Section database take too much time in Staad CE 12 & ALSO IN v2023
Are you talking about section database or the databases under properties tab? If the issue is related to assign of new member from database, this is already reported to the development team. If you are seeing anything else please let me know in details.
Abhisek M any solution ?
Please let us know which option you are referring here. The Section database at Top Ribbon Bar or the Database under Property window
YES if you click on this legacy and standard it will take 4 to 5 sec to open and if you are using the standard it will not open in older version
The is reported to the development team that in STAAD.Pro V23, the section database under Property window is taking more time to open. But I am unable to replicate the second issue you have mentioned. Can you please elaborate more about the issue (if you are using the legacy it will not open in older version).
