 771 666 664; 772 664 665;
773 481 658; 774 585 565; 775 667 615; 776 668 584; 777 669 623; 778 670 576;
779 667 665; 780 669 631; 781 663 669; 782 662 670; 783 670 633; 784 640 668;
785 668 666; 786 660 632; 787 671 664; 788 660 670; 789 669 660; 790 671 668;
791 667 671; 792 669 632; 793 632 670; 794 663 660; 795 660 662; 796 639 668;
797 667 639; 798 671 666; 799 665 671; 800 615 584; 801 617 582; 802 619 580;
803 621 578; 804 623 576; 805 544 672; 806 672 425; 807 615 672; 808 672 427;
809 538 416; 810 538 421; 811 542 421; 812 542 425; 813 537 417; 814 537 420;
815 541 420; 816 541 424; 817 673 424; 818 543 673; 819 552 439; 820 552 435;
821 548 435; 822 548 431; 823 674 431; 824 546 674; 825 551 438; 826 551 434;
827 547 434; 828 547 430; 829 675 430; 830 676 675; 831 674 429; 832 623 674;
833 650 648; 834 631 646; 835 647 636; 836 649 640; 837 658 450; 838 677 454;
839 621 429; 840 621 508; 841 617 508; 842 617 427; 843 663 644; 844 644 662;
845 665 645; 846 645 666;
START GROUP DEFINITION
MEMBER
_SW_TRUSS 247 TO 251 285 TO 289 307 TO 310 329 TO 332 352 TO 360 430 TO 433 -
450 TO 453 475 482 TO 486 533 TO 541 570 TO 578 600 TO 603 619 TO 627 739 -
740 TO 743 746 TO 750 819 TO 830
_NW_TRUSS 240 TO 244 293 TO 301 337 TO 340 371 TO 379 438 TO 446 477 TO 481 -
542 TO 559 606 TO 609 632 TO 640 722 TO 729 731 805 806 809 TO 818
_SE_TRUSS 252 TO 256 262 TO 266 281 TO 284 319 TO 322 403 TO 411 454 TO 458 -
471 TO 474 487 TO 491 495 TO 503 524 TO 532 591 TO 594 652 TO 666 -
684 TO 686 699 TO 709 716
_NE_TRUSS 259 TO 261 272 TO 277 311 324 TO 326 351 380 TO 386 429 462 TO 466 -
492 TO 494 513 TO 523 579 580 596 TO 598 618 641 TO 647 673 TO 679 -
687 TO 694 710 712 774 838
_MOMENTFRAME 245 246 257 258 267 TO 271 302 TO 306 312 TO 318 323 327 328 -
333 TO 336 341 TO 346 412 TO 416 419 TO 428 434 TO 437 467 TO 470 476 504 -
505 TO 512 560 TO 569 581 TO 590 595 599 604 605 610 TO 613 668 TO 672 682 -
683 711 715 719 TO 721 732 TO 738 744 745 751 TO 773 775 TO 778 780 783 784 -
786 TO 791 800 TO 804 833 TO 837
_MOMBRACES 278 TO 280 290 TO 292 361 TO 370 387 TO 396 447 TO 449 459 TO 461 -
628 TO 631 648 TO 651 695 TO 698 713 714 717 718 779 781 782 785 792 TO 799 -
807 808 831 832 839 TO 842
_BRACE 329 354 TO 396 403 TO 411 600 621 TO 627 632 TO 647 652 TO 660
FLOOR
_DECK 240 TO 314 317 TO 351 412 TO 416 419 TO 424 429 TO 476 773 837 838
_SE_LEG 247 TO 251 285 TO 289 307 TO 310 329 TO 333 430 TO 433 450 TO 453 475
_TEST 251 285 329 430
END GROUP DEFINITION
DEFINE MATERIAL START
ISOTROPIC STEEL_50_KSI
E 29000
POISSON 0.3
DENSITY 0.000283
ALPHA 6.5e-06
DAMP 0.03
TYPE STEEL
STRENGTH FY 50 FU 62 RY 1.5 RT 1.2
ISOTROPIC STEEL_N
E 29000
POISSON 0.3
DENSITY 0.000283
ALPHA 6.5e-06
DAMP 0.03
G 11153.8
TYPE STEEL
STRENGTH FY 150 FU 185 RY 1.5 RT 1.2
ISOTROPIC STEEL
E 29000
POISSON 0.3
DENSITY 0.000283
ALPHA 6.5e-06
DAMP 0.03
TYPE STEEL
STRENGTH RY 1.5 RT 1.2
END DEFINE MATERIAL
UNIT FEET POUND
MEMBER PROPERTY AMERICAN
278 TO 280 290 TO 292 329 354 TO 361 370 TO 387 396 403 TO 411 447 TO 449 -
459 TO 461 600 621 TO 627 632 TO 647 652 TO 660 663 687 TO 710 712 TO 714 -
716 TO 718 805 TO 832 839 TO 842 TABLE ST HSST10X10X0.625
661 662 664 TO 666 673 TO 679 681 684 TO 686 722 TO 729 731 739 TO 743 746 -
747 TO 750 TABLE ST HSST12X12X0.625
240 TO 277 281 TO 289 293 TO 328 330 TO 346 351 TO 353 412 TO 416 419 TO 446 -
450 TO 458 462 TO 599 601 TO 613 618 TO 620 668 TO 672 682 683 711 715 719 -
720 TO 721 732 TO 738 744 745 751 TO 791 800 TO 804 833 TO 837 -
838 TABLE ST HSST18X18X.75
347 TO 350 362 TO 369 388 TO 395 614 TO 617 628 TO 631 648 TO 651 792 TO 799 -
843 TO 846 TABLE ST HSST8X6X0.5
UNIT INCHES KIP
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
416 417 438 TO 441 473 517 PINNED
LOAD 1 LOADTYPE Dead  TITLE SELF-WEIGHT
SELFWEIGHT Y -1
UNIT FEET POUND
PERFORM ANALYSIS PRINT STATICS CHECK
PARAMETER 1
CODE AISC UNIFIED 2016
METHOD LRFD
RATIO 1 MEMB 240 TO 396 403 TO 416 419 TO 666 668 TO 679 681 TO 729 731 TO 842
SGR 5 ALL
TBRC 0 MEMB 240 TO 396 403 TO 416 419 TO 666 668 TO 679 681 TO 729 731 TO 842
TORSION 1 MEMB 240 TO 396 403 TO 416 419 TO 666 668 TO 679 681 TO 729 731 -
732 TO 842
TRACK 1 MEMB 240 TO 396 403 TO 416 419 TO 666 668 TO 679 681 TO 729 731 TO 842
CHECK CODE MEMB 240 TO 396 403 TO 416 419 TO 666 668 TO 679 681 TO 729 731 -
732 TO 842
FINISH
Parents Reply Children
