Hi There,
When I import my file from RAM SS to RCDC and try to generate the load combination using the "From Analysis" option, my load combinations are not imported. I would appreciate it if you could please assist with this. Loads and load combinations have already been specified in RAM SS.
Can you please share the file for a quick check?
Sure! How do I go about sharing it?
Do I need to share the RAM file as well?
Im interested in knowing more about this situation.
The RCDC load combination does it consider repeat loads
Yes, that will be helpful in further investigation.
https://virtuosity.bentley.com/resource/importing-repeat-load-cases-in-rcdc/#:~:text=A%20Repeat%20load%20case%20is,that%20incorporate%20any%20non%2Dlinearities.
You will get your answer in this link.
