offset model - reg
Sir/Madam,
Pls. find attached two STAAD model of a steel structure.
First model is made without offset and the next model is made with an offset .
The reaction loads are different . Pls. clarify
STAAD SPACE
START JOB INFORMATION
ENGINEER DATE 27-Jul-21
END JOB INFORMATION
INPUT WIDTH 79
UNIT MMS NEWTON
JOINT COORDINATES
1 0 0 0; 2 0 -1580 0; 3 0 -1700 0; 4 -1240 -350 0; 5 445 -1580 0;
MEMBER INCIDENCES
1 1 2; 2 2 3; 3 4 2; 4 2 5;
DEFINE MATERIAL START
ISOTROPIC STEEL
E 205000
POISSON 0.3
DENSITY 7.68195e-005
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
STRENGTH FY 253.2 FU 407.8 RY 1.5 RT 1.2
ISOTROPIC RIGID
E 2e+007
POISSON 0.3
END DEFINE MATERIAL
MEMBER PROPERTY INDIAN
1 TO 4 TABLE FR ISMC150
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 4 FIXED
LOAD 1 LOADTYPE Dead  TITLE DL
SELFWEIGHT Y -1
PERFORM ANALYSIS PRINT STATICS CHECK
FINISH
FINISH
STAAD SPACE
END JOB INFORMATION
INPUT WIDTH 79
UNIT MMS NEWTON
JOINT COORDINATES
MEMBER INCIDENCES
ISOTROPIC STEEL
E 205000
POISSON 0.3
ALPHA 1.2e-005
DAMP 0.03
TYPE STEEL
ISOTROPIC RIGID
E 2e+007
POISSON 0.3
END DEFINE MATERIAL
CONSTANTS
MATERIAL STEEL ALL
SUPPORTS
1 4 FIXED
MEMBER OFFSET
4 START 75 0 0
SELFWEIGHT Y -1
FINISH
FINISH
